    SketchUp 2016 is here....
    162 Posts 59 Posters 54.4k Views 59 Watching
    • soloS
      edit lines to components is actually called S4u-to components
      • Clayton49C
        Clayton49
        @solo said:
        [attachment=0:pxnbjdin]<!-- ia0 -->TOOLBAR.jpg<!-- ia0 -->[/attachment:pxnbjdin]
        Thanks Pete,
        I'll now check these out.
        Over & out,
        Clayton.
        %(#008000)[Trotman & Taylor
        Architectural Consultants]
        • cottyC
          cotty
          Just to make clear: some of them are commercial plugins ($) and Skatter isn't yet published (but will be commercial too).
          my SketchUp gallery
          • P
            Pherim
            Anyone else noticed that when using a tool from any toolbar other than those native to SU, it is no longer highlighted in the toolbar? This even includes the extension toolbars that come with it, like Sandbox Tools and Dynamic Components. Not a big deal, but a little puzzling indeed.
            • JQLJ
              JQL
              Had never noticed it... It's true! 😲
              www.casca.pt
              Visit us on facebook!
              • Clayton49C
                Clayton49
                To all,
                SketchUP/Layout improvements for the recent 2016 release as listed below may not please everyone I’m sure. However any improvement to software we use has to be welcomed, especially when it seems SU HQ release updates each year.
                SKETCHUP
                Trimble Connect
                Reload Components with 3D Warehouse models
                Generate Report 2.0
                Enhanced inferencing and tool improvements
                Customizable Utility Trays on Windows
                Refreshed Textures
                Support for High DPI Graphics
                Extensions Loading Policy
                Welcome Dialog Refresh
                Knowledge Center Update
                Support for El Capitan and Windows 10
                LAYTOUT
                LayOut cloud references
                Small dimensions
                LayOut layers
                Optimized PDF Export from LayOut
                Documentation Improvements
                For me, the main ones are: Enhanced inferencing, Small dimensions, LayOut layers & Optimized PDF Export from LayOut.
                One item I thought was way overdue for improvement is the SU layer dialogue. So I’ll just have to WHISH-LIST this one for SU 2017. In the meantime I’ll keep on using the superior layers dialogue EXTENSION called Layers Panel by Jiminy-Billy-Bob. It does some of the stuff I note below a good Layers dialogue should do in my opinion.
                Layer Folders for specific layer names.
                Move to layer by selection.
                Layer on/off by selection.
                Layer as active by selection.
                Layer active only by selection.
                Layers all on.
                User to dictate layers order, not alphabetically, i.e. an move up/down arrow button with lock order.
                I also wondered what direction SU HQ were taking in terms of future development, I even muted it may even start looking at some form of basic parametric building elements for certain disciplines in the construction industry. Obviously I was getting way ahead of myself as I see their website now firmly stamps third party developers for this with add-on EXTENSIONS. Being an Architectural Consultant in the UK, any parametric software tools for Designing Buildings for Planning & Building Regulation Approvals for Construction would be key for me. EXTENSIONS may provide this, but I would favour these to be in-house as EXTENSIONS sometimes aren’t initially compatible with new SU releases or may even fall by the wayside.
                From what I understand, FORM-Z & RHINO+VISUALARQ have taken this “in-house” direction & thus may be a consideration for people in the construction industry looking for a similar product as SU.
                Over & out,
                Clayton.
                %(#BF0000)[I posted the above on the SU-FORUM, it might be an idea for all expecting more.. 😡 😡 from SU-2016 to cut+paste their comments to this forum as well, just a thought...... 😒]
                Over & out,
                Clayton.
                • P
                  Philw
                  "- You can still revive the old way if you make a tray per inspector and use a short cut to call it as you probably did before. You can also use that shortcut to toggle it on and off wich is great!"
                  Not sure what you mean,
                  What I don't like with the new tray is the space it takes up on my screen, even when its rolled up I need to adjust the tray to take up less screen space. in SKU2015 and prior I didn't have to do this.
                  My 2015 Setup
                  2016 setup so far
                  • Clayton49C
                    Clayton49
                    For more screen "yardage" double click the trays to fix to right hand side of screen, then you can pin-it or un-pin-it, the latter it slides back to right hand side of screen & pops out when you ghost the mouse pointer over the tab.... 😎
                    Over & out,
                    Clayton.
                    • TommyKT
                      TommyK
                      I've noticed how inferencing has got better. Not just the new parallel/perpendicular feature. Especially noticeable when using the rotate tool - it snaps to edges now - before it only snapped to points in most situations. Inferencing in general feels much more successful. It's a big productivity plus for me, more valuable than any new feature.
                      • K
                        KrisM
                        The perpendicular inference is great but you still can't inference to the world axes from within a component (which has a different axes orientation). 😒
                        • david_hD
                          david_h
                          well .. .Im a tad underwhelmed. I think I will hold out for 2017 where I am sure ALL the major wish items will be finally included.
                          Frankly. . I have been wishing for one feature since version 5 and it doesn't seem to get any traction at all. I don't know if I know how to describe it very well or what. . but the one thing I would love sketch up to is to Hide visibility of nested components when you ware working on them. If I have window C and I have multiple C's in that component to able to hide all but the next C up in the tree for clarity sake would be awesome. right now with "hide rest of Model" it's an all or nothing thing.
                          • K
                            KrisM
                            If you're holding out for 'All the major wish items" to be included, you might change the timeline to 2027. 😞
                            • P
                              Philw
                              Clayton49
                              Still like the old way better as it did not take up screen space and it just worked.
                              its not just SKU, it other programs as well. They keep fixing whats not broken and not fixing what needs to be fixed.
                              • K
                                kaas
                                @philw said:
                                Clayton49
                                +1
                                  rv1974
                                  Odd wishes. Why only 3, not 4?
                                  If it so crucial you could copy 3 instances of the component you are tweaking to the empty file on the next display and tweak there more discreetly. And paste it back when its OK.
                                  • dereiD
                                    derei
                                    Is TREE (like branched hierarchy), not 3 !! 😄)) 💚
                                    DESIGNER AND ARTIST DEREI.UK
                                    • david_hD
                                      david_h
                                      well . .. of course I have been doing that as a workaround,but it seems to me to be a thing that would be a nice feature. but since I seem to be the only one clamoring for this. .
                                      • pbacotP
                                        Just wonder what that means, david.
                                        • david_hD
                                          david_h
                                          i dunno...i'll just shuddup and wait in my corner for 2017 or 18. . .19. .
                                          • pbacotP
                                            I mean, I don't follow the wish item.
                                            • 6 / 9
