    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 446.9k Views 154 Watching
    • N
      Nilez83
      Thanks TIG!
        OK. πŸ˜„
        That issue should have never happened in the first place, and hopefully it won't recur in the future [GΓ‘bor !]
        Incidentally you should NEVER have a Plugins folder for v2014 inside the its 'Programs Files' folder-path.
        It should default to each Users' Plugins folder - as Dave explained.
        There is another potential 'shared' Plugins folder that you can make in the ProgramData tree... BUT do not make this unless you really really want to 'share' plugins...
        All Plugins AutoInstall into the User's Plugins folder anyway - using the native installer.
        The SketchUcation PluginStore's equivalent AutoInstaller will prompt for an alternative destination, but only IF it'd been defined and in $: [Fredo's AdditionalPluginsFolder tool allows you to specify alternative custom-plugins folders BUT is only necessary if you need them - e.g. you are on a commercial/educational network with restricted permissions, or you have several computers and want to share one folder via DropBox, or similar...]
        • B
          beardj0dj0
          GOODDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
          • I
            Ibragol09
            I'm a newbie
            I downloded Zorro that i found in page 1 of this thread
            So i copy the file .rb in /library/app support/sketchup ......
            So it don't work on my sketchUp 2013 and 2014 for MAC!...
            However CutFace work on it...
            What wrong?
            Sorry for my brutal english....i'm italian ...
            Bye bye
              Why not get the RBZ version from the PlugniStore ?
              http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=zorro%26amp;submit=%3F
              Then use the v2013/v2014 Preferences >Extensions > Install button to properly install the contents into the correct Plugins folder.
              The correct Plugins folder is also found using the Ruby Console command: Sketchup.find_support_file('Plugins')
              If you have manually installed files elsewhere remove them... πŸ˜•
                DADAZ
                Very nice zorro 2..... thank very for this....
                • masterpaulM
                  masterpaul
                  This plugin doesn't cut objects into separate components? It just slices through the model?
                    @masterpaul said:
                    Right. It just does what it says in the first post of the thread. πŸ˜’
                    • BoxB
                      I have a banana that won't cut bread no matter how hard I try.
                        Yer holding yer tongue wrong. πŸ˜„
                        • masterpaulM
                          masterpaul
                          @dave r said:
                          @masterpaul said:
                          "- Cutting through nested components results in creation of many unique components"
                          Yeah it says it creates new components in nested components, but it doesn't create new components on my PC. That's why I asked.
                          SU 2014, windows 7.
                          • BoxB
                            It's not quite what that means.
                            Zorro will make a component unique when it cuts it. Not make separate unique components from the cuts.
                            Make a simple component, make a copy of it and use ctrl with zorro to slice the second one. Look at the entity info and you will see it has changed the name therefore making that a unique component.
                            Click me to animate
                            • masterpaulM
                              masterpaul
                              @BOX
                              Cheers for clearing that up, I thought it was an error originally. Guess will have to take that extra step.
                              Is there an alternative that divides components into separate components after cutting?
                              • BoxB
                                Yes, S4u Slice, not free, but very cheap.
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59170
                                  reauen
                                  WHAAAAAAAAT!! this is amazing!! i need to hug you!
                                  thanks!
                                  Especially slice model at section is freaking awsome!!
                                  πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                    jtbrockmeyer
                                    I am trying to install this in a Mac with the SU 2014 version. I am not certain where/how to install the file i downloaded "Zorro2_v2.0_beta.rbz".
                                    I have read all the responses and I still can't seem to get it to work.
                                    Can anyone help?
                                    Thanks in advance.
                                      If you have downloaded the RBZ file, go to the SketchUp menu, click on Preferences>Extensions and then the Install Extension button. Navigate to where you saved the file, select it and click on Open. Then click on all the affirmative responses. Close the Preferences window. Done.
                                      You really ought to get the Sketchucation Plugin Store tool and use it to auto-install plugins.
                                      • E
                                        efm1102
                                        Awesome tool! Thank You.
                                        • Y
                                          yuletide
                                          Any plans to update this? Or suggestions for other ways to get this slice model at section functionality? Can't get it to work with Sketchup 2015 (on mac) 😞
                                            snoodles1990
                                            I have tried to download this plugin (inserted the Zorro2.rb into my system files: Program Files (x86)_Google_Google SketchUp 8_Plugins) without any luck. After I have uploaded it into my program files I should expect to see "Zorro" show up in my Sketchup "Tools," however, it does not show up? Any suggestions?
                                            I have tried to reboot sketchup and my computer. I don't know what else I can do.Thanks for any and all help.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
