    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 70.1k Views 40 Watching
      Catalyst
      Thanks for this great plugin.
      When using the assembler inside a component, the assembler does not respect the component's axes.
      I'm using SU Pro 2016
      • E Offline
        eselick
        Hi Whaat
        My assemblies are getting complicated and I wonder if there is any way to automatically combine them?
        This would make it much easier to get amazing results since they could be created in a modular fashion and debugged and re-used more easily.
        If this cannot be done, can you think of any way to get a report on the assembly that would contain a listing of components and the dialog attributes such as elevation etc.?
        Thanks again for all the fun.
        Elliot
        • W Offline
          Whaat
          @eselick said:
          Hi Whaat
          Elliot
          Sorry, I am not understanding what you mean by 'combine them'. can you elaborate?
          • E Offline
            eselick
            Hi Whaat
            By combining I mean adding two pre-existing assemblies together. These would be assemblies that had been created to be used together.
            I just made a combination exterior siding and stud wall. I dumped the siding assembly into a model where the wall assembly was open. I then added profiles and components from the siding assembly in the model to the wall assembly. I used eye dropper tool which did save some time.
            But I'm lazy and would have preferred to the use an eyedropper like tool with a "+" symbol that would have just "combined" the second assembly into the first with one click. This would have saved me some quite a bit of work and been guaranteed to be error-free.
            Hope that explains it
            Elliot
              French Manual of Profil Builder 2! πŸ˜‰
                TBoy
                When I open library folder, only last row of profiles can be selected, no matter how long is the table of thumbnails-only last row. Anybody to tell me how to resolve this ?
                Trial version installed on 64 bit Windows8.1, same on Windows 10-64 bit.
                • W Offline
                  Whaat
                  That is a strange report. Can you please open the Ruby Console Window (Window->Ruby Console) and then try to select the profile thumbnails in the upper rows. Then, let me know if you see any error messages.
                  Also, could you please ZIP your library folder and send to me for testing? My email address can be found here (see Customer Support):
                  http://extensions.sketchup.com/en/content/profile-builder-2
                  • O Offline
                    optimaforever
                    Hello whaat,
                    Do you think there's a way to program PB to do something like this?
                    https://www.youtube.com/watch?v=V7vshlm06EE
                    It's book manager for 3dsmax; it work with selections of polys but in PB it could be replaced by smart paths.
                    Is there a way to random seed components inside an assembly?
                      TBoy
                      Hellow whaat,
                      I found the reason - I was testing on some kind of portable version of SkethcUp.
                      In installed Sketchup everything is OK.
                      As a new user I'm testing a lot of plugins. ProfileBuilder2 is one of the best (possibly most useful). Professionally made, adding additional functionality to SketchUp. Congratulations for your work.
                      • O Offline
                        optimaforever
                        Hello Dale,
                        To create an assembly for this bench, is there a way to extrude a multi-profile for the wooden lattice (a profile composed of several discrete surfaces, not linked between them) or have I to add x multiples of the same square profile each moved and rotated accordingly to get the complete shape?
                        http://img.archiexpo.com/images_ae/photo-g/54663-4962911.jpg
                        Thanks in advance,
                        • O Offline
                          optimaforever
                          Ok. done.
                          Yet I'd like to have an option to randomize UV tiling without having to group all the profiles, explode them and use Julia's UV depatternize script...
                          It took me a while to get the positioning of each profile right.
                          it has to be done manually.
                          I'd have liked to have the possibility to place the profiles along a predefined shape (spline) with the option of aligning the profile along the shape, and parametric interdistance.
                          It would be cool to have the possibility of interrupting the profiles (in the case of this bench, I'll have to cut the profiles with su4you's incredible slice to create some realistic lengths (there is no manufacturer who can make wooden profile in that shape and that length) 😎
                          • W Offline
                            Whaat
                            @optimaforever said:
                            Ok. done.
                            Nice work! Thanks for the suggestions!
                              rv1974
                              Whaat, its rather tedious the dig into the context to edit the path. Could it 'feel' the path regardless the context?
                              P.S. Are you planning some updates\new versions in the near future?
                              • Bob JamesB Offline
                                Bob James
                                Off Topic Nit Pick
                                Isn't Slice made by TIG? 😎
                                  rv1974
                                  there are different tools. beware of su4you's one- it's extremely addictive, simply genius.
                                  • O Offline
                                    optimaforever
                                    @bob james said:
                                    Off Topic Nit Pick
                                    TIG's "sliceR" I think.
                                    • W Offline
                                      Whaat
                                      Actually...yes. I am nearing the release of a significant update. Stay tuned πŸ˜„
                                      • jujuJ Offline
                                        juju
                                        Do tell!
                                          rv1974
                                          1. Multiple not connected edges as one path.
                                          2. Move\scale\rotate randomization for assembly parts.
                                          3. Easy path access.
                                          I'd buy the upcoming version 3 times for those ones 😎
                                          • W Offline
                                            Whaat
                                            @juju said:
                                            Do tell!
                                            very soon...I'll probably be posting a promo video within the next few days.
                                            • 11
                                            • 7 / 11
