    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 113.4k Views 95 Watching
    • Mistro11M Offline
      Mistro11
      Anything to consider for SU2015?
      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
      Structural Integrity is Not Just Physical...It's in the Design and Purpose
        Download and install a fresh copy. I did and it works just fine.
        • Mistro11M Offline
          Mistro11
          Thank you.
            cmoreink
            I bought the original SDS tool few years ago. I use it with my SU8 but since upgrading to SU2015 and installing the original SDS on SU2015 all icons are "green smiley faces" and I have no problem with that because if I point my cursor on one of the icons it tells me what tool it is but I want to upgrade to a new version with new tools.
            Q: how do I upgrade to the new version with new tools added?
            Q: will I have to pay for upgrade?
            ok, just went to extension warehouse and downloaded the new version. It says "free to use for 15 days... after a license must be purchased..." I also read it's free upgrade if I have the original one (I do) but with the original one there was no license, so how do I go about the free upgrade??? wi
            Problem, so I'm in extension warehouse>Atisan Oganic Toolset>click on download (directs me to same page with install button)>click on install (opens page with terms and conditions of use and sings me out)>checked accept terms and conditions of use>click confirm> and nothing happens.... ???
            Ok, got it πŸ˜„ but how do I register now (I have the original SDS, no registaration back then) the new Artisan tool?
            my portfolio
            • dereiD Offline
              derei
              One quick question: Artisan subdividing operation is not enclosed in start/commit operation? Each step is logged separately? I am asking this, because when I subdivide geometry and I need to undo it, it seems to have to do a lot of UNDOs, often ending somewhere in mid process of subdivision, having my geometry ruined, like parts missing.
                Seems not! Undo works fine! πŸ˜„
                • dereiD Offline
                  derei
                  Well, mine seems different... a lot of UNDOs and ended up with mess...
                  • BoxB Offline
                    You do seem to have some problems, as you can see here it is pretty much instant.
                    Upload your component so we can see if the same thing happens for us or if it specific to your setup.
                    • dereiD Offline
                      derei
                      Hmm, this is most troubling. What do you mean by "specific to my setup" ? What kind of settings do you reckon may influence Artisan's Undo behavior?
                      I attached the component here.
                      Component_85.skp
                      • cottyC Offline
                        cotty
                        No problem here with undo...
                        click to animate
                        my SketchUp gallery
                          What versions of SketchUp are you guys using? And what version of the extension?
                          • cottyC Offline
                            cotty
                            SU16-64 Pro, Artisan 1.2.4, Win10
                            my SketchUp gallery
                              No problem for me SU 64 make 2015 Windows 8.1 Artisan 1.2.4
                              for this all following
                              iterations 1 undo iterations 2 undo iterations 3 undo iterations 4 undo
                              • dereiD Offline
                                derei
                                SU 2015 x64 / Win7 x64
                                Have no idea what version of artisan... because I don't know how to check for the version. There is nothing in Artisan Menu to tell me the version (or I can't find it)
                                  But the version number is available in Preferences>Extensions.
                                  FWIW, I tried undoing a subdivide and smooth operation after running it on your file and got a Bug Splat. SU2016, Win 7 x64, and current version of Artisan.
                                  • BoxB Offline
                                    Same for me Dave, I was just about to post about it but got distracted.
                                    Same Artisan version throughout.
                                    Win7 64bit SU16 Bugsplat every time as soon as you undo
                                    Win10 64Bit SU16 Bugsplat
                                    However use SU15 on either machine and no issues.
                                      This might be a result of changes made to the Observer system in SU2016. (At least the undo thing. Not sure about the BugSplats - crashes should never happen.)
                                      Has anyone checked if there is an update to Artisan?
                                        ThomThom, I installed the latest from EW yeaterday but I didin't check with Dale to see if he's got a newer version that hasn't been posted there. I sent the splat I got if it helps.
                                        • dereiD Offline
                                          derei
                                          My Artisan is also 1.2.4 (just checked) and I use SU2015, so any Observer Changes introduced in 2016 should not affect me. Still, the Undo is nod done in one go, but it undoes every single step as you can see in my previous post.
                                          • BoxB Offline
                                            Yes it appears you have a different problem. Is your graphic driver up to date?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
