    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 172.5k Views 95 Watching
    • C
      cmoreink
      I bought the original SDS tool few years ago. I use it with my SU8 but since upgrading to SU2015 and installing the original SDS on SU2015 all icons are "green smiley faces" and I have no problem with that because if I point my cursor on one of the icons it tells me what tool it is but I want to upgrade to a new version with new tools.
      Q: how do I upgrade to the new version with new tools added?
      Q: will I have to pay for upgrade?
      ok, just went to extension warehouse and downloaded the new version. It says "free to use for 15 days... after a license must be purchased..." I also read it's free upgrade if I have the original one (I do) but with the original one there was no license, so how do I go about the free upgrade??? wi
      Problem, so I'm in extension warehouse>Atisan Oganic Toolset>click on download (directs me to same page with install button)>click on install (opens page with terms and conditions of use and sings me out)>checked accept terms and conditions of use>click confirm> and nothing happens.... ???
      Ok, got it πŸ˜„ but how do I register now (I have the original SDS, no registaration back then) the new Artisan tool?
      my portfolio
      • dereiD
        derei
        One quick question: Artisan subdividing operation is not enclosed in start/commit operation? Each step is logged separately? I am asking this, because when I subdivide geometry and I need to undo it, it seems to have to do a lot of UNDOs, often ending somewhere in mid process of subdivision, having my geometry ruined, like parts missing.
        DESIGNER AND ARTIST DEREI.UK
          Seems not! Undo works fine! πŸ˜„
          • dereiD
            derei
            Well, mine seems different... a lot of UNDOs and ended up with mess...
            • BoxB
              You do seem to have some problems, as you can see here it is pretty much instant.
              Upload your component so we can see if the same thing happens for us or if it specific to your setup.
              • dereiD
                derei
                Hmm, this is most troubling. What do you mean by "specific to my setup" ? What kind of settings do you reckon may influence Artisan's Undo behavior?
                I attached the component here.
                Component_85.skp
                • cottyC
                  cotty
                  No problem here with undo...
                  click to animate
                  my SketchUp gallery
                    What versions of SketchUp are you guys using? And what version of the extension?
                    • cottyC
                      cotty
                      SU16-64 Pro, Artisan 1.2.4, Win10
                      my SketchUp gallery
                        No problem for me SU 64 make 2015 Windows 8.1 Artisan 1.2.4
                        for this all following
                        iterations 1 undo iterations 2 undo iterations 3 undo iterations 4 undo
                        • dereiD
                          derei
                          SU 2015 x64 / Win7 x64
                          Have no idea what version of artisan... because I don't know how to check for the version. There is nothing in Artisan Menu to tell me the version (or I can't find it)
                            But the version number is available in Preferences>Extensions.
                            FWIW, I tried undoing a subdivide and smooth operation after running it on your file and got a Bug Splat. SU2016, Win 7 x64, and current version of Artisan.
                            • BoxB
                              Same for me Dave, I was just about to post about it but got distracted.
                              Same Artisan version throughout.
                              Win7 64bit SU16 Bugsplat every time as soon as you undo
                              Win10 64Bit SU16 Bugsplat
                              However use SU15 on either machine and no issues.
                                This might be a result of changes made to the Observer system in SU2016. (At least the undo thing. Not sure about the BugSplats - crashes should never happen.)
                                Has anyone checked if there is an update to Artisan?
                                  ThomThom, I installed the latest from EW yeaterday but I didin't check with Dale to see if he's got a newer version that hasn't been posted there. I sent the splat I got if it helps.
                                  • dereiD
                                    derei
                                    My Artisan is also 1.2.4 (just checked) and I use SU2015, so any Observer Changes introduced in 2016 should not affect me. Still, the Undo is nod done in one go, but it undoes every single step as you can see in my previous post.
                                    • BoxB
                                      Yes it appears you have a different problem. Is your graphic driver up to date?
                                      • dereiD
                                        derei
                                        What the graphic driver would have to do with UNDO stack? And yes, my graphic driver is up to date.
                                        Undo/Redo should be managed by SketchUp and many operations can be packed in one single UNDO step by the programmer of the extension.
                                        The only other thing that comes into my mind is another plugin that gives me hard time... but I have no time to investigate, as I have LOTS of plugins and the only way to discover this would be to test Artisan by adding one plugin at a time... you can see my problem here.
                                        • BoxB
                                          You can disable half, then half, then half etc till you find it.
                                          • dereiD
                                            derei
                                            Well, after f*king-up all my plugins, some of them losing some settings (somehow they just don't seem to like to be disabled), I managed to find the guilty plugin: It was the LAYERS PANEL http://sketchucation.com/plugin/751-layers_panel
                                            Yup, great idea, good tool, dangerous tool... some dark creatures are lurking there in the deep, messing-up with the observers. I saw that the author made it publicly available... maybe someone will take it and improve it. Or maybe Trimble will think to use it to change the default Layers System after it.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 15 / 15
