    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
      @desertraven said:
      Is this a general sketchup quirk? I was assuming the plug in would only align the UW's accordingly and not chop up the texture image? ?
      Am I missing something ? Anybody else ever had this issue?
      Kind regards, Olav
      This depend on the exporter. SketchUp support UVQ - as oppose to just UV. The Q value is used for perspective mapping. Not all applications or file format support this.
      To preserve the visual appearance some exporters will then generate new textures for faces with perspective mapping.
      • DesertRavenD
        DesertRaven
        Kind regards, Olav
        So basically, there is no solution?
        I'd like to have only one texture so that I can import this into Unity and apply other maps, derived from the bitmap used, like normal maps displacement maps etc... 😢
        simplicity is the ultimate sophistication
          Not sure what format you are exporting to, but one can at the expense of some visual deviation convert UVQ to UV. Depending on the mesh the visual difference might not be that noticeable.
          • DesertRavenD
            DesertRaven
            FBX, and yes, it's a quad mesh.
            • DesertRavenD
              DesertRaven
              Dead end?
              • fredo6F
                That's bascally what ThurPaint is doing. To obtain the result with a quadmesh, it does change the U, V and Q values, as you need the perspective distortion to render the quads properly.
                As thomthom said, this may cause a problem in the exporter.
                I have no solution for that, sorry.
                  AcesHigh
                  @desertraven said:
                  Dead end?
                  why don´t you try 3DS, OBJ, DAE or other format before giving up? Maybe other formats won´t have the same problem.
                  alternativelly, you are exporting FROM Sketchup. I know there are some programs that can open Sketchup files and then you can save them as something else. I never used those programs nor I know if the end result would be different, but maybe you should try (IF there is a trial version) SimLab exporter plugin or SimLab Composer... it seems SimLab Composer can work with several formats including Sketchup. So MAYBE you can open your sketchup file in SimLab Composer and export as FBX and the result MIGHT be different...
                    sreejithjayaram93
                    **How do you use thru paint to texture a plain flat circular path?? I Keep getting an error in the quadmesh UV mode ... Ive attached the screen shot for the same.. 😞
                    Thanks in advance... 😄**
                    here it is...
                      rv1974
                      @desertraven said:
                      Dead end?
                      Take sketchuv of Whaat and do 'triangulate'. 3ds will be exported with one texture.
                      • fredo6F
                        @hsrhdrehre5654654 said:
                        Hi, im really happy about this tool, but i have a slighty problem.
                        Is there any way to disable the "auto join" feature???? i mean, when im painting, everything is great, but when two paths join, the texture scale/direction gets messed up and the whole thing looks really bad. SO i need to paint from scratch in those zones and continue painting. Curious thing is, before thrupaint treats the painted zone, everything looks great, but as i said, when you release the mouse button to join two patchs, everything mess up. If i couuld just deactivate that feature... it will be perfect. Other wise, there are always seams and different parts in the painted texture 😕
                        Do you have an example. I am not sure to understand what is the "auto-join" feature and the junctions of 2 paths.
                        • H
                          hsrhdrehre5654654
                          The problem i probably dont know how to explain better in english. When you are painting, the way thrupaint works is you make a selection of the zone you want to paint (holding themouse while you paint) and when you release the mouse, thrupaint "tries" to correct the texture scale/position in some faces. This produces terrible results in some faces affected by the painted zone, and the whole thing is useless.
                          I dunno how to explain it better, i will try to post a screenshot later.
                          Its not something weird, im pretty sure everyone is having this problem. At least, im having in using it on complex meshes modelled with artisan. My guess is, in a low-polygon model, you dont get to notice it, but when you paint extensive zones happens very often.
                          • H
                            hsrhdrehre5654654
                            Is there any way to disable the "auto join" feature???? i mean, when im painting, everything is great, but when two paths join, the texture scale/direction gets messed up and the whole thing looks really bad. SO i need to paint from scratch in those zones and continue painting. Curious thing is, before thrupaint treats the painted zone, everything looks great, but as i said, when you release the mouse button to join two paths, everything mess up. If i couuld just deactivate that "feature"... it will be perfect. Other wise, there are always seams and different parts in the painted texture 😕
                            • H
                              hsrhdrehre5654654
                              Ok, so here is an example of the problem ->
                              The only thing to avoid this, is to press CTRL (force re-paint) and start over, but you will lose the uv position and the texture will not be continous. If i try to pick a sample of the material/uv coordinates and try to kept the texture continuity, it wont work either.
                              Is there any way to avoid this? thanks in advance.
                                rv1974
                                I'm struggling (unsuccessfully) to get the desired result (see the bottom variant- no distortions, continuity, aligned to the edge, one click solution)
                                Is it possible with this tool?
                                If not, may this mode be added?
                                Thank you.
                                Edit: Actually, there IS a defect with the bottom variant (BTW it was made by default with PB)- sometimes it can't keep contiguity in corners- it applies UV's anew each sector).
                                kkk.zip
                                • romboutR
                                  rombout
                                  In the settings there is a option for thrupaint to activate it when native tools are used. Does this mean thupaint popups when we use the bucket tool? If so on mac using su2015 it doesnt show?
                                  • fredo6F
                                    There is a icon, showing letter A, in the toolbar for auto launch.
                                    Note that if you click again on the toolbar icon of ThurPaint, you will launch the native Bucket tool. Same with shortcuts (say B). If you are in Auto mode, then typing B twice will launch the native bucket tool.
                                    • romboutR
                                      rombout
                                      Thanks I'll check if I can find that. I thought that option being checked already would launch thrupaint together with bucket.
                                      • romboutR
                                        rombout
                                        Aha, got it. i was looking in the main toolbar. thanks!
                                        Its still a bit tiny on mac but the retina settings do work, i cant set them any bigger right?
                                        • Z
                                          Zekiuar
                                          Thank you
                                          • romboutR
                                            rombout
                                            i got a question about using the visual editor. Im using this on mac su2015.
                                            When i want a texture to scale in U and press alt (option) left click i get the editor. When i try to use the sliders for the U and V, im having a hard time getting them to actually do something. Most of the time i need to click a couple before i get it to work.
                                            Im working on macbook pro mid 2015
                                            How can i use this editor with the U and V sliders without the texture getting skewed by QuadUV mesh option?
                                            • 16
                                            • 17
                                            • 8 / 17
