    Materials applied to Fredo Round Corner
    19 Posts 6 Posters 1.7k Views 6 Watching
    • MR WOLFM Offline
      MR WOLF
      Does anyone know how to make all rounded edges show a consistently correct applied material?
      See ther attached images. I made a box with Fredo round tool. My Steps were:
      1. Made the box.
      2. made the box a group.
      3. double clicked to open the group, used Libfredo round corner tool over entire box.
      4. closed the group, selected an ordinary material from a simple image I made into a texture from sketch up materials and painted the box (while it was an uneditable group).
      5. rendered.
      A is the only edge that follows around the rounded corner. All others have some distortion.
        ThruPaint ?
        • MR WOLFM Offline
          MR WOLF
          @pilou said:
          ThruPaint ?
          I dont think this plugin is available anymore..
          • MR WOLFM Offline
            MR WOLF
            Hi Pilou,
            I dont think Thrupaint is available any longer. Not in the extension warehouse anylonger.
            • TIGT Online
              ThruPaint [and many other fine Fredo tools, ~17 in all?] are in a toolset named 'FredoTools':
              http://sketchucation.com/forums/viewtopic.php?p=397448#p397448
              http://sketchucation.com/forums/viewtopic.php?p=373073#p373073
              This toolset's RBZ is available from the SCF PluginStore...
              http://sketchucation.com/pluginstore?pln=FredoTools
              You must also install LibFredo...
              http://sketchucation.com/pluginstore?pln=LibFredo6
              Install both then reestart SketchUp to complete the installations...
              • JQLJ Offline
                JQL
                If you want to have consistency in all corners using only Sketchup (with thrupaint or native tools) you have to use a projected texture:
                www.casca.pt
                Visit us on facebook!
                  @mr wolf said:
                  Hi...
                  1. closed the group, selected an ordinary material from a simple image I made into a texture from sketch up materials and painted the box (while it was an uneditable group).
                  Don't apply the material to the group/component wrapper. Apply it to the faces inside. applying materials to the wrapper means you give up options about how that material gets applied.
                  If you want the grain to run vertically on the sides of the block, you need an end grain material on the top.
                    slbaumgartner
                    Joao got the texture to wrap around the block, but abandoned physical realism in the process! There would have to be end grain somewhere.
                    • JQLJ Offline
                      JQL
                      LOL! I was working on a floor with that texture, I just put a cube on the side to show how it would look like and hit render because Thea textures are shrinked in model and full resolution only in render...
                      I have a procedural though... that if I UV unwrap that Cube, I can make it have the endgrain...
                      www.casca.pt
                      • MR WOLFM Offline
                        MR WOLF
                        @dave r said:
                        @mr wolf said:
                        Hi...
                        Hi Dave R,
                        Thanks for your answer to this problem.
                        I have tried doing as you say, however, the result is no improvement. Perhaps I didn't understand what you meant? This is what I did according to your advice:
                        1. Made the box and grouped it.
                        2. opened up group, double clicked till everything was selected, applied round corner to entire box.
                        3. while it was still all selected, I painted on the material.
                        4. closed the group and rendered.
                        You can see close up the rounded faces along all the curves are still distorted. As far as the end grain goes, I understand all the grain on the box isn't matching correctly (if this was a real small block of timber), this wasn't really what I was testing or concerned about at the minute, however since you mention it, I guess end grain would be created in PS somehow?
                        Cheers!! Wolf πŸ˜„
                        Still distorted on all faces that are on the curved
                          The material can still be applied better but you'll actually be able to control it on each face. Somewhere you're going to run into a problem because the grain direction will cross.
                          • MR WOLFM Offline
                            MR WOLF
                            [attachment=0:365u53bz]<!-- ia0 -->Capturar.JPG<!-- ia0 -->[/attachment:365u53bz]
                            Hi JQL,
                            Thanks very much for your reply to my problem.
                            Your attached image was a new approach I hadn't thought of. I haven't done a projected texture before, or used the Thru paint which I will download and try to use.
                            Correct me if I'm wrong, I have seen a video about projected textures, and it seems that you have to apply a texture to each face. Given there are a lot of faces on the round corners, would this take forever?
                            The example you showed in your image, was that created by projected texture or with Thru paint? I like how its all uniformly wrapped, looks really good and I would like to also learn how to do this, as well as the version I'm trying to achieve (where grain is all straight around with end grain on top).
                            If you can help with these questions you would be Super!
                            Cheers! Wolf
                            • MR WOLFM Offline
                              MR WOLF
                              Hi TIG,
                              Thanks for helping me out with your answer πŸ˜„
                              I have just downloaded The Fredo tool set and can now see all the tools including Thru Paint) within SU. πŸ˜„ So now just have to get my head around it and search for some tuts.
                              Cheers!! hope it achieves a consistent grained wrap on the curved faces πŸ˜„
                              Cheers! Wolf
                              • JQLJ Offline
                                JQL
                                Projecting Textures:
                                www.casca.pt
                                • MR WOLFM Offline
                                  MR WOLF
                                  Yes I have seen this video however, it shows a curve which is parallel to a flat surface (the projected image) I have a six sided cube with hundreds of small faces on round edges so how can I set up one surface (image) to cover entire sides/faces of square cube?
                                  • MR WOLFM Offline
                                    MR WOLF
                                    I managed to do this somehow lol.. Ill figure it out with sometime and playing around πŸ˜„
                                    • MR WOLFM Offline
                                      MR WOLF
                                      @mr wolf said:
                                      Hi Pilou,
                                      Thanks Pilou!
                                      TIG sent me a link to the Thru Paint, I have been testing it and figured a simple solution out. Many Thanks for your help!
                                      • MR WOLFM Offline
                                        MR WOLF
                                        Thank you to all who helped. The Thru Paint did it perfect, just need to learn it as it has so many features.
                                        • MR WOLFM Offline
                                          MR WOLF
                                          Cheers JQL! I just need some practicing on the Thru Paint.
