    What if unwrapping sketchup models was kinda easy....
    112 Posts 36 Posters 35.1k Views 36 Watching
      @jql said:
      @rich o brien said:
      What you see in WrapR is not the texture you saw in SU.
      Sent from my iPhone using Tapatalk
      But it will be... Right?
      Will WrapR be able to convert a model that was mapped with tileable textures into a single texture?
      Like the "combine textures" context menu feature but with multiplanar faces (and no image scale reduction)?
      An atlas but only for selected component/group/mesh?
      That would be a great feature - fantastic for game development. People kept asking for that after I made the Cities Skylines extension.
      I wonder how other tools allows this.
      I'm guessing you'd need to UV unwrap the entire mesh first - then once it's all done you can do some sort of packing algorithm to put them all into one texture tile. Because I don't think you can combine the texture and then uv unwrap...
      • FrederikF
        Frederik
        It works great...
        Cheers
        Kim Frederik
          @ntxdave said:
          Another one of my silly questions. Can someone give me a practical definition of what UV is. I have looked it up in places like Wikipedia but, at least in the context of threads like this one, and do not think I "get it". Thus, why should I understand why UV unwrapping is a big deal?
          U and V are just common variable names such as X, Y and Z. It's convention.
          When we talk about mapping a texture, which is a 2d bitmap to a 3d mesh we need to define where the texture will be place on each of the polygons in the 3d face. To do that we need to attach 2d coordinates to each of the 3d points.
          While X and Y can represent these 2d texture coordinates it gets confusing if we also use XYZ for the 3d points. So by arbitrary convention we usually refer to texture mapping coordinates as UV onto XYZ 3d mesh points.
          UV unwrapping is a big deal - or I'd rather say important, because it's required in being able to map a texture continuously across a mesh. You can imagine how you do gift wrapping; you take a 2d sheet of paper and wrap it around your object. If you force it you end up with wrinkles. Now imagine that you cannot make your paper overlap itself - you need to take a scissor and cut away pieces - but you want to make as few cuts as possible so that it looks nice and hide the seams.
          (Did that make any sense?)
            These are also another UVs methods! πŸ˜‰
            http://www.ikonet.com/fr/ledictionnairevisuel/images/qc/projections-cartographiques-100390.jpg
            • ntxdaveN
              ntxdave
              @ThomThom & @Pilou - Thanks for such good explanations. This is exactly what I thought I understood from my other reading but needed some confirmation.
              Now another question: How do you get the 2d texture to map? In particular when I look at the ThomThom's example of the face. How do you get the flat face texture that you are mapping to your mesh?
              Once again, I really appreciate you guys putting up with these elementary questions so those of us who are just getting started/trying to learn ask. I can see the whole importance of where this is headed and think it is going to play a big role in 3d modeling of all types in the future.
              Press F1...thank me later
                rv1974
                I wish something suitable for fast texturing of 'conventional' architectural objects would eventually appear inside Sketchup:
                http://www.vg2max.spb.ru/polygonmap.htm
                • P
                  Pherim
                  Have you tried ThruPaint?
                  Also, this unwrapping tool sure looks interesting. Just now I'm mostly working with ThruPaint and SketchUV, and the things I can't do directly in Sketchup I can do in Blender with the SketchUV import/export function, but your tool will be a nice addition.
                    That's the process of UV unwrapping. You start with the 3d mesh (on the left in the image) - then you use a tool, like Wrap-R to unfold it like you see in second to left. This is the non-trivial part. You need to crease seams - tell the applications where to cut the 3d mesh such that it can be unfolded into 2d. The unwrapping application then tries to lay out the mesh onto a 2d surface such that no polygons overlap each other.
                    Once you have that 2d flattened version you take it into an application like photoshop and draw your texture using the unwrapped mesh as guides. With that new texture you reapply that to the original model. (Alternatively, there are some applications that let you draw directly onto 3d surfaces.)
                    I'm not sure if that description was the best - a video here is probably more explanatory.
                      I'm a little confused by the arrows that appear. But the tool is trying to determine the flow/direction of the mesh for automating the UV mapping?
                        rv1974
                        Yes, in accordance to edges.
                        From his description:
                        "This modifier allow to set planar mapping of selected polygons and orient map by selected edge or by maximum (minimum) length of edges in each polygons"
                        • PixeroP
                          Pixero
                          I'm really thrilled about this plugin.
                          One thought though.
                          Personally I don't have anything against it but I think the name WrapR might be a bit to cryptic for a lot of people.
                          At least consider a more descriptive name.
                            rv1974
                            Will it be based on Roadkill or something completely independent?
                            The name indeed is not there yet
                            • Bob JamesB
                              Bob James
                              One thought though.
                              UnWrapR 😎
                              • JQLJ
                                JQL
                                I don't think it's criptic but reminds me of rap.
                                I agree with the naming being different that sketchup derivations if this is going to be an external app that can be marketed to other software. If not, the most evident name to use would be in the lines of WrapUp, but I'm pretty sure you've been there...
                                www.casca.pt
                                Visit us on facebook!
                                • K
                                  kaas
                                  Wrapster
                                  Wrap-a-lot
                                  WrapIt
                                  • L
                                    leminilab
                                    Unwrapido! πŸ˜„
                                    • "Live every day as if it were your last and then some day you'll be right."
                                    • "ThomThom rules!!!"
                                    • soloS
                                      "WrapUp" πŸ‘
                                      • McGyverM
                                        McGyver
                                        This looks fantastic. I'm looking forward to its further development.
                                        If possible I hope the price range would be in the Artisan/SubD realm.
                                        I agree, WrapR might not be the name with the most visual lock... Add an "Un" and eyeballs might lock on and stop to read, but still most folks with experience know what wrapping/unwrapping is about.
                                        That and once it's available (it will happen, I hope), people will probably come from all over via suggestions/links in forum posts and other recommendations anyway, so anything "wrappy" will do.
                                        And now the waiting game begins...
                                        Is it done yet?
                                        How about now?
                                        Now?
                                        Visit My ShareCG Freebie Gallery
                                        • McGyverM
                                          McGyver
                                          How about now.... Is it ready now?
                                          Okay... I'll wait...
                                          • K
                                            Khai
                                            2 questions.
                                            1- can the resulting uvs be exported with the mesh to obj, either via the app or via sketchup (or indeed via collada) for use in other applications
                                            And
                                            2- what's the name of the music and where can I get a copy?
                                            • 3 / 6
