    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    159 Posts 50 Posters 218.7k Views 50 Watching
      The plugin is known to work for others using SU8. You haven't given us much to go on. Perhaps you could post the model so we can see what you are working with?
      • formanosqueF Offline
        formanosque
        Fredo a réécrit un plugin qui semble très bien macher... RadialMove. La gestion des unités est OK, le déplacement n'est dépendant de la position en coeff mais bien le nombre de cm, mm depuis le centre.
        Fredo have rewritten a plugin which seems to works perfectly... RadialMove. Units management is fine, move fonction doesn"t depend on a coeff but the real unit of the move from the center.
          DRDS-11
          I am using SU 2015 Pro on a Macbook Pro. Will the latest version of this plugin work with my software? What is the latest version of the plugin? Can you send it to me or post it for download?
          Thanks.
            @DWR
            A few posts ago someone with a MAC and v2014 posted an example SKP.
            So it seems like it should also work with v2015 - which also uses the same newer Ruby etc.
            It IS in the SketchUcation PluginStore http://sketchucation.com/pluginstore?pln=Eclate_Deplace
            It is called 'Exploded View' in English...
            Download its RBZ from there, then install it using SketchUp > Preferences > Extensions > Install... button, OR AutoInstall it directly from the SketchUcation PluginStore dialog within SketchUp itself [install it from the RBZ obtainable from the Resources menu above...]
              Seems working fine in 2015 😄
              (Select your Components / Groups then Right Click ! )
              • ARTchiA Offline
                ARTchi
                The plugin is not bundled with another plugin, which would spread out the groups/components with other nested groups/components 2 and 3 orders? Groups/Components in the groups/components.
                Often the model consists of many sub-groups inside another group, with the explosion of the models can be converted to polygons , and some will be less nested. Need a plugin that would put such complex groups/components, simple one nested (first order) groups/components?
                I hope clearly explained!
                • F Offline
                  faustfa
                  hi guy
                  i have a little problem with this plugine , i am new of sketchup 2015 , how can install it??
                  i tryed to insert in zip file and rename .rbz and bye window --> prefernce ---> install extension , try to install but but noting , i try to create a folder plugin and put inside a .rb file but nothing , everyone have some idea ?? thankz
                  • chriC Offline
                    chri
                    @faustfa said:
                    hi guy
                    hi
                    the best way is to instal and used the plugin store to install this plugin
                    ( take a look on the next parts )
                    link to instal the pluginstore
                    Chri
                      @faustfa said:
                      ...i try to create a folder plugin and put inside a .rb file but nothing...
                      Remove any Plugin folder you have created. SketchUp creates its own folder. Install it the way chri has shown you and all should be well. Or download the .rbz file from the Plugin Store and install it using Preferences>Extensions>Install Extension...
                      • ashscottA Offline
                        ashscott
                        This is beautiful, thankyou Pilou
                        Just some stuff I do with Sketchup.
                          SpookyChick1013
                          Ken referred me here, from the plugin request I made. This is almost what I was looking for; works quite well too.
                          Is there anyway that capability to handle a specified range of distances, could be added? Essentially being able to enter minimum distance / maximum distance, and then execute is the work flow I'm looking for.
                          Thanks,
                          Cathryn Shaw
                          https://kuromatsudriveyards.com
                          Fo-su to tomo ni aran koto o...
                            I made the first stone, CPlassais has made the 99 % missing! 😉
                              shdesign
                              @SpookyChick1013 Wonder why you haven't had a reply? I think we all want this.
                                It's been nearly six years since this extension was last updated. It could be that the author lost interest and moved on to other things. There have been several changes to Ruby in SketchUp versions released since this script was. I wouldn't be surprised if it doesn't work with later SketchUp releases.
                                  Yes I have no news from this guy from years now! 😞
                                    cesom
                                    Salut Pilou,
                                    Tu aurais mis à jour ton extension par hasard ? Elle fonctionne à partir de 2017 jusqu'à 2021 ? Elle me parait très intéressante pour les éclatés.
                                    Je te remercie
                                    Jerryvento
                                    ►►►►► TUTOS FREE GRATUITS SKETCHUP YOUTUBE ◄◄◄◄◄
                                    ►►►►► DISPLAY THE SUBTITLES
                                      Non, plus de nouvelle de CPlassais le developpeur principal! 🤓
                                      Il fonctionne parfaitement jusqu'à la 2017, ensuite, aucune idée pour les versions suivantes ne les ayant pas! 😳
                                      A mon avis peu de chance, à tester, car je crois me rappeler que la version de Ruby avait changé!
                                      Le Plugin apparaît sous le Clic Droit sur une sélection de Groupes et/ou Composants! 🤓
                                      Il faut toujours avoir une version 2017 Make sous la main...ça peut toujours servir! ☀
                                      En plus c'est gratuit et même en français! 😎
                                      Il faut scroller, moletter pour avoir la version idoine! 🎉
                                        DRDS-11
                                        I have some questions regarding this plugin….I have used it a few times, but I really would like a little bit of a primer for it.
                                        When activated on a model it asks a few questions which are no problem to understand, but the dialog box needs some explanation as to what each of the boxes does to the model without me continuing to run trial and error over and over.
                                        A descriptor for each box would be helpful in my own opinion. I know it’s an old plug-in, but it is still useful.
                                        Thanks for anyone and everyone’s insight and direction.
                                          I am affraid but these 2 dialog boxes are self-explainatory! 😄
                                          Idem for parameters!
                                          Have fun éclatement! ☀
                                          • 8 / 8
