    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 53.6k Views 40 Watching
    • W Offline
      Whaat
      @deaneau said:
      Hi Whaat, is it possible to change the currency?. If possible historical curency, too.
      so i could show in my historical project "The Berlin Wall And Inner German Border" the cost of this over the years. Thanks.
      Hi Deaneau,
      In 2.1, you can change the currency in the Report Settings dialog (access from the Quantifier). Is this what you mean?
        rv1974
        Whaat, I've got some project with kilometers of the attached railing which get turned in a funky manner. My problem is I have to do a lot of stupid manual work. Here's a brief description:
        To get the desired state (1) I build a rough one with the assembly (2) I managed to create.
        Then I manuallyadd some sub-assembly (3) in a 'pale red' areas, explode assembly (2) in order to delete unneeded studs in the corners and rotate the green element (3) appropriately.
        Important note: Our local safety regulations demand vertical netgaps <= 10cm. So in the final output I manage to respect this standard.
        The question is Could my manual labor get solved in my assemly?
        Untitled.skp
        • W Offline
          Whaat
          Hi rv1974,
          These types of assemblies are currently quite tough to do in PB2 as a one step assembly. You are on the right track to break this up into multiple assemblies. It becomes a multi-step process but it is still much faster than doing the whole thing manually. I made a slight change with your corner posts which should save you a bit of time. If you split your corner posts and use a junctions setback, I think you can still get the effect you want at the corners without having to rotate element 4.
          Modified-Railing-Assembly.skp
          • W Offline
            Whaat
            @kaas said:
            Hi Dale,
            I updated to the new version of ProfileBuilder and now I get these warnings at every startup of SketchUp. PB works fine though.
            I just tested and de-installed PB and the errors are gone. Re-installed PB again and they are back.
            Any idea how to resolve this?
            regards,
            Max
            Hi Max,
            Thanks for reporting this strange issue. I'll look into this and try to get it sorted out. You are the first one to report this so I wonder if there is a conflict with another plugin that you have.
            Can you please post the full text of the error and not just a screenshot? Thanks!
              kaas
              @whaat said:
              Hi Max,
              Strange coincidence. Will investigate by cleaning the plugin folder and adding one by one.
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:93: warning: already initialized constant FileUtils::OPT_TABLE
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:93: warning: previous definition of OPT_TABLE was here
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1271: warning: already initialized constant FileUtils::Entry_::S_IF_DOOR
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1271: warning: previous definition of S_IF_DOOR was here
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1532: warning: already initialized constant FileUtils::Entry_::DIRECTORY_TERM
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1532: warning: previous definition of DIRECTORY_TERM was here
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1536: warning: already initialized constant FileUtils::Entry_::SYSCASE
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1536: warning: previous definition of SYSCASE was here
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1655: warning: already initialized constant FileUtils::LOW_METHODS
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1655: warning: previous definition of LOW_METHODS was here
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1661: warning: already initialized constant FileUtils::METHODS
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1661: warning: previous definition of METHODS was here
              DL is deprecated, please use Fiddle
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/Win32API.rb:8: warning: already initialized constant Win32API::DLL
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/win32API.rb:8: warning: previous definition of DLL was here
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/Win32API.rb:9: warning: already initialized constant Win32API::TYPEMAP
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/win32API.rb:9: warning: previous definition of TYPEMAP was here
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/Win32API.rb:10: warning: already initialized constant Win32API::POINTER_TYPE
              C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/win32API.rb:10: warning: previous definition of POINTER_TYPE was here
                kaas
                Hi Dale,
                regards,
                Max
                  kaas
                  @Dale, turns out its two of my own plugins that have something to do with this as well although, if I de-install ProfileBuilder the warnings are gone.
                  I have two plugins that use:
                  require 'win32API'
                  require 'FileUtils'
                  I was under the impression that using 'require' would prevent these kind of issues. Am I mistaken here?
                  You are using the same in PB?
                    rv1974
                    Whaat, thank you for help\clarifications. At least I'm glad I use the plugin effectively and hope for PB improvements in future. I this particular case if I'm not mistaken the current BP doesn't let me 'infill only' and 'infill special every approx n cm' components.
                    And of course even not being 100% polished PB saves me tons of time for sure!
                    • W Offline
                      Whaat
                      require 'win32API'
                      require 'FileUtils'
                      That is very strange because I do not 'require' those libraries for PB2.
                      Perhaps when you have PB2 installed, it changes the timing or sequence of your plugins being loaded which results in the error being displayed. I am guessing one of your plugins has set the following:
                      Sketchup.debug_mode = true
                      Try searching your plugins for this expression. If you find it, change it to 'false' and see if that solves your problem.
                        kaas
                        Very strange indeed.
                        I did find the 'debug_mode=' in 1 of my plugins and changed it to false. Also unloaded tt_solidinspector2 that was reported using that argument.
                        Still the same errors appear. I might do a fresh re-install of all the plugins in the near future.
                        thanks for looking into this.
                        • jujuJ Offline
                          juju
                          Has there been an update to PB2.1? I see it is to the top of the list when i go to EW and organize plugins by "most recent", however it doesn't show in My Extensions as needing to be updated?
                          • W Offline
                            Whaat
                            Hi juju,
                            If you have 2.1 already, there is no need to update at this time. The EW probably shows it as most recent because I made a change to the EW page.
                              rv1974
                              Hm.. Sometimes I can't scale entities created with PB2
                              kkkl.skp
                              • W Offline
                                Whaat
                                PB2 actually disables scaling Profile entities that were created with PB2.
                                Because PB2 is a parametric tool, users are encouraged to use the parametric features of PB2 to change the dimensions of the entity rather than the scale tool. When the scale tool is used, things can get messed up, especially in quantity reports.
                                  mwm5053
                                  Dale this plugin is great, I've used the original PB for years but the ability to create my own profiles and the assembly builder really made this chain possible.
                                  Well with the money
                                  Walt
                                  2011 iMac
                                  SU 2015 Pro, 2017 Make
                                  V2 Twilight
                                  macOS Sierra 10.12.5
                                  • W Offline
                                    Whaat
                                    Well with the money
                                    Walt
                                    Wow, thanks Walt! That is so great to hear!
                                    Would you be interested in copy / pasting your post into a review at the EW page?
                                    http://extensions.sketchup.com/en/content/profile-builder-2
                                    Cheers,
                                    Dale
                                      mwm5053
                                      Done for sure
                                      2011 iMac
                                      V2 Twilight
                                      • W Offline
                                        Whaat
                                        @mwm5053 said:
                                        Done for sure
                                        Thanks so much!
                                          rv1974
                                          Whaat is it possible to add 'triangulate all' existing profiles? or at least 'triangulate on creation' option? Zillions of unique materials is a HUGEheadache when exporting to Max.
                                          P.S. Please check possibility of
                                          1. multiple unconnected curves as single path
                                          2. faster path (ideally context ignoring single click )finding. Now it's too much clicking.
                                          • W Offline
                                            Whaat
                                            SketchUV has a triangulate feature (using right-click context menu) that should do the trick.
                                            SketchUp Extension Warehouse
                                            Your library of custom third-party extensions created to optimize your SketchUp workflow.
                                            (extensions.sketchup.com)
                                            • 11
                                            • 2 / 11
