    New Graphics Card .. Now Have Warning!
    43 Posts 10 Posters 4.2k Views 10 Watching
    • JQLJ
      JQL
      yes
      www.casca.pt
      Visit us on facebook!
      • sketch3d.deS
        sketch3d.de
        check that "Camera > Perspective" is enabled and the FoV at "Camera > Field of View" is configured to 30 degrees (or higher).
        • Joe WoodJ
          Joe Wood
          No I have the FOV set to 35, thanks anyway, anyone else have any ideas?
          where would I report this bug??
          Joe Wood
          woodsshop.com/
          • jujuJ
            juju
            default FOV differs between Make and Pro versions, it's easy enough to set it the way you prefer though...
            • sketch3d.deS
              sketch3d.de
              @joe wood said:
              ...anyone else have any ideas?
              is the model very small/big in absolute dimensions or very far away from the origin?
              offic. SU Pro Technical Support Form
              • Joe WoodJ
                Joe Wood
                Nope, just an average sized model right at the origin.
                This happens with all my models, now that I've gone with SUp 2016 ..
                thanks for the link Sketch!
                Joe Wood
                woodsshop.com/
                • sketch3d.deS
                  sketch3d.de
                  try if grouping the text elements helps.
                  • Joe WoodJ
                    Joe Wood
                    Yeah already done that, I almost always group all the text in a scene, so I can hide it all for the next scene.
                    Joe Wood
                    woodsshop.com/
                    • Joe WoodJ
                      Joe Wood
                      Just tried a png, exact same missing / smudged text ..
                      I can't zoom out, I'll loose the scene setup.
                      I'm already at max resolution 1920 x 1080.
                      has anyone else reported this issue??
                      Joe Wood
                      woodsshop.com/
                      • sketch3d.deS
                        sketch3d.de
                        try if zooming out helps, if yes you may compensate this by enlarging the export resolution and cropping the white space away with your image editor.
                        btw, export to losless PNG format instead of lossy JPEG w/ artefacts at hard contrasts or ol' TIFF.
                        • sketch3d.deS
                          sketch3d.de
                          the raster export format has obviously nothing to do with this issue...
                          ... the max. raster export resolution has nothing to do with the screen resolution but is configured during the raster export (see button "Options..." in export dialog).
                          zooming a bit out and cropping the resulting raster image will likely result in a similar scene setup... but as always, it's up to you.
                          • Joe WoodJ
                            Joe Wood
                            Sorry, I don't understand, don't even know what Raster means, I tried zooming out a bit,
                            and the same problem. This is happening with almost every image with text I export from 2016.
                            Joe Wood
                            woodsshop.com/
                            • pbacotP
                              Have you posted a file here, in which this occurs? I'd be curious what result I have. I don't do a LOT of this sort of export with text, but never seen a problem-- that is if the text is positioned correctly in the view, it comes out OK AFAIK.
                              • Joe WoodJ
                                Joe Wood
                                It's happening with every model I have PB, some created in SUp 5, but all of my newer 2016 models too, I wrote to support, what a drag.
                                Joe Wood
                                woodsshop.com/
                                • Joe WoodJ
                                  Joe Wood
                                  Here's that one model I've been posting images from,
                                  top left text disappears and bottom left gets smudged.
                                  Example Corner_Connections.skp
                                  Joe Wood
                                  woodsshop.com/
                                  • G
                                    Garry K
                                    Sketchup 2016 Pro
                                    Windows 10
                                    • bazB
                                      baz
                                      Weird, I get the same result as Joe...
                                      • pbacotP
                                        Nope. Like Garry, I'm not getting it on PNG and JPG.
                                        But for a PDF both leader-less text objects are disappeared!
                                        • G
                                          Garry K
                                          Joe
                                          I very rarely use 2D export. Instead I use a screen capture program called faststone. Best 20$ US that I've spent in a long time. They have a 30 day free trial. Check it out.
                                          I use it because it can do everything from videos to various image specs and editing.
                                          Essentially it is WYSIWYG. It is Windows only - however - from what I've seen you do have Windows.
                                          (www.faststone.org)
                                          • Joe WoodJ
                                            Joe Wood
                                            I need to export at a higher rez, then resize, to cut down on the jaggies, no?
                                            I export these jpg plans pages at 6,000 pixels wide, then resize to 2,000.
                                            If I use another format then jpg, like tif, at a lower rez and till get rid of the jaggies? (won't solve my present problem though)
                                            Joe Wood
                                            woodsshop.com/
                                            • 2 / 3
