    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 82.7k Views 40 Watching
    • E Offline
      eselick
      Hi Whaat
      I'm wondering if you are aware of the problems that I and many others who are on Windows 10 are having when we try to download the Trial version of PB 2.
      A few seconds after the download dialog loads Sketchup crashes, usually with no error message or only a Windows, "this program has stopped working ..." message.
      All of this is quite fully documented at the Sketchup forum:
      http://forums.sketchup.com/t/extension-warehouse-download-attempt-crashes-su/18869/27
      Hopefully you can check it out and help get it fixed so that we can have a look at PB2.
      Elliot
      • W Offline
        Whaat
        @eselick said:
        Hi Whaat
        Elliot
        Yes, thank you for the report. I am aware of the issue and the SketchUp EW team is working to help resolve this. I have made a change to the EW PB2 page. Please try again to see if the issue has been resolved.
        Dale
        • W Offline
          Whaat
          @utiler said:
          Hi Dale, Happy New Year!
          A few queries re: building assemblies and where to use components or not.
          See attached images which I've added questions to each. Cheers, look forward to hearing back ASAP.
          Hi utiler,
          Thanks for the images. I am very aware of the issues you are facing. There is currently no easy way to do what you want. The workaround is to make the fence using two assemblies, one for the posts and another for the fence boards. The one with the fence boards must be created by clicking the center of each post. I am not sure if this makes sense. I hope to make this much easier in a future update.
          • utilerU Offline
            utiler
            Thanks Dale, yes makes sense. I was just hoping to be able to push PB2 a bit that's all.
            Cheers.
            Just Curious...
            • PixeroP Offline
              Pixero
              I'd love to be able to manually exchange a component somewhere and still be able to adjust the curve afterwards.
              • W Offline
                Whaat
                Interesting idea, Pixero! Would you be able to describe a use-case for this feature? Thanks
                • PixeroP Offline
                  Pixero
                  Here is a quick example of one case. There might be ways of doing some thing like this with different start and end components but I think this way would be easier for a lot of cases where you dont know the exact position until after its drawn.
                  • E Offline
                    eselick
                    I'm just getting started with this amazing and wonderful plugin.
                    My problem is that when I save my assembly and then reuse it a new model, one of the components, #2 "Corner" in the original, is missing in the saved Assembly.
                    Here's the original Assembly dialog from the skp where I created it followed by the one that's loaded from the Assembly browser:
                    http://s20.postimage.org/r5bksx08d/Original_Assemblywith_Corner_Component_Before.jpg
                    http://s20.postimage.org/gtz8098j1/Assembly_Missing_Component_After_Save.jpg
                    There are only 3 instead of 4 components in the second one.
                    Ideas?
                    • W Offline
                      Whaat
                      @eselick said:
                      Ideas?
                      Hello eselick,
                      Thank you for the report. Can you please do the following:
                      • Open the Ruby Console and check for error messages when you save and load the assembly.
                      • Send the assembly SKP file to mindsightstudios AT gmail DOT com for me to test
                        rv1974
                        I'm not sure in which topic it should be asked.. Luckily you're the author of both plugins (Profile Builder and Sketch UV.
                        I applied tube SketchUV's tube mapping to the curb generated with PB.
                        As you can see the vertical seams are distorted- they are not perpendicular to the 'U' path (I put the desired look above).
                        Could you advice how to get the desired result with the present tools?
                        And may be it's a good idea to have 'generate UV's' in the PB v.3?
                        • W Offline
                          Whaat
                          Hi rv1974,
                          Before you create the object using PB2, select the desired textured material from the drop-down list in PB2. Then, you should get your desired result automatically. SketchUV applies a different UV mapping scheme than PB2.
                            rv1974
                            Damn.. I actually use it but in this case it didn't popped up in my brain.
                            You should emphasize this amazing feature in you promotions!
                            Many thanks!
                              rv1974
                              Hm.. We've got problem on curved areas though.
                              PB applies the same texture coordinates on every segment. ๐Ÿ˜ข
                                rv1974
                                ..Meanwhile I found partial workaround:
                                1.Select curved areas
                                2.Apply tube mapping
                                3.Triangulate to eliminate 100500 materials after export.
                                Could this issue be addressed in future?
                                  Catalyst
                                  Thanks for this great plugin.
                                  When using the assembler inside a component, the assembler does not respect the component's axes.
                                  I'm using SU Pro 2016
                                  • E Offline
                                    eselick
                                    Hi Whaat
                                    My assemblies are getting complicated and I wonder if there is any way to automatically combine them?
                                    This would make it much easier to get amazing results since they could be created in a modular fashion and debugged and re-used more easily.
                                    If this cannot be done, can you think of any way to get a report on the assembly that would contain a listing of components and the dialog attributes such as elevation etc.?
                                    Thanks again for all the fun.
                                    Elliot
                                    • W Offline
                                      Whaat
                                      @eselick said:
                                      Hi Whaat
                                      Elliot
                                      Sorry, I am not understanding what you mean by 'combine them'. can you elaborate?
                                      • E Offline
                                        eselick
                                        Hi Whaat
                                        By combining I mean adding two pre-existing assemblies together. These would be assemblies that had been created to be used together.
                                        I just made a combination exterior siding and stud wall. I dumped the siding assembly into a model where the wall assembly was open. I then added profiles and components from the siding assembly in the model to the wall assembly. I used eye dropper tool which did save some time.
                                        But I'm lazy and would have preferred to the use an eyedropper like tool with a "+" symbol that would have just "combined" the second assembly into the first with one click. This would have saved me some quite a bit of work and been guaranteed to be error-free.
                                        Hope that explains it
                                        Elliot
                                          French Manual of Profil Builder 2! ๐Ÿ˜‰
                                            TBoy
                                            When I open library folder, only last row of profiles can be selected, no matter how long is the table of thumbnails-only last row. Anybody to tell me how to resolve this ?
                                            Trial version installed on 64 bit Windows8.1, same on Windows 10-64 bit.
                                            • 11
                                            • 7 / 11
