    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 64.1k Views 24 Watching
    • SkalpS
      Skalp
      @cadmunkey said:
      @jql said:
      Will we be able to export Skalp patterns that we manually painted on faces? Will it be this that will make me finally jump to skalp?
      You havent got Skalp yet?? You should have taken advantage of their black Friday sale a couple of weeks back. Wouldnt use sketchup without it now. πŸ‘ πŸ˜„
      Any idea on release date of 1.5? I am working on a project now that could definitely use some of the new features!
      What function do you need for this project. We will very soon start with a beta problem.
      The Skalp Team
      Skalp
      http://www.skalp4sketchup.com
      • C
        cadmunkey
        The Skalp Team
        The improved DXF export for sure. From the v1.5 preview video it looks like it will export entire elevations now and not just the section cut? Perfect for interior views.
        I also wanted the Thea section cut renders, but after I posted I tried it on my existing model and that feature already works! I never knew 😲
        • SkalpS
          Skalp
          @cadmunkey said:
          The Skalp Team
          Yes the dxf exports sections including the front hidden lines, also in perspective mode. This new feature only works on SU2016. Send me an email guy@skalp4sketchup.com if you like to become a beta tester for this feature.
          Guy
          Skalp
          • SkalpS
            Skalp
            We are glad to announce Skalp for SketchUp 1.2, a nice first Christmas present to all our users!
            This update looks like a minor update, but it isn't. To meet the specs of the SketchUp Extension Warehouse we had to rewrite a lot of code to workaround some SketchUp API limitations. Now this is done we get to focus on new features and improvements, but first we want to show you what we have done:
            NEW: Easy fog setting tool. From the Skalp options menu a new Fog Settings section allows to define and activate SketchUp's fog at a distance relative to an activated Skalp section. This feature only works whenever your sectionplane is parallel to the viewport.
            Changed: Way better support for SketchUp's UNDO/REDO operations. This represents some major rewrite work in Skalp's code. Changes are also made to the way Skalp links it's sectionplanes to each scene. Older Skalp models will be converted to the new format automatically. In some cases it might be necessary to relink a Skalp section to a Scene manually.
            Improved: Skalp materials for different scales are no longer stored multiple times in the model. Scales are now using applied using UV mapping. Older Skalp sections will be converted to the new format upon first recalculation.
            Change: Skalp patterns are now always stored in the model at a printscale of 1:1 Different drawing scales are based on and use this same pattern using UV mapping to implement the actual print scale on the model.
            Improved: Skalp in-section edit tool now allows selection of nested component instances and groups. This eases assignment of Skalp patterns to nested objects.
            Fix: Foreign language/special characters are now supported on Skalp section names, layer names, material names, tags and Skalp pattern names.
            NEW: Save a Skalp Style to a file and load this Skalp Style to an other scene or an other model.
            Skalp is now signed as a trusted extension for use on SketchUp 2016.
            We are working hard on new features and improvements. New things must be tested: shortly we'll need extra beta testers for Skalp 1.5. One major new feature in Skalp 1.5 beta will be forward views included in DXF exports. If you can help us with testing this much improved and long requested feature in Skalp DXF export, please contact us at beta@skalp4sketchup.com.
            We are always looking for awesome projects and user stories. If you like to share your Skalp experiences with the rest of the world please send your coolest examples to guy@skalp4sketchup.com.
            Merry Christmas and a happy New Year!
            The Skalp Team
            Skalp
            • utilerU
              utiler
              Nice work, Guy and to all your team! You guys are really changing the way we can present documentation with some exciting things to come.
              Merry Christmas to you all!!
              Just Curious...
              • SkalpS
                Skalp
                Thank you! And nice to hear I get a team to help me developing Skalp for Christmas πŸ˜‰
                If you don't know, Skalp is just a two men company and we are located in Belgium.
                Skalp
                • utilerU
                  utiler
                  Even more impressive then!
                  Just Curious...
                  • jujuJ
                    juju
                    at SKALP:
                    How's version 1.5 coming along?
                    • jujuJ
                      juju
                      @juju said:
                      at SKALP:
                      cough cough
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        At Basecamp, they publicly said that they expected v1.5 to ship within 3 weeks.
                        It was 10 days ago.
                        • C
                          coty82
                          I just noticed in a post from last December they said that Skalp 1.5 will be able to include forward views into dxf support. Will this happend in this release? That would be really awesome!
                          • jujuJ
                            juju
                            I see that SKALP version 2.0.0135 is available on the sketcUcation pluginstore, on the SKALP website the latest is version 2.0.0124 and the one on EW seems to be even older (v2.0.0062). When installing the latest version, nothing is mentioned under Release Notes about the newer version number?
                            I'm hoping Guy (or someone from SKALP) could elaborate here.
                            • SkalpS
                              Skalp
                              Correct SketchUcation has a newer version!
                              We need to update the version on our own download page, but first we are doing some extra fixes.
                              We need to fix somethings before EW will update to the newest version 😞, EW still has the old 1.2 version.
                              The Skalp Team
                              Skalp
                              • SkalpS
                                Skalp
                                Skalp is an easy to use yet powerful Live Section Tool. Packed with key features, it is the missing link to realize a long standing dream: to go all the way from preliminary design to stunning construction documents, all within SketchUp!
                                Skalp
                                • utilerU
                                  utiler
                                  Hi guys, can you chime in on this post please?
                                  Seems to be something weird happening with cutting through a wall with an opening inserted into it.
                                  404 Not Found
                                  (sketchucation.com)
                                  Just Curious...
                                  • P
                                    PascalCoutu
                                    Hi, I'm new to Skalp and i'm having trouble with the resolution of the Skalp materials in Layout.
                                    Is the blurriness of the concrete material normal ? It seems awful to me.
                                    What I'm I doing wrong?
                                    Pascal
                                    Sketchup file
                                    • jujuJ
                                      juju
                                      edit (line weights / scale) the pattern in pattern designer
                                      • 9 / 9
