    Hourglass Helix?
    24 Posts 5 Posters 4.8k Views 5 Watching
    • B
      BallBearing
      Ok! I think I made it with the Curviloft.
      SketchUp, 3D printing stuff and more:
      http://www.youtube.com/user/CinemaTablet
        • BoxB
          I'm a bit lost, are you asking a question?
          Could you explain your question better with some images perhaps.
          Pilou has given you a great helix tut.
          I'll add mine in case it is of interest.
          https://media.giphy.com/media/l2QZZEUFLToXcgRwc/giphy.gif
          • B
            BallBearing
            Perhaps this image explains what I wanted and managed to make, with two normal helices + faces made with Curviloft cutting a path to a hourglass shape (or two curved cones). Sadly this is not enough what I need. I need helix going and growing up through the certain points (second image). Is there a way to make helix go using certain points or first pitch, second pitch etc.? Or I'm not sure if stitching helices with different pitch one over other makes a continuous grow? Like that half circle helices do not grow up correctly.
              This isn't really all that difficult. Draw a lathed shape with the curve you're after. I used a Bezier curve and Follow Me. Make the shape a component or group and show hidden geometry. Then use the Line tool to draw the helix. Draw from intersection to intersection.
              The number of turns and the smoothness of the helix will determine the numbers you use for the sides of the circular path and the segments in the Bezier curve. In the interest of time, I used 20 sides onthe circle and 60 segments on the Bezier curve. This gives 3 turns in the helix.
              • B
                BallBearing
                Hmmm. That's a nice way from point to point. But I need a variable pitch helix, so I cannot easily use intersections. 73.2mm -> 74mm etc. If there exists something like img.2 here down...? Points and pitch between them .
                  Why didn't you ask for a varying pitch in the first place? Do you want BOTH varying pitch AND the "hour glass" shape?
                  Give real specific dimensions.
                    Helix Along Curve πŸ˜‰
                      See my previous old post for draw your curve! πŸ˜‰
                      Some tricks inside!
                      http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=49558#p445823
                        http://www.drawmetal.com/download πŸ˜‰
                        Build the Volume first then deform it by Fredo Tool!
                        • Fredo Scale Box Scaling (+SHIFT No Uniform) + Box Tapering + Box Stretching (+ F4) and you can draw any sort of volume helicoidal!
                        http://s6.postimg.org/xs4tm0mmp/grillage.jpg
                        • B
                          BallBearing
                          Perhaps I managed to make the correct helix, but sadly now I cannot get it to work with the curviloft correctly. First image helix. Second helix made of half circles. Not good, but the closest what I have.
                          • B
                            BallBearing
                            Perhaps I found the correct option for curviloft. I have to think and try more...
                            • B
                              BallBearing
                              Edit: Uh! I was fool or too tired. I do not need to make the cut. The helix path is already hourglass shape and pitch growing and valid for curviloft.
                              Sorry! First I needed just the hourglass helix and then I found that I need variable pitch also. Yes I need both. Thank you pointing to the Helix along curve! At first it looks like that plug-in can do the thing If I do a one variable pitch helix using different length lines, then copy and scale it down 0.5 red&green axis. And then make curviloft faces along the paths cutting the hourglass and leaving a path which is a helix with hourglass shape and variable pitch.. I will try.
                              hmm what is the degrees option in Helix along curve plug-in...?
                              • B
                                BallBearing
                                Edit: Uh! I was fool or too tired. I do not need to make the cut. The helix path is already ok hourglass shape and pitch growing and valid for curviloft.
                                Now thinking how to get the the path or shape helix turn tighter or more along the hourglass body, perhaps just more sections? I have to learn better this helix along curve plug-in.
                                  Maybe this can help you! πŸ˜‰
                                  Loft along a Vector by the genious Projection By Didier Burr
                                  Joint PushPull Interactive by Fredo
                                  http://s6.postimg.org/guo6j56s1/Mini_tuto.jpg
                                  ...or Curviloft! πŸ˜‰
                                    πŸ˜„
                                    http://s6.postimg.org/whffwikk1/vers.jpg
                                    • B
                                      BallBearing
                                      Thanks! I check them. I still have about 0.2mm "error" on radius with curviloft.
                                      • C
                                        CAUL
                                        Maybe Flowify can be of help here.
                                        The spiral can be turned into a quad surface with "Extrude Edges by Vector" from TIG's extrusion tools. Just extrude the spiral edges along the blue axis up and down. After that the worm can be mapped onto the quad surface using Flowify.
                                        A problem here is that since the spiral's radius is variable the vertex normals in the quad surface does not extend radially from the spirals center. This means that the distance between two revolutions in the spiral is not retained at the tip. The difference in this case is <1%.
                                        In the upcoming version of Flowify (2.0) it will be possible to explicitly set the normals at each vertex. The image below shows the setup. All normals extend radially from the spirals center and this aligns the geometry at the tip with the geometry at the base between revolutions. The last image shows the difference in a section cut for three consecutive revolutions.
                                        Flowify 1.1 setup
                                        Flowify Result
                                        Flowify 2.0 (not yet released) setup
                                        Difference between Flowify versions
                                        Flowify Setup skp
                                        • B
                                          BallBearing
                                          There's another thing too. The tooth has to point to the center of the worm wheel. So I have tried curviloft follow spiral path and tooth faces oriented to the center. No success yet. So the path is not correct then.
                                          • C
                                            CAUL
                                            This is an intriguing problem. Here's another take.
                                            The first image is a flat setup for flowify and a flowify output which is a gear and a profile for the worm.
                                            The next image shows a setup for a tiny custom script (attached below). The script takes two groups as input:
                                            1) A group with a single edge representing the rotation axis of the
                                            main gear.
                                            2) A group containing the worm profile AND a lonely edge representing the worms rotation axis.
                                            The script itself has two internal parameters at lines 49 and 50. Those are the number of cogs on the main gear and the number of circle segments for the worm.
                                            To run the script, open it in a text editor, set the parameters and save. Then select the two input groups, copy and paste the code into the ruby console and press enter. The result for 48 cogs on the main gear and 192 segments in the worm can be seen in the last image. The output is just profiles that have to be merged manually with Curviloft.
                                            wormScript.rb
                                            WormIII.skp
