    Engineering Template in SU Make 2016
    7 Posts 3 Posters 1.1k Views 3 Watching
    • E
      elmchris
      Can anyone tell me if SU Make 2016 should have the Engineering template? I downloaded and installed SU 2016 and do not see that template in he list of styles. Thanks
        Which template are you referring to specifically? There isn't one that is explicitly called Engineering Template. There isn't one with that name in SU2016 Pro either. What are you looking for that you would expect from this template? You can make your own template and call it "Engineering Template" if you wish.
        • E
          elmchris
          I was looking through tutorials and came across one in which the author stated to use Engineering Style. He was using SU 8 however. Here is a video stating to change to Engineering style. It 26 seconds into the video...Thanks https://www.youtube.com/watch?v=JC8sYjN1vtY
            There's only the Model Unit > Engineering in the Model Info dialog....
            But that limits you to imperial measurements.
            SketchUp 8 and prior version had an Engineering template. This was before 3D Printing got popular. Under Google the Construction Templates weren't available.
              You'll notice Matthias said "Style" not Template. They are different things. The Engineering style is no longer included in the default styles but you can edit the style you are using under the edit tab. Set Profiles to 1, turn off the endpoints and extensions. Then set the Background color to white.
              Matthias made those changes because he chose an Architecture template when SketchUp started.
                True dat.
                I just remembered the Engineering Template and felt compelled to confse things further.... πŸ˜„
                  @rich o brien said:
                  ...and felt compelled to confse things further.... πŸ˜„
                  Being stingy with the letters again, too. πŸ’š
                  @elmchris, you could make the style and Units changes as desired and save as a default template so you don't have to make those changes every time you start a new drawing.
