    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.1k Views 155 Watching
    • dereiD
      derei
      UNDO issue ...
      sometimes when I cancel JPP it lets the geometry with missing faces. Then I undo to get it back to its previous state...the problem is that i have to hit A LOT of UNDOs.
      Maybe the undo function should be reviewed and pack multiple phases in a single undo command.
      DESIGNER AND ARTIST DEREI.UK
      • C
        Ciacnorris
        Hi, I tried to install it on my PC, and I think it doesn't work on Windows 8.1.
        Are you gonna make it work on Windows 8.1 too?
        Really wanna try your plugin! 😄
        • P
          peterromao
          Hail to a very reliable extension which I have used countless times so far to give thickness to my sheets! Good Job!
          Today is the first time that I found an error with it.
          For some reason I cannot give this form a thickness.
          The ruby error I get is the following:
          Date: 07-Aug-15 19:49:31
          An error occurred in Joint Push Pull
          Error in generation of the geometry
          reference to deleted Entity
          JointPushPullGeometry.rb: 1027 -- entityID
          JointPushPullGeometry.rb: 1027 -- block in geometry_coplanar_edges_overhang
          JointPushPullGeometry.rb: 1025 -- each
          JointPushPullGeometry.rb: 1025 -- geometry_coplanar_edges_overhang
          JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges
          JointPushPullGeometry.rb: 352 -- each
          JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges
          JointPushPullGeometry.rb: 214 -- robot_call_action
          JointPushPullGeometry.rb: 177 -- geometry_robot_exec
          JointPushPullGeometry.rb: 160 -- geometry_robot
          JointPushPullGeometry.rb: 75 -- block in geometry_execute
          Lib6Operation.rb: 325 -- call
          Lib6Operation.rb: 325 -- step_geometry
          Lib6Operation.rb: 367 -- start_execution
          JointPushPullGeometry.rb: 75 -- geometry_execute
          JointPushPullTool.rb: 891 -- go_preview_or_geom
          JointPushPullTool.rb: 697 -- dragging_stop
          JointPushPullTool.rb: 1319 -- onLButtonUp
          I have attached the object.
          Single sheet with openings.
            If you JPP OUTWARDS it works OK.
            Extruding INWARDS will fail.
            This is because you have some tiny geometry in the surface - e.g. the segmented edges around the slotted holes semi-circular ends.
            When extruding 'inwards', SketchUp's tolerance of 1/1000" can cause some tiny edges to be omitted - their start/end points are deemed coincident - then the faces relying on those also fail to be created.
            But all is not lost...
            You can JPP INWARDS if you do the following...
            Make your group into a component.
            Make a copy of it and Scale that x100.
            Edit that instance and Preselect its surface.
            Activate JPP - making x100 allowance in the offset value.
            It will now extrude successfully.
            Exit the edit and delete the scaled version.
            The real size version will also show the JPP changes.
            Tiny geometry can exist but it cannot be created directly in SketchUp.
            The "Scale up a copy of a component" trick is a well known workaround for these kinds of issues...
            • P
              peterromao
              Hello TIG,
              Awesome!!!!
              That was an excellent reply. It worked. Thanks for the heads up. I recall doing something of the sort in the very distant past but if it weren't for your reminder I would have never gotten there!
              Thanks again!
              Peter
              • JQLJ
                JQL
                Fredo,
                We are able to push pull by vector keeping original face orientation or by creating the ending faces as normal to the push pull vector. This is great!
                Do you think it would be possible to pick any face in the project as the ending faces plane?
                Thanks and best regards,
                João
                www.casca.pt
                Visit us on facebook!
                • fredo6F
                  Joao,
                  This is technically feasible, but more a matter of UI, which is already complex for users, as you know.
                  I'll see what I can do when I refresh the plugin.
                  • JQLJ
                    JQL
                    @fredo6 said:
                    Joao,
                    I understand perfectly.
                    It's also something that would be good to have but that can be achieved manually. I hope you find the time to include it someday.
                    Thanks again,
                    João
                    www.casca.pt
                    • dereiD
                      derei
                      Two changes would be great for this plugin, as it works somehow against "intuition":
                      -first would be Press RETURN to exit (that's the ENTER key, and usually is used to CONFIRM a action, not to cancel it) - best would be to use ESC Key
                      -second would be the obligation of inserting push value with (-) AFTER the push action was initialized. It is great to let the option there, in case the user really needs to revert the direction, but it would be better that once a number was introduced, to take "by default" the pushing direction already initialized by the user.
                      Another thing is that AFTER doing a JPP operation, I must be very careful what tool or key I press, or I risk to have my operation canceled... this is extremely frustrating, as there is no intuitive action. As I said before, I am tempted to press ENTER - but guess what? I cancel my work. If I press Space Bar (to go to select tool) it happens the same, if I click on screen I also cancel the operation... every time is "lucky guess". In my opinion should be clear: ESC= Abort, ENTER=Commit. Nothing around. To not exit from operation until ESC or ENTER was pressed. This way there is no chance of mistake.
                      I hope this suggestions make sense.
                      Thank you.
                      • fredo6F
                        Do you have a model where this happens? It must be related to the Preview mode, when you have a lot of faces.
                        • Enter / Return is used to perform the Push Pull, so that you don't even need to drag the faces. The cursor must be still on one face, since when the cursor is in the empty space, it is used to exit the tool.
                        • Escape does Abort when in interactive mode
                        • Spacebar functions as in any Sketchup tool. If you did not commit beforehands, it simply exits with doing nothing.
                        • dereiD
                          derei
                          yes, I had many faces in the model (organic modelling)...
                          But why there are 2 different uses for ENTER (when cursor on face, or not on face?) Is possible that is why I miss it many times... because i move the cursor around. I am not used to pay attention to it when i don't actively use it to manipulate geometry. Do you think this behavior is actually useful?
                          Thanks for all explanations 😉
                          • JQLJ
                            JQL
                            Fredo,
                            Would it be easy to have normal push pull Taper with an angle or a offset distance instead of exclusivelly by ratio? It would be a nice feature to have for chanfering faces outside their plane with a double click. (I love this double click through groups/components)
                            www.casca.pt
                            • B
                              bapito
                              Where do i download it!!!???!!!
                                See the first post of this thread. It is clearly spelled out with bold type and links.
                                  Arctura
                                  Hi I'm having a small issue that I can't for the life of me understand.
                                  I'm extruding the wall of a truncated cone, or more like a rounded plate that along with 11 other identical plates will make up the cone. I'm trying to make flanges around the sides of one plate to then instance it, but the sides keep intersecting and I can't seem to control them! 😞
                                  I did manage to get it right at first, but there were some other issues with the model so I have restarted and this time around I can't get it to work.
                                  I'm using Joint Push Pull and Round Push Pull.
                                  Description of intersection problem
                                  • PixeroP
                                    Pixero
                                    I'm getting this error message when trying to Joint Push pull:
                                    ` [/Date: 21-Sep-16 09:11:28
                                    undefined method `smooth?' for nil:NilClass
                                    JointPushPullGeometry.rb: 1107 -- block in geometry_coplanar_edges_overhang
                                    JointPushPullGeometry.rb: 1105 -- each
                                    JointPushPullGeometry.rb: 1105 -- each_with_index
                                    JointPushPullGeometry.rb: 1105 -- geometry_coplanar_edges_overhang
                                    Lib6Operation.rb: 332 -- call
                                    Lib6Operation.rb: 332 -- step_geometry
                                    Lib6Operation.rb: 374 -- start_execution
                                    JointPushPullTool.rb: 892 -- go_preview_or_geom
                                    JointPushPullTool.rb: 698 -- dragging_stop
                                    JointPushPullTool.rb: 1320 -- onLButtonUp`
                                    • fredo6F
                                      @pixero
                                      Thanks for signaling. This seems to be an unusual case.
                                      Anyway, I have fixed the problem and will re-release soon.
                                        surfmike
                                        Hi. I'm having a problem with the plugin gui showing up really small in SU. See attached picture.
                                        I'm on SU2016, OS X 10.9.5.
                                        How can I make it bigger?
                                        //Mike
                                        it's small...
                                        • fredo6F
                                          //Mike
                                          [attachment=0:26p179xb]<!-- ia0 -->Screen Shot 2016-11-26 at 11.35.17.png<!-- ia0 -->[/attachment:26p179xb]
                                          Mike,
                                          If you go to Windows > libFredo6 Settings... > Default Parameters..., you will find an option "Retina Screen" in the section "Palette Configuration".
                                          If you check the option, you should get the palette buttons bigger (x 2). However, the text may remain small.
                                          If you are OK, and since you are on SU2016, you can help me to see if we can resolve the issue, if you are OK to test some changes in the LibFredo6 library. I was hoping that it would be solved by Sketchup 2017, but that's not the case!
                                          Otherwise, other high-dpi screen users have discussed some ways to avoid the issue by system set up. See discussion here.
                                          Fredo6
                                          • pbacotP
                                            What may I be doing wrong. Trying to pull up three surfaces sharing three edges.
                                            ate: 30-Nov-16 08:55:30
                                            Could not compute valid matrix from points
                                            JointPushPullGeometry.rb:: 1169 -- position_material
                                            JointPushPullGeometry.rb:: 1169 -- block in geometry_transfer_material_top
                                            JointPushPullGeometry.rb:: 1145 -- each
                                            JointPushPullGeometry.rb:: 1145 -- geometry_transfer_material_top
                                            JointPushPullGeometry.rb:: 337 -- block in geometry_robot_transfer_material
                                            JointPushPullGeometry.rb:: 337 -- each
                                            JointPushPullGeometry.rb:: 337 -- geometry_robot_transfer_material
                                            JointPushPullGeometry.rb:: 212 -- robot_call_action
                                            JointPushPullGeometry.rb:: 177 -- geometry_robot_exec
                                            JointPushPullGeometry.rb:: 160 -- geometry_robot
                                            JointPushPullGeometry.rb:: 75 -- block in geometry_execute
                                            Lib6Operation.rb:: 332 -- call
                                            Lib6Operation.rb:: 332 -- step_geometry
                                            Lib6Operation.rb:: 374 -- start_execution
                                            JointPushPullGeometry.rb:: 75 -- geometry_execute
                                            JointPushPullTool.rb:: 890 -- go_preview_or_geom
                                            JointPushPullTool.rb:: 696 -- dragging_stop
                                            JointPushPullTool.rb:: 1318 -- onLButtonUp
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 30
                                            • 31
                                            • 12 / 31
