    Right-click to "Orbit" & Middle-click to "Pan"
    17 Posts 14 Posters 10.3k Views 14 Watching
      sorgesu
      You are right: Different strokes.
      Susan Sorger
      Former Seller Hand Rendered Entourage
      Former Canadian Authorized Training Centre, SketchUp
        Sawduster
        I tried using my middle finger on the wheel and man, that was difficult. Guess if I did it enough I could get used to it, but . . .
        May all your dimensions be the sum of their total.
        Jerry
        http://www.sawdustersplace.com
        • plot-parisP
          plot-paris
          what a cool thing (middle mouse button + left mouse button = pan)!
          I am honestly considering to change my habits of using a mouse. always having three fingers on the three main buttons may not be too bad...
          by the way: I love the possibility of "smoothly" switching between orbit and pan mode (by pressing Shift or Left Mouse Button) without the need of releasing the Scroll Wheel, so that you can switch between orbiting and paning several times within one movement.
          other programs dont support that and it is sooo cooool!!! 😎
          • GaieusG
            For me the problem with the middle + left buttons to pan is that I use my pointing (?) finger for the middle button, too, so it's a bit inconvenient to start using another finger at this age... 😒
              sorgesu
              Yeah, it means either permanently switching to always use the middle finger for scrolling or it means switching just for the pan. I find either option very difficult at this point.
              What would have been easier is instead to use the scroll wheel with the pointer finger and the right button at the same time. That wouldn't have required any physical re adjustment. I wonder if we can force that somehow with mouse setting?
              Nope, can't. I have a great mouse with programmable buttons but it doesn't allow for programming of a double button action. So the only way to do it would be to swap the functionality of the left and right buttons, which I certainly don't want to do.
              Susan Sorger
                Mouthpear
                Did you ever find a solution for this? I also would rather use the wheel + right button tp pan instead of how it is default. I mean there is some line of code that says if you hold down the wheel and press the left mouse button you start the pan function. How hard would it be to change that to the right button? lol. I was trying to find the file and line but can't.
                • Bob JamesB
                  Bob James
                  Buy a SpaceNavigator or Spacemouse and eliminate all of the finger shifting. 😎
                    jaceguay
                    You could use X-mouse button https://www.highrez.co.uk/downloads/XMouseButtonControl.htm
                    or autohotkey to achieve this, the first are easier to use, in both you can configure this behavior by application so it won´t interfere with other programs.
                    I use a autohotkey script and have a friend that prefer X-mouse.
                    • pbacotP
                      Original post was 7 years ago, and OP never made another post, but keep the ideas coming!
                      • pmolsonP
                        pmolson
                        Any mouse with a thumb button. use the mouse software to assign the letter O to the thumb button
                          skateboardtshirt
                          It is possible to set your mouse's right-click as something else other than 'context-click' (bring up the menu). Here's how:
                          On a mac you can invoke the context-click menu by holding 'control' and then clicking.
                          To remap your right-click mouse button you can use a third-party software called SteerMouse. You make an application-specific remapping (so that it only remaps it in SketchUp) to a keyboard shortcut. In your example you would set the keyboard shortcut to 'o' which is the default SketchUp keyboard shortcut to invoke the orbit tool
                          • G
                            galiaf
                            !!!!!!!!!!!!!!!!!!!THIS ONE IS A REAL SOLUTION!!!!!!!!!!!!!!!!!!!
                              @galiaf, youve dredged up an ancient thread.
                              Curiously no one has addressed Gaeius's question. If right click is used for Orbit, how does one acess the Context menu?
