    Animator: Parametric Animation plugin - Discussion
    223 Posts 55 Posters 85.5k Views 55 Watching
    • ntxdaveN Offline
      ntxdave
      I know this is pushing it but I would also like for it to be supported by one of the extensions that support exporting the model to WebGL.
      Imagine being able to show you model on a web page with no plugin that included object animations.
      Press F1...thank me later
      • fredo6F Offline
        @thomthom said:
        Can you animate instances within other instances?
        Answer is Yes.
        Actually, grouping component instances and groups helps transform several objects at once, instead of selecting each of them (even if multi-selection is also supported).
        But you can individually move an object within a group.
        In the Car Wash example, the whole car is translated as a group, including the wheels, and the wheels are transformed by spin individually.
        • fredo6F Offline
          @thomthom said:
          @solo said:
          I hope that this animation gets supported by the SU integrated render engines like Twilight, Thea, Podium, Corona, Vray, etc.
          Ditto! I know they'd be very interested.
          I tentatively built an API for acting externally on the animation, so that a rendering software can drive the animation frame by frame.
          Animator - API for Renderers - v1.pdf
          I am in contact with tomasz for Thea.
          But I don't know how to reach the others
          • fredo6F Offline
            That would be a good feature, not just for animation.
            I'll have to explore WebGL to understand what it is about and if it is applicable in the case of an animation.
            I know Tak2hata has released a plugin doing WebGL export, so he is probably the best expert to contact.
            • soloS Offline
              So when can we play?
              Planning a beta team?
              • O Offline
                otb designworks
                Re beta test team: Pick Me Pick Me!!!
                I am more excited for this plugin than anything I have seen come out of the official team since they gave us Layout!
                Cheers, Chuck
                OTB Designworks is on Youtube
                  PM me who you are looking for - I'll see what I can do. I have the ChaosGroup contacts for sure - but I should be able to obtain other as well.
                  • soloS Offline
                    I have had so many issues in the past with the available tools/plugins, that is why this is a huge thing.
                    See video below, a recent attempt to use SU and Thea, It failed and i needed to finally go into Thea studio to complete animation. I also needed to have layers animate, so I could show and hide panels, will it be possible with this plugin?
                    • fredo6F Offline
                      Animator should normally support layer visibility, either attached to views or independently of views.
                      Below a short example. Watch the green cylinder and red cube, and layers panel.
                      [attachment=0:1ubxfxj3]<!-- ia0 -->Animator%20Layer%20visibility%20simple.gif<!-- ia0 -->[/attachment:1ubxfxj3]
                      • JQLJ Offline
                        JQL
                        Fredo and what about animating stuff by cycling through scenes as usual, is it also possible?
                        I mean it's so advanced in it's own that I can't understand if that is a possibility as it's what a basic animation plugin for SU does...
                        If it is, can we do it without showing UI? In fullscreen mode, to present stuff live to an audience?
                        www.casca.pt
                        Visit us on facebook!
                        • fredo6F Offline
                          Animator is not based on the native Scene animation mechanism of Sketchup. You can actually position the animation at any given time. Indeed, it is possible to develop a small GUI to make short cuts to specified time.
                          Also, there is a Player mode, with a much smaller palette. I plan to make the option to hide it when playing animation.
                            Seems very promising! 😎
                            • JQLJ Offline
                              JQL
                              We will find something you didn't think of! πŸ˜„
                              www.casca.pt
                              • fredo6F Offline
                                That's why the thread was started πŸ˜„
                                • PixeroP Offline
                                  Pixero
                                  What about how hierarchies are created?
                                  Can that be made separate from how objects are grouped?
                                  And what about inverse kinematic?
                                  I'm also very interested in ways to fine tune camera animation paths and speed.
                                  • fredo6F Offline
                                    I am not clear about what is "Reverse kinematic" and "hierarchies".
                                    Could you illustrate ?
                                    • PixeroP Offline
                                      Pixero
                                      Forward kinematics. You rotate a shoulder and the arm and hand follows.
                                      Inverse kinematics. You move the hand and the arm and shoulder rotates to match the hands movement.
                                      I think it would be great to have a way of creating the hierarchy independent of how objects are grouped.
                                      Something like bones in other software where you create a structure that you bind geometry to.
                                      How you model and group geometry doesn't always match how you want to animate them.
                                        How do you control the motion of an object over time? Is it linear interpolation?
                                        If an object moves along X at 2m/s can you control the acceleration from 0 to 2m/s in some way?
                                        Sent from my iPhone using Tapatalk
                                        • fredo6F Offline
                                          This should be addressed with Easing, which is supported in the Animator engine (in the initial video, you can see that the explosion of Homer is accelerated).
                                          But I still need to build the GUI for custom easing.
                                          By the way, I don't know if the appropriate term in English would be 'Easing' or 'Pacing'.
                                            Easing.
                                            • 11
                                            • 12
                                            • 6 / 12
