    From roughed out design to real (more added)
    48 Posts 19 Posters 6.2k Views 19 Watching
    • srxS Offline
      srx
      @ntxdave said:
      Well done sir........I am just trying to learn how to render and things like this represent the target I am trying to hit. Mine does not need to be a photo realistic as yours but it is the type of result that is inspirational.
      Thees type of renders is the target for all of us... 💚
      (photo-realistic)
      www.saurus.rs
      • majidM Offline
        majid
        Which is which, I mean which is render and which one is a real photo?
        • HornOxxH Offline
          HornOxx
          This work is simply great!!!
          Majid, I have no idea also...
          never trust a skinny cook
          • soloS Offline
            First one is a render and the rest are photos. 😄
            • RichardR Offline
              Richard
              @mike lucey said:
              Very clean design there Richard.
              BTW, have you seen,
              'Sustainable home can be built in four days using only a screwdriver'
              Page non trouvée - PopUp House
              PopUp House (www.popup-house.com)
              I'm still reading about the 'patented' system and like what I see so far.
              Mike
              Yeah I have seen it Mike! It's a BRILLIANT system, this display home here uses SIP panels for all the floor, walls and roofing but in probably a more simple install than POP-UP.
              The actual footing system is VERY cool, no need for excavation or drilling - they are just simple plates sat on and pinned to the ground with long rods. Still results in massive bearing and uplift capacities. But they only take ten minutes each to install.
              BUILTBRAND.COM.AU
              • RichardR Offline
                Richard
                Sorry mate! I've lead you astray, these are ALL as Solo points out Photos of the actual display home!
                BTW Render like that! I'd even like to be able to take a photo like that!
                BUILTBRAND.COM.AU
                • majidM Offline
                  majid
                  I will never forget your tree factory! that was a great idea to prepare realistic trees at the era that there were no good models. I thought you have improved some of those trees and used power of maxwell render over your model. though it makes me to try modeling and rendering your design 😉
                  • jo-keJ Offline
                    jo-ke
                    Wow! What nice work.
                    Always nice to see ideas become real
                    http://www.zz7.de
                      The usual high quality with simple and elegant description/marketing form. A lesson in and of itself.
                      • RichardR Offline
                        Richard
                        Majid, that is SO LONG ago, yeah it was at a time when nothing tree wise was available for SketchUp, though now there is a wealth of vegetation options.
                        These days I'm not so fussed on 3D tree models in renders, the time time and ease to add them post pro seems much more efficient. I might have got lazy!
                        BUILTBRAND.COM.AU
                        • RichardR Offline
                          Richard
                          Thanks mate, it really is nice to see things come to life! Shame it's on the other side of the country, a 4 hour flight if I want to have a peep myself!
                          BUILTBRAND.COM.AU
                          • RichardR Offline
                            Richard
                            Thanks Mike! Luckily the design utilising panels only in construction meant keeping it very simple.
                            Here is a shot from SU of the general panel arrangement.
                            BUILTBRAND.COM.AU
                            • PixeroP Offline
                              Pixero
                              Looks great!
                                The fact is, should I be lucky enough to live in one of those, I would be happy as a cat up a tree, with a whole salmon.
                                • RichardR Offline
                                  Richard
                                  Classic! Yeah I'd be happy too!
                                  BUILTBRAND.COM.AU
                                  • majidM Offline
                                    majid
                                    To show my modeling progress here is a snapshot.
                                    • utilerU Offline
                                      utiler
                                      Very nice, Rich. you're a clever dick....! 😉
                                      Just Curious...
                                      • RichardR Offline
                                        Richard
                                        Thanks mate, I wish it was closer than Perth! A 4hr flight to go and have a sticky doesn't excite me that much!
                                        BUILTBRAND.COM.AU
                                        • RichardR Offline
                                          Richard
                                          Looks good Majid, you've made me realise the plan has certainly changed somewhat from the first iteration. I'll check back through the file to see if I have any plans of the final!
                                          BUILTBRAND.COM.AU
                                          • majidM Offline
                                            majid
                                            That'd be great Richard. Waiting to see if there is any recent plan.
                                            • 1 / 3
