    Unreal 4 Engine
    extensions
    87 Posts 20 Posters 27.6k Views 20 Watching
    • jenujacobJ Offline
      jenujacob
      @cmeed said:
      Play up tools - might be cooking up something for unreal4.
      Indeed they are!! πŸ˜„
      http://playuptools.blogspot.ae/2015/10/unreal-engine-4-exporter-teaser.html
      • cmeedC Offline
        cmeed
        Great stuff!
        Curious to see how play up tools will get round the uv issues when exporting from sketchup. I'm very excited though.
        • cmeedC Offline
          cmeed
          Play up tools as mentioned are making a SU 2 Unreal4 exporter. Not sure if this will speed things on but they having a vote to see what games engine people use. Use the link above and vote for unreal4
            Do you make something special or have you some tricks for loading this prog and launch it? (UE4)
            I am registered - loading it etc...
            But when I launch it I am not accepted by their server!
            You must buy something even it's a personnal free version?
            The Helper page is a nightmare!
            https://wiki.unrealengine.com/Troubleshooting_Launcher_Problems
            It's a pity because it seems more friendly than Unity! πŸ˜„
              kaas
              @pilou said:
              ...I am registered - loading it etc...
              It's free. I have been using it and didn't need to pay anything. Look on the forum's, not in the wiki.
              Your connection problem has been reported before:
              https://forums.unrealengine.com/showthread.php?75206-Error!-Connection-to-server-failed
                Thx for the super trick! 😎
                Excellent! The "-http=wininet" at the end of the Properties of the Right Click on the Epic icon works fine! πŸ‘
                Just now loading the 5.8 Gigas ! πŸ’š
                  kaas
                  @pilou said:
                  ...The "-http=wininet" at the end of the Properties of the Right Click on the Epic icon works fine! ..
                  Nice it works now. Strange though you needed the trick. At my system (Win7X64) it just worked fine without it.
                  • cmeedC Offline
                    cmeed
                    Great that it works pilou!
                    I'm still trying to get a simple model to work
                    There are many things that can go wrong but try here
                    (youth.be)
                    This person seems to have got simple stuff in.
                      kaas
                      @cmeed said:
                      ...I'm still trying to get a simple model to work ...
                      I did several (simple) projects already with UE and SU so maybe I can help. Could you post the model?
                      Also, the youtube link doesn't work for me?!
                      • cmeedC Offline
                        cmeed
                        Try this.
                        http://youtu.be/PyYRz9h-eJU
                        Kaas - i'll get back to you I need to have a bit more of a place tried a couple of times and it was sort of working last night.
                          kaas
                          @cmeed said:
                          Try this.....
                          I just had a look at the videos. Its nice he/she did take the effort to try to explain his/her 'workflow'. I would suggest though to look for another source of information to really get a really useful workflow going for more complex scenes, nice results and acceptable calculation times.
                            OK UE4 works fine! πŸ˜„After hours of loading! πŸ’š
                            Does it normal it works not in "Local" so you must have start from Internet site of UE4 ?
                              Curious that is not existing an SKP direct format!
                              In Unity you import directly an .SKP file! πŸ€“
                              Maybe there is a trick like Load the .SKP file ( Texture + material) in Unity
                              Save it with a format compatible with UE4
                              Relaod it inside UE4
                              • cmeedC Offline
                                cmeed
                                theres a few post on the ue4 forums about supporting .skp but they don't seem to want to. what you will now ask is what format to export from SU - .obj but make sure you follow some rules regarding your textures and Mapping them correctly see previous post for youtube link. you can use .fbx i think. I've managed to get a simple model in tonight and build some lighting. Best i've done so far but still theres errors
                                maybe going through Unity is a good idea, I've not heard anyone try.
                                • cmeedC Offline
                                  cmeed
                                  @kaas said:
                                  @cmeed said:
                                  Try this.....
                                  As I said above I managed to get a model in to UE4 tonight. lots of errors though. Although none visible as far as I could see.
                                  I have 2 questions you may know the answer to
                                  have you tried getting a textured sphere or a shere with an image on it? I tried but when UE4 compiled shaders it took ages, it took each individual face as a new texture - I've tried a few times all the same
                                  the other question
                                  I'm looking to import the whole model and not place individual items ( i do this by dragging all the meshes that have been imported onto the view port (easy)) but my scale is really off - do you know the method of setting this up on export or during import (there's an option (for .obj) to use model units or millimetres etc and a scale option in UE4)
                                  tonight i've only exported as an .obj, have you used .fbx?
                                  (that's 3 questions)
                                    kaas
                                    I did import more blobby objects into UE but.. I needed to pass them through Blender first.
                                    SketchUp does 'strange things' with mapping coordinates / textures on blobby objects - they seem to turn into small unique materials when exporting to obj (look into the export folder and you will see lots of small textures).
                                    Unreal Engine needs a second uv channel for storing the lightmaps. Sketchup can't create that 2nd channel so Unreal automatically creates it during import (if you have that option checked) by copying the first channel and re-arraging it into the 0-1 UV space(no repetition).
                                    Result in UE: lots of small unique materials, all with a default size lightmap which takes 'ages'.
                                    In short: for blobby objects, I export to obj -> import in Blender -> create a second UV channel for the lightmap with everything layed out flat, all into the 0-1 UV space -> import into UE with the option 'generate lightmaps' NOT checked -> succes
                                    @cmeed said:
                                    the other question
                                    Internally UE uses centimeters. I normally model in mm's myself so during fbx-export from SU, in the export options I set the units to cm's.
                                    In SU, I export to fbx for more simple objects like walls, floors, etc
                                    I use obj for objects that are more complex or causing trouble in UE and run them through Blender first for applying an extra Lightmap UV channel. From Blender I export to fbx again.
                                    It seems complicated but once you have this workflow going its easy. Maybe have another read in my quickstart that I posted a while ago in this thread? http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=57392%26amp;start=60#p576468
                                    Good luck! If you have any more questions, fire away
                                      kaas
                                      I start UE from a normal icon on my taskbar. If you start the editor without an internet connection it throws an error but on the bottom of the screen there is an option for using it 'offline'.
                                      • soloS Offline
                                        Unreal 4.10 released:
                                        (www.unrealengine.com)
                                          jenujacob
                                          forgive me if its a stupid question... but since UE4 is free for archViz now... why cant say someone take the source code and make a dumbed-down-architect-friendly version which would work similar to lumion/twinmotion and lumenrt?? πŸ˜„
                                          • cmeedC Offline
                                            cmeed
                                            Great idea. Go on then ....
                                            In the unreal marketplace there is an architect aimed bit of kit. It's called HAL. I think. Have a look. I think I mentioned it in an earlier post here. It's not twinmotion/lumion and, like your thinking, ue4 could easily be similar. Certainly cheaper. Lumion looks great now but for the price.
                                            • 4 / 5
