    From roughed out design to real (more added)
    48 Posts 19 Posters 6.8k Views 19 Watching
    • soloS Offline
      First one is a render and the rest are photos. 😄
      • RichardR Offline
        Richard
        @mike lucey said:
        Very clean design there Richard.
        BTW, have you seen,
        'Sustainable home can be built in four days using only a screwdriver'
        Page non trouvée - PopUp House
        PopUp House (www.popup-house.com)
        I'm still reading about the 'patented' system and like what I see so far.
        Mike
        Yeah I have seen it Mike! It's a BRILLIANT system, this display home here uses SIP panels for all the floor, walls and roofing but in probably a more simple install than POP-UP.
        The actual footing system is VERY cool, no need for excavation or drilling - they are just simple plates sat on and pinned to the ground with long rods. Still results in massive bearing and uplift capacities. But they only take ten minutes each to install.
        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
        • RichardR Offline
          Richard
          @ntxdave said:
          Well done sir........I am just trying to learn how to render and things like this represent the target I am trying to hit. Mine does not need to be a photo realistic as yours but it is the type of result that is inspirational.
          Sorry mate! I've lead you astray, these are ALL as Solo points out Photos of the actual display home!
          BTW Render like that! I'd even like to be able to take a photo like that!
          • majidM Offline
            majid
            I will never forget your tree factory! that was a great idea to prepare realistic trees at the era that there were no good models. I thought you have improved some of those trees and used power of maxwell render over your model. though it makes me to try modeling and rendering your design 😉
            • jo-keJ Offline
              jo-ke
              Wow! What nice work.
              Always nice to see ideas become real
              http://www.zz7.de
                The usual high quality with simple and elegant description/marketing form. A lesson in and of itself.
                • RichardR Offline
                  Richard
                  Majid, that is SO LONG ago, yeah it was at a time when nothing tree wise was available for SketchUp, though now there is a wealth of vegetation options.
                  These days I'm not so fussed on 3D tree models in renders, the time time and ease to add them post pro seems much more efficient. I might have got lazy!
                  • RichardR Offline
                    Richard
                    Thanks mate, it really is nice to see things come to life! Shame it's on the other side of the country, a 4 hour flight if I want to have a peep myself!
                    • RichardR Offline
                      Richard
                      Thanks Mike! Luckily the design utilising panels only in construction meant keeping it very simple.
                      Here is a shot from SU of the general panel arrangement.
                      • PixeroP Offline
                        Pixero
                        Looks great!
                          The fact is, should I be lucky enough to live in one of those, I would be happy as a cat up a tree, with a whole salmon.
                          • RichardR Offline
                            Richard
                            Classic! Yeah I'd be happy too!
                            • majidM Offline
                              majid
                              To show my modeling progress here is a snapshot.
                              • utilerU Offline
                                utiler
                                Very nice, Rich. you're a clever dick....! 😉
                                Just Curious...
                                • RichardR Offline
                                  Richard
                                  Thanks mate, I wish it was closer than Perth! A 4hr flight to go and have a sticky doesn't excite me that much!
                                  • RichardR Offline
                                    Richard
                                    Looks good Majid, you've made me realise the plan has certainly changed somewhat from the first iteration. I'll check back through the file to see if I have any plans of the final!
                                    • majidM Offline
                                      majid
                                      That'd be great Richard. Waiting to see if there is any recent plan.
                                      • Bryan KB Offline
                                        Outstanding job!
                                        • majidM Offline
                                          majid
                                          Any new news from the as-built plans?
                                          • RichardR Offline
                                            Richard
                                            I've just added a few new photos to the first post!
                                            • 1 / 3
