    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 958.4k Views 172 Watching
      gepponline77
      Maybe I didn't explain well my problem.
      I know how to use joints!
      The problem is that if use hinge, or motor or slider, all work well. I simply have to drag my object to move it.
      If i use piston or servo, in Sketchyphysiscs, when i press play, a popu control panel with a slider appear and it allow me to mov emy object.
      With MS, nothing appear and i can't move my object
        PituPhysics
        I'm sorry, I misunderstood. In the MSPhysics at present there is no "Controller Panel".
        Anton is likely to put into it as well. For the time being, you can control the keyboard.
        • soloS Offline
          @sekramer10 said:
          Hello,
          Does this work on SU 2016 64bit ?
          From the requirements section of the website:
          http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/README.md
          SketchUp 6 or later. SU2016 64bit is recommended!
            gepponline77
            Could you please explain me how?
            For example, if i place a servo joint connected to an object, what should I do to move that object in play mode?
              PituPhysics
              Write this codes into Joint / "Controller":
              rightx         Left - right arrows
              righty         Up - down arrows
              leftx          A - D
              lefty          W - S
              key('1')       0-9
              key('a')       A-Z keys
              key('enter')   All the Windows function keys. (lctrl, rctrl, space, backspace, etc...)
              key('numpad1') 0-9 Right numpad keys
              key('+')       Numpad operations (+, -, *, /)
              key('lbutton') Mouse keys (mbutton, rbutton, xbutton1, xbutton2)
              get_var('variable')   ... for script.
                gepponline77
                Sorry but for me is really unclear.
                What should i have to write?
                Controller field is a single line field.
                So eventually i can insert only a row of what you have write above.
                I paste "rightx Left - right arrows" in the controller field, press the play button and press left and right arrow but nothing happen.
                Of course is my fault.
                But could you gave mme an example step by step of using a piston joint?
                  PituPhysics
                  I made an test model: piston test.skp
                    PituPhysics
                    I made an test model: [attachment=0:1hwdkrag]<!-- ia0 -->piston test.skp<!-- ia0 -->[/attachment:1hwdkrag]
                    Succeeded solve?
                    • F Offline
                      faust07
                      Very good example and important notes above. It works.
                        Anton_S
                        @faust07 said:
                        Great news, Anton. Short question: I want this Topic not bloat with simple examples and tests. Should I better open a new topic as entitled "MSPhysics examples and tests"?
                        Yes, I can see that you already did. However because there aren't many tutorials on how to use MSPhysics and because its generally not done, the topic could be quite empty for a while, but don't worry once the project is done, I'm gonna help you fill it in.
                        Yep, I'm planning to put in all the feature of SketchyPhysics and more.
                          gepponline77
                          Thanks PituPhysics, now I can move my objects.
                          Still some doubts about parameters (like controller and min-max position)
                          But it start to be clearer
                            pnickles
                            SU2016 Plugins folder location:
                            C:\Users[USERNAME]\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                              PituPhysics
                              Just write this: %APPDATA%\SketchUp\SketchUp 2016\SketchUp\Plugins
                              The USERNAME is will be automatically detected. Or here is shortcuts 2014+ in zip archive:
                              Plugins Shortcuts.zip
                                Anton_S
                                Announcing 0.6.0. See change-log here: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                • F Offline
                                  faust07
                                  Usefully new options, functions and joints!
                                  What is meant with the Sliders Control Panel? A control panel for the slider joint in MSPhysics UI or a Joint Controller Panel with slider input similar to SP (couldn't find it...)?
                                    Anton_S
                                    Faust, the control panel displays only when necessary, that is when there are actually slider controllers. The control panel will display in the lower-right corner when simulation is started. Here is an example that uses a slider controllers.
                                    Arrow keys to drive and slider to raise suspension.
                                    • jenujacobJ Offline
                                      jenujacob
                                      i know what i am gonna ask may be way too optimistic but can we have something similar to whats shown here? πŸ˜„ love the way u can paint over a couple of selected objects and just 'drop 'em'!
                                      http://hocuspocus-studio.fr/tools/product/physx-painter/
                                        So many times I wished for a tool like that!
                                          PituPhysics
                                          Super the new, transparent Control Panel. πŸ‘
                                            Anton_S
                                            Announcing 0.7.0: Change Log
                                            Here is a little turret with particle effects.
                                            turret.skp
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 46
                                            • 47
                                            • 35 / 47
