    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 58.3k Views 24 Watching
    • JQLJ Offline
      JQL
      @skalp said:
      In the next 1.5 update the AutoCad export will be improved a lot!
      The Skalp Team
      Care to give us a sneak peak?
      Will we be able to export Skalp patterns that we manually painted on faces? Will it be this that will make me finally jump to skalp?
      www.casca.pt
      Visit us on facebook!
      • jujuJ Offline
        juju
        @jql said:
        The Skalp Team
        • JQLJ Offline
          JQL
          Thanks Juju! The reflected ceiling is a good one!
          Might be worth considering...
          www.casca.pt
          • Lemoyne ArchitectL Offline
            Lemoyne Architect
            @juju said:
            Skalp definitely takes SketchUp to the next level in doing construction documents.
            A question - the Thea Render integration is great, but will it work with others (VRay)?
            • facerF Offline
              facer
              My understanding is V-Ray is a rendering software program similar to Thea Render.
              Thea Render integrates with a number of modelling programs (as does V-Ray).
              This of current plugins in modelling programs by Thea is noted on their website:
              Thea Products
              Eshop
              (www.thearender.com)
              • SkalpS Offline
                Skalp
                No this will not work with VRay.
                The Skalp Team
                Skalp
                http://www.skalp4sketchup.com
                • jujuJ Offline
                  juju
                  Like SKATTER, I'm sure SKALP will be able to find a work-around to have it work with (just about) all rendering softwares
                    cadmunkey
                    You havent got Skalp yet?? You should have taken advantage of their black Friday sale a couple of weeks back. Wouldnt use sketchup without it now. πŸ‘ πŸ˜„
                    Any idea on release date of 1.5? I am working on a project now that could definitely use some of the new features!
                      Lemoyne Architect
                      The Skalp Team
                      Sorry to hear that.
                      • SkalpS Offline
                        Skalp
                        What function do you need for this project. We will very soon start with a beta problem.
                        The Skalp Team
                        Skalp
                          cadmunkey
                          The Skalp Team
                          The improved DXF export for sure. From the v1.5 preview video it looks like it will export entire elevations now and not just the section cut? Perfect for interior views.
                          I also wanted the Thea section cut renders, but after I posted I tried it on my existing model and that feature already works! I never knew 😲
                          • SkalpS Offline
                            Skalp
                            @cadmunkey said:
                            The Skalp Team
                            Yes the dxf exports sections including the front hidden lines, also in perspective mode. This new feature only works on SU2016. Send me an email guy@skalp4sketchup.com if you like to become a beta tester for this feature.
                            Guy
                            Skalp
                            • SkalpS Offline
                              Skalp
                              We are glad to announce Skalp for SketchUp 1.2, a nice first Christmas present to all our users!
                              This update looks like a minor update, but it isn't. To meet the specs of the SketchUp Extension Warehouse we had to rewrite a lot of code to workaround some SketchUp API limitations. Now this is done we get to focus on new features and improvements, but first we want to show you what we have done:
                              NEW: Easy fog setting tool. From the Skalp options menu a new Fog Settings section allows to define and activate SketchUp's fog at a distance relative to an activated Skalp section. This feature only works whenever your sectionplane is parallel to the viewport.
                              Changed: Way better support for SketchUp's UNDO/REDO operations. This represents some major rewrite work in Skalp's code. Changes are also made to the way Skalp links it's sectionplanes to each scene. Older Skalp models will be converted to the new format automatically. In some cases it might be necessary to relink a Skalp section to a Scene manually.
                              Improved: Skalp materials for different scales are no longer stored multiple times in the model. Scales are now using applied using UV mapping. Older Skalp sections will be converted to the new format upon first recalculation.
                              Change: Skalp patterns are now always stored in the model at a printscale of 1:1 Different drawing scales are based on and use this same pattern using UV mapping to implement the actual print scale on the model.
                              Improved: Skalp in-section edit tool now allows selection of nested component instances and groups. This eases assignment of Skalp patterns to nested objects.
                              Fix: Foreign language/special characters are now supported on Skalp section names, layer names, material names, tags and Skalp pattern names.
                              NEW: Save a Skalp Style to a file and load this Skalp Style to an other scene or an other model.
                              Skalp is now signed as a trusted extension for use on SketchUp 2016.
                              We are working hard on new features and improvements. New things must be tested: shortly we'll need extra beta testers for Skalp 1.5. One major new feature in Skalp 1.5 beta will be forward views included in DXF exports. If you can help us with testing this much improved and long requested feature in Skalp DXF export, please contact us at beta@skalp4sketchup.com.
                              We are always looking for awesome projects and user stories. If you like to share your Skalp experiences with the rest of the world please send your coolest examples to guy@skalp4sketchup.com.
                              Merry Christmas and a happy New Year!
                              The Skalp Team
                              Skalp
                              • utilerU Offline
                                utiler
                                Nice work, Guy and to all your team! You guys are really changing the way we can present documentation with some exciting things to come.
                                Merry Christmas to you all!!
                                Just Curious...
                                • SkalpS Offline
                                  Skalp
                                  Thank you! And nice to hear I get a team to help me developing Skalp for Christmas πŸ˜‰
                                  If you don't know, Skalp is just a two men company and we are located in Belgium.
                                  Skalp
                                  • utilerU Offline
                                    utiler
                                    Even more impressive then!
                                    Just Curious...
                                    • jujuJ Offline
                                      juju
                                      at SKALP:
                                      How's version 1.5 coming along?
                                      • jujuJ Offline
                                        juju
                                        @juju said:
                                        at SKALP:
                                        cough cough
                                        • jiminy-billy-bobJ Offline
                                          jiminy-billy-bob
                                          At Basecamp, they publicly said that they expected v1.5 to ship within 3 weeks.
                                          It was 10 days ago.
                                            coty82
                                            I just noticed in a post from last December they said that Skalp 1.5 will be able to include forward views into dxf support. Will this happend in this release? That would be really awesome!
                                            • 8 / 9
