    [Plugin] SectionCutFace
    565 Posts 170 Posters 375.0k Views 169 Watching
    • cottyC Offline
      cotty
      @n i c o said:
      Greetings!!
      Is there a SectionCutFace plug-n compatible for sketchup 2015, I can't find anywhere? I need it and it will be a big help for my thesis. Thank you so much in advance.
      Godspeed!
      Yes, this one, you can download it at the plugin store or with the plugin store extension.
      my SketchUp gallery
      • O Offline
        otb designworks
        Thanks TIG!!
        Without doubt, my SU experience would suck a whole lot without Section Cut Face and Mirror. Indispensable and greatly appreciated.
        Cheers, Chuck
        OTB Designworks is on Youtube
        • JQLJ Offline
          JQL
          @otb designworks said:
          Thanks TIG!!
          Without the automatisms of other more sophisticated section plugins yet it was this plugin, along with Layout, that allowed me to ditch away CAD.
          I draw every section detail on a SectionCutFace that only updates on demand.
          Amazing possibilities!
          www.casca.pt
          Visit us on facebook!
          • ntxdaveN Offline
            ntxdave
            If I select/apply a color to the cut, is there a way to go back and changed the color?
            I have looked at the documentation but did not understand from it how to change the color.
            Press F1...thank me later
            • JQLJ Offline
              JQL
              The color is just a material applied to the section. You can leave it as Default and apply your own material or you can choose a material and then replace the material that has been applied by your own.
              The section cut is no more than a group with faces and edges...
              www.casca.pt
              • ntxdaveN Offline
                ntxdave
                OK, I set it to <Default> but I do not see how to change it. I tried using the paint bucket.
                What the heck am I missing?
                OH HOW STUPID - I just figured it out. If you want to change something, you need to UNLOCK it. 😎
                • JQLJ Offline
                  JQL
                  you can unlock it on the first place by using settings...
                  www.casca.pt
                  • JQLJ Offline
                    JQL
                    TIG,
                    I've tested it to the extent I could and I found a problem with old models.
                    It seems the settings of old Section Cut Faces persist to new ones and I get some that don't assume the section's layer's name into the Section Cut Face Layer.
                    This is what happens:
                    1 - SectionCutFace Created with previous plugin version:
                    1.1 - Made that original SectionCutFace with "On Demand" option;
                    1.2 - Section group on was set to an existing layer at the time like "Layer X";
                    1.3 - Group Name auto defined as SCUT-54345.
                    2 - Remaking SectionCutFace with new plugin after reorganizing layers
                    2.1 - Reorganize sections and put that Original Section from "Layer X" into layer "X CL C":
                    2.2 - Remake Section Cut Face;
                    2.3 - Section group layer switches to "Layer 0"
                    2.4 - Section's group name redefines itself to "X CL C"
                    3 - Erasing original Section and Make New SectionCutFace
                    3.1 - Erased that section cut face and "Make SectionCutFace"
                    3.2 - Switch options to "NO" Autoupdate.
                    3.3 - Section Group layer stays switches to "Layer 0"
                    3.4 - Section Group Name Get's correct as "X CL C"
                    The funny thing is that after creating a SectionCutFace group with the new plugin I can select it BUT it doesn't show on Entity Info (The info there is from the section itself, not the SectionCutFace group).
                    If I double click on the SCF group, I can edit it, but once I get out of it, it's in Layer 0. "Not X CL C"
                    If I would guess, I'd say some old observer from "ONDEMAND" is overriding the new settings... It's an uneducated guess from reading stuff here and there about observers being the things that you guys use for memorizing plugin actions...
                    I hope it's easily fixable and thanks once again for this update!
                    www.casca.pt
                    • N I C ON Offline
                      N I C O
                      @tig said:
                      @N I C O
                      It should be compatible with earlier SketchUp versions [like v2015].
                      What is the "error that occurs" ?
                      Please supply the details.
                      We can't help with such vague reports...
                      So please supply the FULL error-message.
                      Yes I was expecting that it would be compatible with Sketchup Pro 2015. I think there's something wrong. Thank you for your reply.
                      Here's the error message.
                      Error Loading File SectionCutFace_loader.rb
                      Error: #<NameError: uninitialized constant TIG::SectionCutFace::DEFAULT>
                      C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SectionCutFace_loader.rb:18:in <module:SectionCutFace>' C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SectionCutFace_loader.rb:12:in module:TIG'
                      C:/Users/USER/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SectionCutFace_loader.rb:10:in `<top (required)>'
                      • N I C ON Offline
                        N I C O
                        @tig said:
                        @N I C O
                        Thank you again for your reply, i already fixed the error and installed the plug-in successfully. Thank you so much.
                        Best regards!
                        • TIGT Online
                          @JQL
                          Thanks for the bug report.
                          I found and fixed the issues...
                          Now, when you update a SectionCutFace - i.e. it's one which is set as either 'on_demand' or 'auto_update' - then its group.layer will change to match its section-plane's layer, unless its layer is already set to be 'Customized', in which case its layer is left unchanged...
                          The group.name also updates to match the group.layer.name, unless its name is already set to be 'Customized', in which case its name is left unchanged...
                          Here's v5.1 http://sketchucation.com/pluginstore?pln=SectionCutFace
                          • JQLJ Offline
                            JQL
                            @tig said:
                            @JQL
                            You're more than welcome, thanks for the quick fix. I'll test this asap!
                            www.casca.pt
                              antoinelepoutre
                              Is it supposed to update with the model ?
                              • JQLJ Offline
                                JQL
                                It has 3 Auto-Update options:
                                • No - which never updates unless you make a new Section Cut Face;
                                • Yes - which is supposed to update with the model;
                                • On Demand - which only updates when you right click, and choose Remake section cut face.
                                If your model is correctly modeled and creates a closed loop that SectionCutFace can figure out, it auto updates with model. Click the Gif:
                                www.casca.pt
                                  architect
                                  Screen shot 2016-02-04 at 8.49.46 AM.pngScreen shot 2016-02-04 at 8.46.52 AM.pngSectionCutFace loaded from preferences - extensions. Shows up there but does nothing and I get a load error after shutdown and restart. Plugins folder has "SectionCutFace.rb" file and "SectionCutFace" folder.
                                    @architect said:
                                    [attachment=1]SectionCutFace loaded from preferences - extensions. Shows up there but does nothing and I get a load error after shutdown and restart. Plugins folder has "SectionCutFace.rb" file and "SectionCutFace" folder.
                                    Are you still using SketchUp 8 as indicated in your profile?
                                    • TIGT Online
                                      While v8 is no longer supported by Trimble, and it's regarded as pretty much obsolete, I have loaded the latest version of SectionCutFace into v8 and it loads and works just fine...
                                      So something is wrong...
                                      Close SketchUp.
                                      Find the SectionCutFace.rb file and SectionCutFace subfolder within v8's Plugins folder - and delete them.
                                      Then reinstall SectionCutFace from its latest RBZ.
                                      I suspect you somehow have some older legacy files loading.
                                      This plugin tries to delete any such files in the subfolder, but if your v8 Plugins folder security-permissions are not set to FULL for every one listed in its Properties dialog, then it might be failing...
                                      By manually removing the loader and subfolder... and reinstalling from new you should get a clean installation.
                                      As I said - it works for me in all versions from v8 up to v2016, on both PC and MAC...
                                      So something is wrong at your end...
                                        architect
                                        Tried everything suggested and still get the same load error - time to enter the 21st century and upgrade from 8 Pro. Have you guys chased all the gremlins out of v2016 yet?
                                          There are a lot more gremlins in SU8 than in SU2016. πŸ˜‰
                                          • TIGT Online
                                            Have you actually removed the related file/subfolder as I suggested, and then reinstalled the RBZ ?
                                            I have it working fine on v8, so you should be able to too ??
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 28
                                            • 29
                                            • 14 / 29
