    How do make a 3d model of this?
    14 Posts 7 Posters 1.3k Views 7 Watching
      In SU it becomes unusable at 0.5million vertices.
        Actually when I saved the file as a .skp it was 64mb in size.
        I imagine the full file would run into gigabytes.
          @ Rich : With what have you made your displacement Map?
            I used Blender....
            404 Not Found
            (cloud.sketchucation.com)
            ...feel free to examine the file
            • bazB
              baz
              @rich o brien said:
              You need to displace a subdivided mesh so the image can act as the displacement map to raise and lower the mesh.
              I love it when you talk dirty.
                I should start charging
                • L
                  LARV
                  [attachment=0:zbh5bvyq]<!-- ia0 -->2015-10-27_10-38-33.png<!-- ia0 -->[/attachment:zbh5bvyq]
                  Here's an example with only a single area acting as a displacement map. The mesh is at 0.7 million vertices to get anything reasonable for presenting.
                  I would think using this technique on the full resolution would require you traveling to CERN and making use of the Hadron Collider to run SU.
                  I have an Alienware computer, I got this.
                  • FrederikF
                    Frederik
                    Do you have access to it...??
                    πŸ˜† πŸ˜† πŸ˜†
                    Cheers
                    Kim Frederik
                      Yes....you can find out what's possible here
                      • JQLJ
                        JQL
                        www.casca.pt
                        Visit us on facebook!
