    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 412.4k Views 154 Watching
    • Y Offline
      yuletide
      Any plans to update this? Or suggestions for other ways to get this slice model at section functionality? Can't get it to work with Sketchup 2015 (on mac) ๐Ÿ˜ž
        snoodles1990
        I have tried to download this plugin (inserted the Zorro2.rb into my system files: Program Files (x86)_Google_Google SketchUp 8_Plugins) without any luck. After I have uploaded it into my program files I should expect to see "Zorro" show up in my Sketchup "Tools," however, it does not show up? Any suggestions?
        I have tried to reboot sketchup and my computer. I don't know what else I can do.Thanks for any and all help.
          Where did you get the file you downloaded? The one that is available here on SCF comes as an rbz file, not rb. Do not put rbz files into the Plugins folder. After downloading the rbz file, open SketchUp and go to Window>Preferences>Extensions. Click on Install Extensions... Navigate to the location where you saved the file, select it and click on the affirmative answers.
          Better, install the Sketchucation Plugin Store plugin that way and use it to automatically install the plugin.
            snoodles1990
            Thanks this did it. This is the first .rbz I have downloaded to date. Thanks for your help.
            • H Offline
              Heda27869415
              Hi Whaat i seem to be having a bugsplat problem with my zorro2 plugin, i also really need to use it asap, please can you help me. oh and thank you for such an amazing tool.
              • W Offline
                Whaat
                What version of SketchUp are you using?
                • F Offline
                  fungchi
                  i was depressed before i know this plugin! i already installed sectioncutfaces but there's no option for slice the model. i'm stuck and you really made my day!! Thankyou so much! ๐Ÿ‘
                  • O Offline
                    olivarchi0
                    fabulous, thank you ๐Ÿ˜„
                      katecheung
                      where can i download this great program?
                        Search the SketchUcation PluginStore - linked in the menu above...
                        • 2 Offline
                          2agostosanthi
                          ya descargue el zorro, pero ahora no se como lo encuentro en google sketcUp
                            It's in 'Tools'...
                            Have you read the PDF manual?
                            Estรก en 'Herramientas' ...
                            ยฟHa leรญdo el manual en formato PDF?
                            404 Not Found
                            (sketchucation.com)
                              Kuchcok
                              Hi, I have downloaded and installed plugin as said at the first page. Works 100% (W7, SU2016pro). I would like to thank you for great saving of time ๐Ÿ‘
                              Also if there will be some day an update, really helpful would be if plugin can also cuts only visible groups ... now I have to copy and move away from entire model what I want to cut and put it back when done. If I just turn off the layers, for example walls, terrain, windows, etc. and I can "play" only with roof tiles with no need to copy something... itยดs just an opinion
                              It is ๐Ÿ˜Ž and very useful plugin!
                              Cheers mate
                                Zorro2 cuts objects in the model's active_entities context, it also cuts into any nested components/groups in that context is the option is chosen
                                So to cut only part of your model make a temporary group of the objects you wish to cut.
                                Edit that group and use Zorro2 within that edit's entities context.
                                Now anything outside of the group remains unchanged.
                                Explode the group when you are done - if desired...
                                In the attached image I cut a component [which is just a specialized kind of group] and deleted the bottom part - note how outside of the context nothing is affected...
                                  melu
                                  alguien me podria explicar como descargarlo ?
                                    First page of this thread:
                                    Then:
                                    It's even better if you install the Sketchucation Plugin Store tool and use it to install Zorro2 and other extensions.
                                    • W Offline
                                      Whaat
                                      That is so kind of you to say! You are most welcome. Perhaps it is time to take this Project out of beta... ๐Ÿ’š
                                        DragonCF
                                        wooooow! its so perfect~
                                          Modixxs
                                          Wish it could also slice in curves and rounded lines...
                                          • ArckadiaA Offline
                                            Arckadia
                                            I was quietly working with my sketchup friend when the need to cut shapes became a major problem ๐Ÿ˜ฎ . But suddenly in the distance a galloping rider appears in the night and with the tip of his awesome super mega cool PLUGIN Zorro2, all my problems were gone. A thousand thanks Zorro ๐Ÿ‘ ๐Ÿ‘
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
