    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    New Graphics Card .. Now Have Warning!
    43 Posts 10 Posters 2.7k Views 10 Watching
    • Joe WoodJ Offline
      Joe Wood
      Here's that one model I've been posting images from,
      top left text disappears and bottom left gets smudged.
      Example Corner_Connections.skp
      Joe Wood
      woodsshop.com/
        Garry K
        Sketchup 2016 Pro
        Windows 10
        • bazB Offline
          baz
          Weird, I get the same result as Joe...
          • pbacotP Offline
            Nope. Like Garry, I'm not getting it on PNG and JPG.
            But for a PDF both leader-less text objects are disappeared!
              Garry K
              Joe
              I very rarely use 2D export. Instead I use a screen capture program called faststone. Best 20$ US that I've spent in a long time. They have a 30 day free trial. Check it out.
              I use it because it can do everything from videos to various image specs and editing.
              Essentially it is WYSIWYG. It is Windows only - however - from what I've seen you do have Windows.
              FastStone Image Viewer, Screen Capture, Photo Resizer ...
              (www.faststone.org)
              • Joe WoodJ Offline
                Joe Wood
                I need to export at a higher rez, then resize, to cut down on the jaggies, no?
                I export these jpg plans pages at 6,000 pixels wide, then resize to 2,000.
                If I use another format then jpg, like tif, at a lower rez and till get rid of the jaggies? (won't solve my present problem though)
                Joe Wood
                woodsshop.com/
                • bazB Offline
                  baz
                  Joe, I noticed that the text in question has a leader line which you have hidden, this I believe is the problem, maybe a bug.
                  But simply redo your text in a clear area which will negate the leader line and bob's yer uncle.
                  baz
                  • sketch3d.deS Offline
                    sketch3d.de
                    Win 7 x64
                    SUP v16.1.1449 x64
                    as already elaborated above, grouping the text entities workarounds the issue (see attach).
                    Archive Content: PNG (9999x4494x24)
                      sketch3d.de
                      @joe wood said:
                      ...don't even know what Raster means...
                      raster data means pixel based outpout as on your monitor or printer or photo or newspaper... whereas vector data is defined as analytic lines, circle/arcs, curves/splines etc.:
                      https://upload.wikimedia.org/wikipedia/commons/thumb/a/aa/VectorBitmapExample.svg/597px-VectorBitmapExample.svg.png
                      • Joe WoodJ Offline
                        Joe Wood
                        I tried grouping all the text, it's all there now but I still get a black box
                        Baz, I don't understand this
                        "simply redo your text in a clear area which will negate the leader line"
                        Joe Wood
                        woodsshop.com/
                          He means clicking in empty space with the Text tool allow you place text without a leader line. Leader lines appear when you infer a face, edge, point or object
                          Download the free D'oh Book for SketchUp šŸ“–
                            sketch3d.de
                            update the GeForce driver to the latest version 356.19.
                            Artefacts with Hardware Acceleration enabled or disabled?
                              Charlie__V
                              Joe, All
                              I get the same result as Joe. (on export to png @ 6000pix)
                              However if I place new textbox by double left click (no leader)SU behaves as expected.(and I think others have suggested this)
                              Also, in entity info,Joes text that is giving him trouble has "hidden" showing as to leader.
                              New text placed by double click shows the arrow and leader blank in entity info. (see attached pix & revised SU model)
                              Joe, did you originally place the text with a leader showing and then select hidden in entity info?
                              Charlie
                              Having trouble uploading images...........Joe.....try exporting from SU model attached.
                              Joes original SU model with new text via double left click
                              Joe original text entity info
                              New text entity info (placed via double click)
                              • Joe WoodJ Offline
                                Joe Wood
                                I think you folks have resolved this issue .. what a crew! I've never just dbl clicked in open space, I've always anchored it and hidden the leader, and no, didn't select Hidden I don't think,
                                thanks for the help with this Major problem!
                                Joe Wood
                                woodsshop.com/
                                • 2 / 3
