    Material Problem in TheaRender
    extensions
    25 Posts 10 Posters 13.5k Views 10 Watching
      tomasz
      In general it is better to apply all textures inside SketchUp.
      If you have to do it in Thea Studio, then use cubic mapping for the piece of the model you have applied the new material (Tools/Transform Tool/Mapping Icon/Cubic).
      I suggest you checking new integrated Thea for SketchUp!
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        gafia
        I have problem in scatter part in Thea Render Material Lap
        i cant see it and it not working
        i am asking if i need some program for make it working right
        please answer me πŸ˜„
        • soloS Offline
          You have a blank scene, try adding the material to a shape, a plane or something then check again.
            gafia
            i did that
            and not working it was working before i recover the laptop i guess its about the system files
            • N Offline
              notareal
              I'd try to reinstall Thea if you have not done so. Are you using latest RV
              http://www.thearender.com/cms/index.php/downloads/thea-render.html remember also get latest presto GPU (if you have nvidia GPU) http://www.thearender.com/cms/index.php/downloads/presto-gpu.html
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                gafia
                i have the latest version and i tried all versions
                not working right " sorry about my english "
                i have this problem in other CPU and this LapTop
                but it work right in other LapTop
                and i am afraid to uninstall it from it cause if i re install and get that am going to be disappoints
                  gafia
                  Note : i have registration but i didnt put it
                  i tried ro recover laptop and have same problem
                  i tried to update windows and the same thing and graphics card too
                  i tried many things nothing work
                  i need solution
                    gafia
                    Thanks for all and especially "notareal"
                    it work now i download the links and it working very good thanks again
                      Cittizewn
                      cadmunkey... did you fix you problem with displacement map?
                        cadmunkey
                        Hi, that was over 4 years ago! I didnt sort it at the time but I know displacement works well in Thea now, but to be honest I never use it anymore.
                        • JQLJ Offline
                          JQL
                          Are you having trouble with displacement yourself Cittizewn?
                          www.casca.pt
                          Visit us on facebook!
                            Cittizewn
                            Yes, my difuse map scale and displacemente map scale are not de same somehow. if i change the texture scale in sketchup somehow the displacemente scale of my displacemente map dont match afterwards.
                            How should i do do get same scales in dif and displa? change scales in sketchup first or in thea material studio?
                            • JQLJ Offline
                              JQL
                              Verify if the following settings are the same with that material for both diffuse, displacement, and all other maps:
                              (click the gif)
                              www.casca.pt
                              • JasonWDJ Offline
                                JasonWD
                                JQL That is super useful! Thanks
                                SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
                                • JQLJ Offline
                                  JQL
                                  I'm glad it was helpful!
                                  www.casca.pt
                                    morin
                                    hi every one. I have no bump and no displacement.
                                    I follow all that was explained before but still have this problem.
                                    SEE the image.(no image. dont know how !) translation look good in preview but no bump no translation on rendering.
                                    I’m on the demo version. would like to buy but need to fix this problem first.
                                    please help! thea render look very great !
                                    I am on windows 10, sketchup 2017 make, Intel(R) Core(TM) i7-4770S CPU @ 3.10GHz (Cores: 😎 and GeForce GTX 750 Ti (Cores: 640)
