    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 70.1k Views 40 Watching
      rv1974
      Damn.. I actually use it but in this case it didn't popped up in my brain.
      You should emphasize this amazing feature in you promotions!
      Many thanks!
        rv1974
        Hm.. We've got problem on curved areas though.
        PB applies the same texture coordinates on every segment. 😒
          rv1974
          ..Meanwhile I found partial workaround:
          1.Select curved areas
          2.Apply tube mapping
          3.Triangulate to eliminate 100500 materials after export.
          Could this issue be addressed in future?
            Catalyst
            Thanks for this great plugin.
            When using the assembler inside a component, the assembler does not respect the component's axes.
            I'm using SU Pro 2016
            • E Offline
              eselick
              Hi Whaat
              My assemblies are getting complicated and I wonder if there is any way to automatically combine them?
              This would make it much easier to get amazing results since they could be created in a modular fashion and debugged and re-used more easily.
              If this cannot be done, can you think of any way to get a report on the assembly that would contain a listing of components and the dialog attributes such as elevation etc.?
              Thanks again for all the fun.
              Elliot
              • W Offline
                Whaat
                @eselick said:
                Hi Whaat
                Elliot
                Sorry, I am not understanding what you mean by 'combine them'. can you elaborate?
                • E Offline
                  eselick
                  Hi Whaat
                  By combining I mean adding two pre-existing assemblies together. These would be assemblies that had been created to be used together.
                  I just made a combination exterior siding and stud wall. I dumped the siding assembly into a model where the wall assembly was open. I then added profiles and components from the siding assembly in the model to the wall assembly. I used eye dropper tool which did save some time.
                  But I'm lazy and would have preferred to the use an eyedropper like tool with a "+" symbol that would have just "combined" the second assembly into the first with one click. This would have saved me some quite a bit of work and been guaranteed to be error-free.
                  Hope that explains it
                  Elliot
                    French Manual of Profil Builder 2! πŸ˜‰
                      TBoy
                      When I open library folder, only last row of profiles can be selected, no matter how long is the table of thumbnails-only last row. Anybody to tell me how to resolve this ?
                      Trial version installed on 64 bit Windows8.1, same on Windows 10-64 bit.
                      • W Offline
                        Whaat
                        That is a strange report. Can you please open the Ruby Console Window (Window->Ruby Console) and then try to select the profile thumbnails in the upper rows. Then, let me know if you see any error messages.
                        Also, could you please ZIP your library folder and send to me for testing? My email address can be found here (see Customer Support):
                        http://extensions.sketchup.com/en/content/profile-builder-2
                        • O Offline
                          optimaforever
                          Hello whaat,
                          Do you think there's a way to program PB to do something like this?
                          https://www.youtube.com/watch?v=V7vshlm06EE
                          It's book manager for 3dsmax; it work with selections of polys but in PB it could be replaced by smart paths.
                          Is there a way to random seed components inside an assembly?
                            TBoy
                            Hellow whaat,
                            I found the reason - I was testing on some kind of portable version of SkethcUp.
                            In installed Sketchup everything is OK.
                            As a new user I'm testing a lot of plugins. ProfileBuilder2 is one of the best (possibly most useful). Professionally made, adding additional functionality to SketchUp. Congratulations for your work.
                            • O Offline
                              optimaforever
                              Hello Dale,
                              To create an assembly for this bench, is there a way to extrude a multi-profile for the wooden lattice (a profile composed of several discrete surfaces, not linked between them) or have I to add x multiples of the same square profile each moved and rotated accordingly to get the complete shape?
                              http://img.archiexpo.com/images_ae/photo-g/54663-4962911.jpg
                              Thanks in advance,
                              • O Offline
                                optimaforever
                                Ok. done.
                                Yet I'd like to have an option to randomize UV tiling without having to group all the profiles, explode them and use Julia's UV depatternize script...
                                It took me a while to get the positioning of each profile right.
                                it has to be done manually.
                                I'd have liked to have the possibility to place the profiles along a predefined shape (spline) with the option of aligning the profile along the shape, and parametric interdistance.
                                It would be cool to have the possibility of interrupting the profiles (in the case of this bench, I'll have to cut the profiles with su4you's incredible slice to create some realistic lengths (there is no manufacturer who can make wooden profile in that shape and that length) 😎
                                • W Offline
                                  Whaat
                                  @optimaforever said:
                                  Ok. done.
                                  Nice work! Thanks for the suggestions!
                                    rv1974
                                    Whaat, its rather tedious the dig into the context to edit the path. Could it 'feel' the path regardless the context?
                                    P.S. Are you planning some updates\new versions in the near future?
                                    • Bob JamesB Offline
                                      Bob James
                                      Off Topic Nit Pick
                                      Isn't Slice made by TIG? 😎
                                        rv1974
                                        there are different tools. beware of su4you's one- it's extremely addictive, simply genius.
                                        • O Offline
                                          optimaforever
                                          @bob james said:
                                          Off Topic Nit Pick
                                          TIG's "sliceR" I think.
                                          • W Offline
                                            Whaat
                                            Actually...yes. I am nearing the release of a significant update. Stay tuned πŸ˜„
                                            • 11
                                            • 7 / 11
