    Animator State per scene
    renderpluginsextensions
    20 Posts 4 Posters 10.2k Views 4 Watching
    • fredo6F Offline
      This is what the Visit Controller is supposed to do in 2 forms:
      1. With a kind of slider controller
      2. with switches embedded into the model that you activate This part if not finished for the GUI.
      You can try the Visitor and see what I mean.
      The final possibility is to create Scene snapshots at certain stage of the animation.
      • JQLJ Offline
        JQL
        I'm sorry if I've missed that. Animator is an overwhelming experience and I haven't got the time to explore it deeply.
        www.casca.pt
        Visit us on facebook!
        • ntxdaveN Offline
          ntxdave
          I had some problems with controlling the location of the Visitor window but it worked fine. My tool for capturing the screen did not work correctly though. I encourage you to try it.
          One thing it did not do though was use the Views in my model. When I used the arrows on the Film_1 line, it did open and close the door but it did not play my views like if I was in Animator.
          Press F1...thank me later
          • fredo6F Offline
            In Visitor, the cameras are disabled, actually, since you 'visit' the model.
            • ntxdaveN Offline
              ntxdave
              No problem with that. Just need to be able to control where the Visitor panel is located better. Initially shows up at the bottom of the screen and I have to expand to full screen to then get control. Once I do get control, I still cannot move it around on the screen,
              Now, I did find out that my screen capture did work. It is a little hard to see that I am clicking the scene tabs but here is a quick little example of what it looks like. Well not exactly, when I switch the scenes, it stopped recording but it does work.
              Door Swing with 2 Scenes
              Well, I just tried in another model and I had full control over the Visitor......
              • JQLJ Offline
                JQL
                That's a hell of a feature thanks for your gif dave!
                I'm wondering one thing though... Is there any room for CSS customization in your plugins Fredo?
                I'm absolutelly sure I'm going to use this in client's meetings but I'd really love to be able to set a minimalistic style for Visitor's dialog... Something black and white probably. Could I do that if I dig into your CSS file? (I happen to know a little CSS/html coding...)
                www.casca.pt
                • ntxdaveN Offline
                  ntxdave
                  I also would like to be able to distinguish between clips and sequences:
                  There is an error in this image (a stray sequence designator). But if possible in addition to distinguishing between the 2, it would be outstanding if the sequences were nestled below their clip.
                  As an example:
                  Top Brush Demo
                  • Car
                    .....- Car Translation
                    .....- Wheels Spin
                  • Top Brush
                    .....- Top Brush Rotate
                    .....- Top Brush Spin
                  You get the idea.
                  • fredo6F Offline
                    @JQL: there is no CSS, as I style the dialog boxes in Ruby. But could be an option
                    @ntxdave: Yes, I will certainly present differently anyway. Currently, this is more for me to debug.
                    One small remark:
                    • In Edit mode, you see all films, clip and sequence.
                    • If you click on one row, you select it, it becomes yellow
                    • You can switch to the Runtime mode by toggling the small wrench (the panel gets blue) and you only see the sliders selected.
                    • ntxdaveN Offline
                      ntxdave
                      One small remark:
                      Good things to know.......
                      Boy, this thread got me thinking. It would be great if the visitor worked inside the SketchUp Viewer or if there was a way to get this view in a web page. At a convention, I had a number of links for videos of different car washes. Man would it be neat if there was a way to click on a link for a car wash and it would launch the visitor and its capabilities. Would almost eliminate the need for generating videos πŸ˜„
                      • fredo6F Offline
                        Actually, I was thinking of creating dynamic components (switches and various shapes), so that when you interact you start a piece of animation.
                        • ntxdaveN Offline
                          ntxdave
                          Where I would eventually like to go is to not have to have the SketchUp software installed. Just a way to view the files with some animation.
                          • JQLJ Offline
                            JQL
                            Grea idea! I wonder how far off from an animation plugin animator would go if you follow that path, but I like the possibilities.
                            www.casca.pt
                            • ntxdaveN Offline
                              ntxdave
                              @jql said:
                              Yep - good question.
                              Again, I think the capabilities for the visitor is something I have wanted for a long time. I would like to be able to share the file and let them see the model and its animations without having to have the SketchUp software. Again, thinking about being able to give a customer the file with animations but they do not have SU.
                              Either way, I like what I am seeing but other things are more important to me in the short run (like scaling). I need that for a couple of pieces of the car wash equipment but then I am being short sighted. I am willing to go with the majority and Fredo's original schedule.
                              • JQLJ Offline
                                JQL
                                If you don't have sketchup how do you get visitor in a file? Sketchup viewer, for what I know, doesn't have ruby support so you can't have visitor activated in it. Or am I missing something?
                                www.casca.pt
                                • ntxdaveN Offline
                                  ntxdave
                                  Right now, they only show the customer drawings. I am trying to entice them with animations. So, other than me and the president of the company no one ever sees the actual SU files. I think the president has a copy of SU but no one else does. The only time they really see the files is at a convention and even then they only use PDF and movie files. What I am seeing with the visitor has, in my opinion, the opportunity to show off the SU file in a really constructive way. At least that is my goal. I am searching for a way to get them beyond the paper environment.
                                  Last night I was thinking, wouldn't it be neat if you could use the visitor feature to show off your model on a tablet with all of the animation features. But then, I have been accused of being crazy before. Back in the late 70's some people I worked with at a technology company thought I should be fired because I suggested building a portable computer (can you say laptop).
                                  Anyway, the visitor feature of Animator has me fired up. I see lots of potential for showing models developed in SU. Architecture like you discussed, products demos like Solo showed and many more things where you have the ability to "bring that drawing/product to life". What I am seeing is via Animator, you can produce a lot of the same type of things as Lumion, LumenRT and others. Maybe I am going too far.
                                  • ntxdaveN Offline
                                    ntxdave
                                    Fredo, I am not sure how/if this should be addressed. In some of my testing/learning, I created an animation that uses views to capture different scenes to show/hide objects.
                                    In the video below, I used the view to capture a "spray" when the car reaches a certain piece of equipment. In the normal videos, this works great. However, when I view it using the Visitor, I do not get the same thing because it ignores my "views" and shows things based on the scene that I have active. Notice that there are 2 scenes in this model. One is named "No Spray" and the other is named "Spray". I added a view just before the piece of equipment that sprays to switch the scene from "No Spray" to "Spray" so you would see the spray when the car goes through that piece of equipment. In a full car wash, this type of situation will take place several times and it works just fine. But in Visitor it does not work because it shows the entire animation based on the view of the selected scene. Hope this makes sense.
                                    Maybe I asking to "eat my cake and have it too". Is there any way to view the animation the same way in both Animator and the Visitor? Again, this is not the highest priority in the world. I see this as a long range question that is far less important than many of the other things you are working on.
                                    • fredo6F Offline
                                      Dave,
                                      Yes I know. Visitor is just in draft mode.
                                      Actually, I will allow the usage of views (same filtering as in the Editor).
                                      I will also decouple the Camera, Style and Layer Visibility in the next version. View Camera will still have the possibility to carry style and layer visibility, but that will not be the default.
                                      This will allow to control layers independently of view (in your case, the visibility of the water curtain is linked to the animation of the car, regardless of the view).
                                        Your horizontal blue object don't rotate, does this normal?
                                        • ntxdaveN Offline
                                          ntxdave
                                          @fredo6 said:
                                          Dave,
                                          Sounds good to me.. πŸ‘ πŸ‘ πŸ‘
