    From roughed out design to real (more added)
    48 Posts 19 Posters 7.6k Views 19 Watching
    • pbacotP
      Really nice! Great job. Yes that is an enviable position, to be all about the design.
      • ntxdaveN
        ntxdave
        Well done sir........I am just trying to learn how to render and things like this represent the target I am trying to hit. Mine does not need to be a photo realistic as yours but it is the type of result that is inspirational.
        Press F1...thank me later
        • srxS
          srx
          Thees type of renders is the target for all of us... ๐Ÿ’š
          (photo-realistic)
          www.saurus.rs
          • majidM
            majid
            Which is which, I mean which is render and which one is a real photo?
            • HornOxxH
              HornOxx
              This work is simply great!!!
              Majid, I have no idea also...
              never trust a skinny cook
              • soloS
                First one is a render and the rest are photos. ๐Ÿ˜„
                • RichardR
                  Richard
                  @mike lucey said:
                  Very clean design there Richard.
                  BTW, have you seen,
                  'Sustainable home can be built in four days using only a screwdriver'
                  http://www.popup-house.com/en/
                  http://www.popup-house.com/en/what-is-a-passive-h
                  I'm still reading about the 'patented' system and like what I see so far.
                  Mike
                  Yeah I have seen it Mike! It's a BRILLIANT system, this display home here uses SIP panels for all the floor, walls and roofing but in probably a more simple install than POP-UP.
                  The actual footing system is VERY cool, no need for excavation or drilling - they are just simple plates sat on and pinned to the ground with long rods. Still results in massive bearing and uplift capacities. But they only take ten minutes each to install.
                  BUILTBRAND.COM.AU
                  • RichardR
                    Richard
                    Sorry mate! I've lead you astray, these are ALL as Solo points out Photos of the actual display home!
                    BTW Render like that! I'd even like to be able to take a photo like that!
                    BUILTBRAND.COM.AU
                    • majidM
                      majid
                      I will never forget your tree factory! that was a great idea to prepare realistic trees at the era that there were no good models. I thought you have improved some of those trees and used power of maxwell render over your model. though it makes me to try modeling and rendering your design ๐Ÿ˜‰
                      • jo-keJ
                        jo-ke
                        Wow! What nice work.
                        Always nice to see ideas become real
                        http://www.zz7.de
                          The usual high quality with simple and elegant description/marketing form. A lesson in and of itself.
                          • RichardR
                            Richard
                            Majid, that is SO LONG ago, yeah it was at a time when nothing tree wise was available for SketchUp, though now there is a wealth of vegetation options.
                            These days I'm not so fussed on 3D tree models in renders, the time time and ease to add them post pro seems much more efficient. I might have got lazy!
                            BUILTBRAND.COM.AU
                            • RichardR
                              Richard
                              Thanks mate, it really is nice to see things come to life! Shame it's on the other side of the country, a 4 hour flight if I want to have a peep myself!
                              BUILTBRAND.COM.AU
                              • RichardR
                                Richard
                                Thanks Mike! Luckily the design utilising panels only in construction meant keeping it very simple.
                                Here is a shot from SU of the general panel arrangement.
                                BUILTBRAND.COM.AU
                                • PixeroP
                                  Pixero
                                  Looks great!
                                    The fact is, should I be lucky enough to live in one of those, I would be happy as a cat up a tree, with a whole salmon.
                                    • RichardR
                                      Richard
                                      Classic! Yeah I'd be happy too!
                                      BUILTBRAND.COM.AU
                                      • majidM
                                        majid
                                        To show my modeling progress here is a snapshot.
                                        • utilerU
                                          utiler
                                          Very nice, Rich. you're a clever dick....! ๐Ÿ˜‰
                                          Just Curious...
                                          • RichardR
                                            Richard
                                            Thanks mate, I wish it was closer than Perth! A 4hr flight to go and have a sticky doesn't excite me that much!
                                            BUILTBRAND.COM.AU
                                            • 1 / 3
