    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • StinkieS Offline
      Stinkie
      @thomthom said:
      There are talks going on with various render engines to allow for them to render high-poly variants from the low-polys.
      Nice! πŸ‘
      • O Offline
        optimaforever
        In the same order of idea, can you thomthom develop a quadchamfer4SU?
        Ideally it would be a mix between the editability of SubD and the easiness of RoundCorner...
        Roundcorner is good but it doesn't allow for editing. I have to keep a non-chamfered version in a temp layer if I need to edit it again. And SubD need manually offsetted lines to control the distance of chamfering. On complex models, it can quicky become a time-consuming burden, just to create chamfered edges, not to mention the file size and the memory footprint.
        This TTQuadchamfer would be a quick 3D chamfer/fillet tool that automatically creates the needed lines offsets according to pre-entered parameters, which in return could allow easy re-editing, should the need arise. And afterward, one could tweak the fillet values edge by edge for more flexibility.
        What do you think?
          Got some visuals to illustrate expected result?
          • O Offline
            optimaforever
            Have you seen http://www.mariussilaghi.com/products/quad-chamfer ?
            • gillesG Offline
              gilles
              Streamliner, based on Norman E. Timbs 48 buick.
              • JQLJ Offline
                JQL
                What do you think?
                Actually I'm simply not using SubD, because it would be the most fun plugin I'd have, but it's not really useful for what I need right now. I would have yet another toy to have fun with and deviate my attention for what I do for a living... I must resist...
                If you'd do it, it would be extremelly useful if you'd integrate it with SubD methodology and chamfer it only when subdividing, keeping UV's, allowing for creases worflow to be integrated too and, probably integrate it in the rendering workflow too.
                I didn't know it yet but if SubD would be able to produce that, it would turn into the most useful toy an architect that deals with archviz needs apart from the renderers themselves.
                Thanks for that feature request Optimaforever, I really hope Thomthom pulls that one off!
                www.casca.pt
                Visit us on facebook!
                  @: Gilles where is the model ? πŸ˜‰
                  Inspiration Vrooum, vrooum! πŸ’š
                  car_v6.zip
                  • gillesG Offline
                    gilles
                    [attachment=2:2ruqdqif]<!-- ia2 -->blobcar.jpg<!-- ia2 -->[/attachment:2ruqdqif]
                    STREAMLINER.skp
                    • StinkieS Offline
                      Stinkie
                      Oooh, it'd be great to have that in SU.
                      • O Offline
                        optimaforever
                        Indeed, my next request would be that the quad chamfer only applies when rendering, a bit alla Skatter-way, with the "render only" option.
                        I don't know if it's in the pipeline but I guess that having the SUbD not visible when working and only visible during rendertime would be an equally useful feature. A kind of general SUbD toggle on/off in the SUbD preferences. The thing is, there is always an SUbD object on which I forget to apply the subdivision before pushing on the render button (lazy me), and having a "all subd on when rendering" toggle button would save my ass for sure 🀒
                          @ Gilles : Thx! πŸ˜‰
                          Model by Gilles above!
                          The trick is colored first then SUbD πŸ˜‰
                          Or there is another trick after the SUbD ?
                          • O Offline
                            optimaforever
                            very nice pilou ! 😎
                            • HornOxxH Offline
                              HornOxx
                              @pilou said:
                              ... The trick is colored first ...?
                              typical French - you inspire a new fashion trend !! πŸ˜›
                              never trust a skinny cook
                                I'm in contact with some render engines in exploring way to allow them to render subdivided mesh independent from what is visible in the SU viewport. πŸ˜„
                                • O Offline
                                  optimaforever
                                  Thomthom, you're da man πŸ˜„
                                    leminilab
                                    Hi, Just uploaded a few objects modeled with basically Vertex Tools, and SubD:
                                    https://3dwarehouse.sketchup.com/model.html?id=u4ce6c724-8926-4af9-a91c-acbe495b50db
                                    Thanks for the planet, man (if everybody could share their files in proxy mode (1,5 to 9,5Mb in my example), we'd save a lot of energy!
                                    You well deserve the cookies you get! My hero! πŸ˜„
                                    • "Live every day as if it were your last and then some day you'll be right."
                                    • "ThomThom rules!!!"
                                    • StinkieS Offline
                                      Stinkie
                                      Now that'd be quite something. πŸ‘
                                      • BoxB Offline
                                        I really do love the simplicity of modelling with the combination of QFT, VT and SubD.
                                        http://i155.photobucket.com/albums/s296/storeben/SU/Marble_1.png
                                          Vasarely revival! 😎
                                          • HornOxxH Offline
                                            HornOxx
                                            ... a simple beverage can and a trial with texturing
                                            beverage can Proxy.skp
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 82
                                            • 83
                                            • 18 / 83
