    SketchUp 2016 is here....
    162 Posts 59 Posters 48.5k Views 59 Watching
      KrisM
      The perpendicular inference is great but you still can't inference to the world axes from within a component (which has a different axes orientation). πŸ˜’
      • david_hD Offline
        david_h
        well .. .Im a tad underwhelmed. I think I will hold out for 2017 where I am sure ALL the major wish items will be finally included.
        Frankly. . I have been wishing for one feature since version 5 and it doesn't seem to get any traction at all. I don't know if I know how to describe it very well or what. . but the one thing I would love sketch up to is to Hide visibility of nested components when you ware working on them. If I have window C and I have multiple C's in that component to able to hide all but the next C up in the tree for clarity sake would be awesome. right now with "hide rest of Model" it's an all or nothing thing.
          KrisM
          If you're holding out for 'All the major wish items" to be included, you might change the timeline to 2027. 😞
            Philw
            Clayton49
            Still like the old way better as it did not take up screen space and it just worked.
            its not just SKU, it other programs as well. They keep fixing whats not broken and not fixing what needs to be fixed.
              kaas
              @philw said:
              Clayton49
              +1
                rv1974
                Odd wishes. Why only 3, not 4?
                If it so crucial you could copy 3 instances of the component you are tweaking to the empty file on the next display and tweak there more discreetly. And paste it back when its OK.
                • dereiD Offline
                  derei
                  Is TREE (like branched hierarchy), not 3 !! πŸ˜„)) πŸ’š
                  DESIGNER AND ARTIST DEREI.UK
                  • david_hD Offline
                    david_h
                    well . .. of course I have been doing that as a workaround,but it seems to me to be a thing that would be a nice feature. but since I seem to be the only one clamoring for this. .
                    • pbacotP Offline
                      Just wonder what that means, david.
                      • david_hD Offline
                        david_h
                        i dunno...i'll just shuddup and wait in my corner for 2017 or 18. . .19. .
                        • pbacotP Offline
                          I mean, I don't follow the wish item.
                            slbaumgartner
                            I think what is confusing in david_h's request is the meaning of "next C up in the tree". I suppose "tree" means a structure with components nested inside components that are nested inside other components? Then the phrase might mean the instance of C nested in the component that contains the one currently open for edit? Alternatively it could mean sibling C's nested in the same component or all except those nested in the same component. So, the issue isn't with whether it is a good request but with understanding what it means!
                            • david_hD Offline
                              david_h
                              Yeah! what he said! πŸ’š
                              So.. .I didn't explain it well . .as I figured I wouldn't. All I meant was that if you have a structure of nested components--a nice feature for me would be to have a control on the visibility of said components when editing so that when instead of "hide rest of Model" you get can see all or some of the other components in the tree but not the rest of the model. For example . . if I have a component B in Model A I can work on Nested F component but maybe only see E or D not everything else?
                              A>B>C>D>E>F
                              There. That should make it much more clear right? πŸ˜’
                              Now I feel bad cuz I hi=jacked this thread. I'll shuddup now.
                              • pmolsonP Offline
                                pmolson
                                I have been using 2016 for a few days now, and I have no complaints.
                                I do have a question though.
                                Is there a way to dislodge the layers dialog box from the default Tray. I like the tray, especially with autohide enabled, but I would like to get the layers dialog out of there and float it wherever I want.
                                I tend to have a lot of layers and the tray forces me to awkwardly scroll up and down to access.
                                Paul
                                  kaas
                                  @pmolson said:
                                  Is there a way to dislodge the layers dialog box from the default Tray. I like the tray, especially with autohide enabled, but I would like to get the layers dialog out of there and float it wherever I want...
                                  Create a new tray just for the layers and drag it off the docked position (double click).
                                  Window-manage trays-new etc
                                  • pmolsonP Offline
                                    pmolson
                                    Thank you!
                                    • pmolsonP Offline
                                      pmolson
                                      I created the new trays as you instructed and it worked great.
                                      A follow up questions if you don't mind.
                                      in the image below I am showing my newly created trays docked on the right side under the default tray.
                                      I like it because when I access the new trays I get a full length dialog box allowing me to see a nice long list of layers or components at a glance. or I can dislodge it and drag it onto another screen.
                                      When I opened a new drawing the new trays were not there. Are they really drawing file specific?
                                      is there a way to set them to be part of my standard template file?
                                        kaas
                                        @pmolson said:
                                        ...When I opened a new drawing the new trays were not there. Are they really drawing file specific?is there a way to set them to be part of my standard template file?
                                        Strange, I just tested it and when I open a new session they are in the same position where I left them when I closed SketchUp.
                                        Not sure whats happening here. Maybe a rights-issue?
                                        • JQLJ Offline
                                          JQL
                                          If you have two sessions open and close one that has the desired layout AND THEN close one that is incorrect, when you open sketchup the last one is the one saved, so it's the incorrect layout.
                                          You should set things up with A SINGLE sketchup instance open and it should save correctly.
                                          www.casca.pt
                                          Visit us on facebook!
                                          • pmolsonP Offline
                                            pmolson
                                            Worked like a charm.
                                            • 6 / 9
