    SketchUp using all cores off the processor!!!
    22 Posts 13 Posters 22.4k Views 13 Watching
    • honoluludesktopH
      honoluludesktop
      Hi tim, Have no idea what you are talking about, but you seem to have the inside track to SU. Not that it matters, but what is it written in? My guess was based on similar behavior I have with a solid modeler written for Win95. I switched to SU because support for that program ended. Btw, it (Trispectives) still run on current hardware, and WinXP; in addition, I continue to support some old programs by coding with a pre 2000 compiler.
      • K
        kwistenbiebel
        I am having a déja vue feeling with this thread, although I share the concern.
        Bottom line is: Sketchup is slow on a medium to high polycount and needs to get faster. The way they do it doesn't matter....
          Fully agree. I don't think it's right of us to make assumptions on how they make it faster. We don't know the architecture of Sketchup.
          • honoluludesktopH
            honoluludesktop
            C++ would have been my guess. I have not kept up with the development of programming languages, so how are older libraries used by newer compilers? Can they be? Don't really understand OO, and when I am forced to program, I use Visual Basic. The system hides the OO process, and lets me think of the program structure in a conventional (procedure like) way. Guess I am one of the bad guys:-)
            Btw, Didn't I read elsewhere here that is may not the high polycount that is the problem for SU, but the way textures are handled?
              When I was referring to the architecture of SU I didn't mean the programming language they used, but how they structured their code and inner working.
              Textures does slow it down, but even with plain default materials SU will bog down with high polycount.
              It's most likely a compound of causes for it.
              • KrisidiousK
                Krisidious
                So this older program I have uses this command called +fullproc. It's supposed to make the program use all cores or threads. I wonder...
                By: Kristoff Rand
                  slbaumgartner
                  I doubt it. Programming to use multiple threads or cores effectively requires techniques to split up the workload into pieces that can proceed in parallel and to synchronize the results afterward. This is far from easy or automatic, and is not even possible for some kinds of tasks.
                  • K
                    kokoriko17
                    Ok so bottom line, no multithread support in the next year or so ?
                    It's astonishing that even with a Core i7 3.9GHZ 4C/8T, PCIE SSD , 32GB of RAM and GTX 780, I have to wait 5 hours to clean up a 110 MB high details file because my CPU usage is 15% at max while rendering the scene at very high details takes 4 hours.
                    Also with complex models, I get a lot of hiccups and sluggish performance and it's definitely not my Nvidia as GPU-ID reports 10-20% GPU usage while sketchup is freezing or not responding most of the time with 15% CPU load ( the maximum it can use ).
                    I'd swear by sketchup if it were multithreading.
                    • pbacotP
                      What process are you doing that you wait 5 hours? CleanUp plugin or ..?
                      What? So to be clear: You hit a scene and wait 4 hours to see it on the screen. Or is this for some sort of output like pdf? Until it gets faster, break up your files. If it's details, why put them all in one file?
                      Hiccups. Yeah the autosave for large files is a pain. As someone noted regular save is relatively fast, so why is autosave slow?
                      • K
                        kokoriko17
                        Hello and thanks for your reply; Yes the cleanup plugin takes too much time. Not that I am trying to compare sketchup to Autodesk products but Autosave usually doesn't lag me that much as I'm on a PCIe SSD ( 800+ MBps read/write ) I hit save as and it takes 2 seconds to save a 150MB sketchup file.
                        It's not only about the cleanup. For instance if I want to import and obj file using Simlab plugins sometime it takes 20-30 mins depending on the file size because only one thread is active out of 8.
                        I understand that OBJ files can be complex but after cleanup they shrink significantly.
                        Here's an example of a scene I'm rendering with sketchup ( needs 14 hours to finish ) :
                        https://i.gyazo.com/b5a83d70e37499377fd65838cf61ece7.jpg
                        Before cleanup file size was around 350MB then it went down to 74MB but it took literally 20 hours to finish the cleanup.
                        • pbacotP
                          Looks like that's going to be a nice render!
                          Not that this is going to save you tons of time, but I only use CleanUp as I work, only on select parts of the model, nothing too big.
                          • JQLJ
                            JQL
                            @kokoriko17 said:
                            2 seconds
                            That's too long!
                            Frame your model nicelly and save. Then turn off thumbnail generation on "Model Info".
                            www.casca.pt
                            Visit us on facebook!
                            • K
                              kokoriko17
                              @jql said:
                              @kokoriko17 said:
                              2 seconds
                              That's too long!
                              I understand that but if you need your render to look nice you need to import some complex models ( flowers, vase, figurines etc.. ) and these really hit sketchup hard. Check the remaining time for just merging faces :
                              https://i.gyazo.com/4e931721b6b7ebbfe6b30a6cdc7fce8f.gif
                              https://i.gyazo.com/84871df464dd17f5a5534c4b58b5137d.gif
                              • JQLJ
                                JQL
                                I just said that with my SSD AND without thumbnails, I don't get 2 secs saves. I don't even notice saving anymore.
                                You should use proxies for that sort of stuff.
                                Merging faces is not saving a model, it's a complex face operation like explode or import.
                                www.casca.pt
                                • K
                                  kokoriko17
                                  My problem is not the rendering, I can render relatively quickly. But the problem with Sketchup itself.
                                  I have been trying to load a 118 MB skp file into sketchup but it took over 6 hours. What's funny is that 3DS Max could load it in 2 mins.
                                  We can't deny that Sketchup is slow, really slow and I refuse to leave it for basic modeling as it has a lot of potential to compete with the big 5 but then we need a major update.. maybe a complete re-written Sketchup.
                                  https://i.gyazo.com/594ff8247346cbb22599d244f39c1cb5.png
