    New Graphics Card .. Now Have Warning!
    43 Posts 10 Posters 3.8k Views 10 Watching
    • sketch3d.deS Offline
      sketch3d.de
      @joe wood said:
      ...anyone else have any ideas?
      where would I report this bug??
      is the model very small/big in absolute dimensions or very far away from the origin?
      offic. SU Pro Technical Support Form
      • Joe WoodJ Offline
        Joe Wood
        Nope, just an average sized model right at the origin.
        This happens with all my models, now that I've gone with SUp 2016 ..
        thanks for the link Sketch!
        Joe Wood
        woodsshop.com/
          sketch3d.de
          try if grouping the text elements helps.
          • Joe WoodJ Offline
            Joe Wood
            Yeah already done that, I almost always group all the text in a scene, so I can hide it all for the next scene.
            Joe Wood
            woodsshop.com/
            • Joe WoodJ Offline
              Joe Wood
              Just tried a png, exact same missing / smudged text ..
              I can't zoom out, I'll loose the scene setup.
              I'm already at max resolution 1920 x 1080.
              has anyone else reported this issue??
              Joe Wood
              woodsshop.com/
                sketch3d.de
                try if zooming out helps, if yes you may compensate this by enlarging the export resolution and cropping the white space away with your image editor.
                btw, export to losless PNG format instead of lossy JPEG w/ artefacts at hard contrasts or ol' TIFF.
                  sketch3d.de
                  the raster export format has obviously nothing to do with this issue...
                  ... the max. raster export resolution has nothing to do with the screen resolution but is configured during the raster export (see button "Options..." in export dialog).
                  zooming a bit out and cropping the resulting raster image will likely result in a similar scene setup... but as always, it's up to you.
                  • Joe WoodJ Offline
                    Joe Wood
                    Sorry, I don't understand, don't even know what Raster means, I tried zooming out a bit,
                    and the same problem. This is happening with almost every image with text I export from 2016.
                    Joe Wood
                    woodsshop.com/
                    • pbacotP Offline
                      Have you posted a file here, in which this occurs? I'd be curious what result I have. I don't do a LOT of this sort of export with text, but never seen a problem-- that is if the text is positioned correctly in the view, it comes out OK AFAIK.
                      • Joe WoodJ Offline
                        Joe Wood
                        It's happening with every model I have PB, some created in SUp 5, but all of my newer 2016 models too, I wrote to support, what a drag.
                        Joe Wood
                        woodsshop.com/
                        • Joe WoodJ Offline
                          Joe Wood
                          Here's that one model I've been posting images from,
                          top left text disappears and bottom left gets smudged.
                          Example Corner_Connections.skp
                          Joe Wood
                          woodsshop.com/
                            Garry K
                            Sketchup 2016 Pro
                            Windows 10
                            • bazB Offline
                              baz
                              Weird, I get the same result as Joe...
                              • pbacotP Offline
                                Nope. Like Garry, I'm not getting it on PNG and JPG.
                                But for a PDF both leader-less text objects are disappeared!
                                  Garry K
                                  Joe
                                  I very rarely use 2D export. Instead I use a screen capture program called faststone. Best 20$ US that I've spent in a long time. They have a 30 day free trial. Check it out.
                                  I use it because it can do everything from videos to various image specs and editing.
                                  Essentially it is WYSIWYG. It is Windows only - however - from what I've seen you do have Windows.
                                  (www.faststone.org)
                                  • Joe WoodJ Offline
                                    Joe Wood
                                    I need to export at a higher rez, then resize, to cut down on the jaggies, no?
                                    I export these jpg plans pages at 6,000 pixels wide, then resize to 2,000.
                                    If I use another format then jpg, like tif, at a lower rez and till get rid of the jaggies? (won't solve my present problem though)
                                    Joe Wood
                                    woodsshop.com/
                                    • bazB Offline
                                      baz
                                      Joe, I noticed that the text in question has a leader line which you have hidden, this I believe is the problem, maybe a bug.
                                      But simply redo your text in a clear area which will negate the leader line and bob's yer uncle.
                                      baz
                                        sketch3d.de
                                        Win 7 x64
                                        SUP v16.1.1449 x64
                                        as already elaborated above, grouping the text entities workarounds the issue (see attach).
                                        Archive Content: PNG (9999x4494x24)
                                          sketch3d.de
                                          @joe wood said:
                                          ...don't even know what Raster means...
                                          raster data means pixel based outpout as on your monitor or printer or photo or newspaper... whereas vector data is defined as analytic lines, circle/arcs, curves/splines etc.:
                                          https://upload.wikimedia.org/wikipedia/commons/thumb/a/aa/VectorBitmapExample.svg/597px-VectorBitmapExample.svg.png
                                          • Joe WoodJ Offline
                                            Joe Wood
                                            I tried grouping all the text, it's all there now but I still get a black box
                                            Baz, I don't understand this
                                            "simply redo your text in a clear area which will negate the leader line"
                                            Joe Wood
                                            woodsshop.com/
                                            With your input, this post could be even better šŸ’—
                                            • 2 / 3
