    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      BeePee
      ISSUES SKINNING A TWISTED PART
      Hi All, I love Fredo Scale and Curviloft. However, while the results look great on screen, I'm wanting to export the parts for 3D printing. I'm finding there are LOTS of healing issues with the parts I've altered using these plugins.
      I attach a JPEG and STL of the part I'm trying to skin and place in a box section. It's a short bar twisted 180 degrees. It's actually one of an intended series of these inside of a harmonica comb intended to re-direct air from an upper to a lower reedplate, hence the small size).
      You can see from the STL that the twisted bar has lots of holes on the outside edges, and skinning doesn't fix these. When I export to my 3D printer software the part looks a real mess and won't print.
      Can one of you experts check the file and let me know how to overcome this?
      Thanks! Brendan
        driven
        @beepee said:
        I attach a JPEG and STL of the part ...
        hi Brendan
        no files attached, but for most of these types of operations in SU you need to scale up 100 times, do the transforms, thens scale back down for export...
        SU can't make tiny triangles, but can use and export them if they are scaled down from existing larger ones...
        that's most likely your issue..
          BeePee
          John - sorry for the delayed reply, I couldn't see my post when I first looked but came back later and saw your advice.
          I followed it and hey presto, it worked! I scaled up massively, did the twisting and skinning, and after scaling down to the correct size, it stayed healed and looks fine in my 3D printer slicing software.
          Thanks so much πŸ˜„
          Cheers, Brendan
            jgt1942
            How about a video with english audio. I've watched the existing videos and have not found them helpful because I really don't know what is being done.
            How do I scale an object to a desired dimension. Example I have a 6" dia pipe and I want it to be 5" dia. I click the center handle and attempt to get the desired dia but cannot lock in on the desired 5".
            jgt
              It's me or we can only "Stretch" a Pipe in "vertical" Z ?
              • fredo6F Offline
                Pilou,
                You have to explode the curves of the cylinder
                • pbacotP Offline
                  I use Fredoscale Stretch A LOT to make different versions of the same window type. I wonder if these modifications would be difficult or impossible--and if they might happen someday:
                  1. If nested components are unchanged in the operation have them stay the same definition.
                  2. If nested components are changed in the operation, make them "unique" with new name (how it works now).
                  3. Do this for all nested components. (At present I am not sure what rules apply. If I have components, say a muntins in a sash, and I stretch the window: The sash which is used in other windows might not change in those non-operation components (it becomes unigue), but the muntins might be affected in those other windows--which isn't desirable.)
                  4. If multiple instances of the same component are changed in the operation AND they remain identical to one another--make them unique from the old version but the share the same definition (e.g. two identical window components in the same assembly).
                  oh, and an aside: Is there a way to have the divider always on by default? It never is and the hot key doesn't work for me (on a Mac).
                  Thank you for the wonderful plugins. I use them A LOT. πŸ˜„
                  • fredo6F Offline
                    These suggested enhancements can be done and make a lot of sense actually.
                    I think that the current behavior if that all components and nested components are made unique.
                    Indeed I have to dive again into the code which is now old for me.
                    For the divider, you have an option in the Default Parameters dialog box to enable or disable the Divider (and also the slicer for Bend) by default.
                      Dcch
                      ayuda no puedo instalar el plugin me da error indandome que no tengo la actualizacion, gracias de antemano
                      • fredo6F Offline
                        NEW RELEASE: FredoScale v2.8a - 13 Nov 15
                        FredoScale 2.8a is a maintenance release for bug fixing
                        • dereiD Offline
                          derei
                          FredoScale doesn't allow absolute input? I must admit, I never tried before, but as the native SketchUp Scale tool accepts absolute input (scale to 100mm -> will scale to match size, not the scaling ratio), I just needed to scale very precisely with FredoScale and it seems to not work like that.
                          Please confirm. Thanks
                          DESIGNER AND ARTIST DEREI.UK
                          • pbacotP Offline
                            Yeah it does. (not the same method as SU tool though)
                            • dereiD Offline
                              derei
                              Would you please tell me how, then? πŸ’š
                              Much appreciated.
                              • massimoM Offline
                                massimo Moderator
                                Much appreciated.
                                -Pick a tool;
                                -click on a handle. You can press CTRL if you want to scale symmetrically from the centre;
                                -press TAB key;
                                -input a measure;
                                -click OK or press ENTER.
                                • E Offline
                                  etzaelpinon
                                  -it Dies pretty easily when organic components selected and or when a small group of drawings selected.
                                    An example or two would help...
                                    Otherwise Fredo would need to rely entirely on his ESP...
                                      sasasaps
                                      Hello everyone,
                                      Amazing plugin! But, the more I use it I go finding some problems, I donΒ΄t know if they are common bugs or just limitations of the plugin.
                                      I usually have problems at exploding, grouping or regrouping geometry that has been sheared preaviously (I have just noticed it when using "shear").
                                      The reshaped elements or components return to their original shape, (previous to FredoScale), after doing any of the operations listed:
                                      • after exploding a reshaped group. (sometimes)
                                      • after "copying-pasting out" a plane from a reshaped group.
                                      • after grouping a set of reshaped groups.
                                        dozer157
                                        Download LINK? -_-
                                          @dozer157 said:
                                          Download LINK? -_-
                                          It's very clearly spelled out in the first post of this thread.
                                          • masterpaulM Offline
                                            masterpaul
                                            Can I use this to scale a component without scaling any inner components/geometry (just increasing and decreasing the space between objects)?
                                            I.E there are 20 sub components in the the component and I would like the components to remain the same size while scale, and only the size between the components to shrink and expand proportionally.
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 56
                                            • 57
                                            • 45 / 57
