    From roughed out design to real (more added)
    48 Posts 19 Posters 6.8k Views 19 Watching
    • RichardR Offline
      Richard
      Here is a little Granny Flat I designed for the Perth market. The client has now completed and opened their display home.
      For this client I fortunately didn't need to go to any extreme details (or dimensions even), just provide them with a vision so to speak. I seriously love working to that level and no more!
      BTW for those who might question, a granny flat is an ancillary dwelling you put in your backyard for your extended family or to lease out. This one is around 90m2 (tight)!!
      The original layout sketch (the actual build is flipped).
      Sketch exterior
      The finished Display Home
      More Photos added
      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
      • Mike LuceyM Offline
        Mike Lucey
        Very clean design there Richard.
        BTW, have you seen,
        'Sustainable home can be built in four days using only a screwdriver'
        Page non trouvée - PopUp House
        PopUp House (www.popup-house.com)
        I'm still reading about the 'patented' system and like what I see so far.
        Mike
          Neat! 😎
          • cheddaC Offline
            chedda
            Super job Richard !
            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
            • marked001M Offline
              marked001
              that is awesome.. love that.
              http://www.revision21vis.com
              instagram: revi21on
              • pbacotP Offline
                Really nice! Great job. Yes that is an enviable position, to be all about the design.
                • ntxdaveN Offline
                  ntxdave
                  Well done sir........I am just trying to learn how to render and things like this represent the target I am trying to hit. Mine does not need to be a photo realistic as yours but it is the type of result that is inspirational.
                  Press F1...thank me later
                  • srxS Offline
                    srx
                    Thees type of renders is the target for all of us... 💚
                    (photo-realistic)
                    www.saurus.rs
                    • majidM Online
                      majid
                      Which is which, I mean which is render and which one is a real photo?
                      • HornOxxH Offline
                        HornOxx
                        This work is simply great!!!
                        Majid, I have no idea also...
                        never trust a skinny cook
                        • soloS Offline
                          First one is a render and the rest are photos. 😄
                          • RichardR Offline
                            Richard
                            BTW, have you seen,
                            Mike
                            Yeah I have seen it Mike! It's a BRILLIANT system, this display home here uses SIP panels for all the floor, walls and roofing but in probably a more simple install than POP-UP.
                            The actual footing system is VERY cool, no need for excavation or drilling - they are just simple plates sat on and pinned to the ground with long rods. Still results in massive bearing and uplift capacities. But they only take ten minutes each to install.
                            • RichardR Offline
                              Richard
                              Sorry mate! I've lead you astray, these are ALL as Solo points out Photos of the actual display home!
                              BTW Render like that! I'd even like to be able to take a photo like that!
                              • majidM Online
                                majid
                                I will never forget your tree factory! that was a great idea to prepare realistic trees at the era that there were no good models. I thought you have improved some of those trees and used power of maxwell render over your model. though it makes me to try modeling and rendering your design 😉
                                • jo-keJ Offline
                                  jo-ke
                                  Wow! What nice work.
                                  Always nice to see ideas become real
                                  http://www.zz7.de
                                    The usual high quality with simple and elegant description/marketing form. A lesson in and of itself.
                                    • RichardR Offline
                                      Richard
                                      Majid, that is SO LONG ago, yeah it was at a time when nothing tree wise was available for SketchUp, though now there is a wealth of vegetation options.
                                      These days I'm not so fussed on 3D tree models in renders, the time time and ease to add them post pro seems much more efficient. I might have got lazy!
                                      • RichardR Offline
                                        Richard
                                        Thanks mate, it really is nice to see things come to life! Shame it's on the other side of the country, a 4 hour flight if I want to have a peep myself!
                                        • RichardR Offline
                                          Richard
                                          Thanks Mike! Luckily the design utilising panels only in construction meant keeping it very simple.
                                          Here is a shot from SU of the general panel arrangement.
                                          • PixeroP Offline
                                            Pixero
                                            Looks great!
                                            • 1 / 3
