    How do make a 3d model of this?
    14 Posts 7 Posters 873 Views 7 Watching
      LARV
      Hello pros,
      I found this NASA site where I can download topography images. IΒ΄ve seen these black and white images before and I heard they can be (or are ment to be) used to create 3d topography models. The problem is that I donΒ΄t know how to do that, once I have the images. Can someone help me out? πŸ‘
      (visibleearth.nasa.gov)
        Maybe Bitmap to Mesh by Thomthom if you want stay inside Sketchup but reduce the size first! πŸ€“
        • Rich O BrienR Online
          You need to displace a subdivided mesh so the image can act as the displacement map to raise and lower the mesh.
          Here's an example with only a single area acting as a displacement map. The mesh is at 0.7million vertices to get anything reasonable for presenting.
          I would think using this technique on the full resolution would require you traveling to CERN and making use of the Hadron Collider to run SU.
          • massimoM Offline
            massimo Moderator
            :laughing:  :laughing:  :laughing:
              In SU it becomes unusable at 0.5million vertices.
                Actually when I saved the file as a .skp it was 64mb in size.
                I imagine the full file would run into gigabytes.
                  @ Rich : With what have you made your displacement Map?
                    I used Blender....
                    (cloud.sketchucation.com)
                    ...feel free to examine the file
                    • bazB Offline
                      baz
                      I love it when you talk dirty.
                        I should start charging
                          LARV
                          [attachment=0:zbh5bvyq]<!-- ia0 -->2015-10-27_10-38-33.png<!-- ia0 -->[/attachment:zbh5bvyq]
                          Here's an example with only a single area acting as a displacement map. The mesh is at 0.7 million vertices to get anything reasonable for presenting.
                          I have an Alienware computer, I got this.
                          • FrederikF Offline
                            Frederik
                            Do you have access to it...??
                            πŸ˜† πŸ˜† πŸ˜†
                            Cheers
                            Kim Frederik
                              Yes....you can find out what's possible here
                              • JQLJ Offline
                                JQL
                                www.casca.pt
                                Visit us on facebook!
