    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
    • TIGT Online
      @congellous said:
      Apologies if this is already answered but my extrude to 3D lattice doesn't seem to work, it was working ?
      It does work OK.
      What are you trying to do exactly ?
      You need the curved paths and a 'profile' face, with an optional guide-point...
      Perhaps you are making a simple oversight.
      Have you reviewed the usage video ?
      Are there any errors messages or anything printed out in the Ruby Console.
        Jago25_98
        This looks like an important plugin.
        It seems one thing it could be used for (correct me if I'm wrong) is for fixing holes in a solid identified by SolidInspector... but which tool is appropriate...
        Here I'm trying to plug holes in the underside of a surfboard... it has had the poly count reduced for testing. I want to smooth over those holes:
        holes in surfboard (heavily curved object)
        • TIGT Online
          Here's v3.0 http://sketchucation.com/pluginstore?pln=ExtrudeTools There are no major changes, but it's now 'signed', and therefore as well as working as before in older SketchUp versions, it is compatible with SketchUp >= v2016, in all 'Extension Loading Policies' [i.e. 'future-proofed']...
            littldrummrboy
            This is a great plugin! It contains a feature that would be AMAZING as a stand-alone tool: Orient Faces.
            Do any of your plugins offer Orient Faces as a function that can be applied to free geometry, instead of just working on geometry created by using the plugin?
            Is there another way to easily orient faces on a mixed-orientation mesh? Please create a stand-alone Orient Faces function to that we can easily fix mixed-face orientation geometry!
            • TIGT Online
              "Orient" is already a built-in context-menu tool.
              Select a correctly oriented face and choose the tool from the right-click context-menu.
              All connected faces are now oriented to match that face.
              Tip: Turn View > Hidden Geometry ON, so then you can select a single facet for the orientation, because otherwise if the mesh is smoothed it selects en mass...
              Unfortunately a mesh can only be oriented successfully if every edge in it has only one or two faces.
              If an edge has three or more faces, then no algorithm can determine what to do, because some faces will never be correctly oriented compared to their neighbors.
              Because a mesh that is made with a EEby... tool is likely to be 'orientable' it works 'in-code', but it's not guaranteed to be effective on other meshes...
              Unfortunately "Orient" is NOT accessible in the Ruby API, so I wrote my own.
              But it's only needed if the orientation of code-generated faces cannot be guaranteed.
                arklandesign
                Icons for this extension are not showing up at all. This is on 2016 Pro version using windows 7. I can access all the tools via extensions but would like to see the icons as before. Used sketucation3.0 to install, tried deleting the rb file and install again but still no icons showing.
                Any suggestions on what I can do to get the icons to appear again?
                • TIGT Online
                  Did you install it from a downloaded RBZ using Preferences > Extensions > Install Extension...
                  or the equivalent SketchUcation Archive Installer, or directly using the SketchUcation PluginStore dialog within SketchUp ?
                  Having reread your post I see it was the latter.
                  Your supposed problem...
                  If you mean the toolbar is not visible, then you probably need to activate it from its entry in the Toolbar list...
                  If you mean the toolbar appears, but it has blank buttons, then check that there are 22 PNG files in the subfolder - ..\Plugins\ExtrudeTools
                  This seems unlikely because all of the other files used by the tool to make the submenu items etc are also in that subfolder !
                  If there is no toolbar available something is weird... ๐Ÿ˜•
                    arklandesign
                    Hi Trevor, Yes all the png's appear and yes it is activated with a check to enable it. But I still have no tool bars or icons whatsoever. I tried disabling it, open sketchup again, re enable, open again and still nothing. Something is weird
                    I guess it would be quicker to reinstall SketchUp 2016 and reload all my plugins with sketucation's brilliant plugin store.
                    Thank you for the assistance.
                    Rashad
                      Hi John!
                      Happy New Year
                      • BoxB Offline
                        Isn't there something about java or some such being up to date for some icons to work?
                        I'm probably wrong but it stuck in my mind.
                          arklandesign
                          Hi Brian happy new year to you too ๐Ÿ˜‰ Very funny
                          Box- that might be it as I was told not to update Java by a friend. Perhaps i need to ignore that advice
                          Quick questions. I've uninstalled 2016 version. Should I delete everything in my appdata roaming plugins folder? Is there anything there I should leave alone?
                          Thanks again for all the help.
                          Rashad
                            Reinstalling SU2016 won't change the User/AppData/...SketchUp 2016/Plugins folder, though. Reinstalling SketchUp 2016 seems like a drastic step that's unlikely to fix the problem. Delete the Extrude Tools files from the Plugins folder and install anew with the SCF Plugin Store.
                            Edit: Too late. ๐Ÿ˜ฎ
                              arklandesign
                              Hi Dave,I already tried deleting and then re installing the extrude tools several times to no avail.
                              Re install only takes a few minutes as does re installing all my extensions. So it is not too drastic in my opinion. But I'm still not sure if I should delete every single file in the plugins folder or if there is something I should keep there that might be needed or is it okay to simply leave them all as is?
                                I guess at this point I'd delete the entire Plugins folder from App Data/Roaming... Then install the SCF Plugin Store from a fresh download and use it to install TIG's Extrude Tools. Don't install anything else until testing for icons.
                                  arklandesign
                                  That sounds like great advise and a good way to go
                                  Thank you Dave
                                    Good luck.
                                      arklandesign
                                      Darn Just did as per Dave's advice and still not showing toolbar for extrude tools.
                                      I updated java too so completely stumped at the moment as to how to correct this.
                                      Where is that head banging against a wall emoji Or is that on another forum ๐Ÿ˜ฒ
                                        arklandesign
                                        Yaaaaay... Got it working at last, Most likely operator error ( it always is) as when I went to toolbars and checked the box for extrude tools it came up. I had been checking the box under extensions.
                                        Anyhooo feels so good to sort this out, even if it was just due to correcting operator error. ๐Ÿ’š
                                        Thank you all for the help
                                        • TIGT Online
                                          ๐Ÿ˜’
                                          Many [but not all] Plugins are made as Extensions, and because of a glitch in v2016-M0's Loading Policy, when these are first installed they do no start off 'activated', even when the author specifies that they ought to, and the RBZ is properly signed, and the Loading Policy is set as 'Unrestricted' [the default]...
                                          Therefore, you currently need to activate any installed Extensions manually from Preferences > Extensions, by placing a check-mark against their entry [you can also use the SketchUcation Extensions-Manager to do this by moving them into the left 'activated' column].
                                          Thereafter, this activation should be remembered across sessions...
                                          When an activated Plugin has a Toolbar, then that might not start off initially activated when its RBZ is installed [but its initial state depends of the author's coding, if the Extension has been deactivated etc].
                                          You can activate that toolbar under the Toolbars list, by placing a check-mark against its entry.
                                          By default, when first activated it will appear top-left of the SketchUp-window, floating and in one line.
                                          You can reshape/relocate/dock it etc, all as you wish.
                                          This now active-toolbar should reappear across sessions, remembering wherever you last left it [and floating or docked etc].
                                          • ntxdaveN Offline
                                            ntxdave
                                            TIG, it appears I am seeing a problem with the Extrude Tools extension. Any time I use it if I use Ctrl-Z to undo something, I am winding up with a rectangle at the axis base point in my model. Please see this thread
                                            Press F1...thank me later
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 28 / 32
