    Material Problem in TheaRender
    extensions
    25 Posts 10 Posters 14.4k Views 10 Watching
    • N
      nursill
      People pls help. I have a problem, when i do model in SU and export to the the THEA, add material and then look likes... on the wall build lines
      http://s018.radikal.ru/i513/1301/8b/023a18de3f31.jpg
      • T
        tomasz
        In general it is better to apply all textures inside SketchUp.
        If you have to do it in Thea Studio, then use cubic mapping for the piece of the model you have applied the new material (Tools/Transform Tool/Mapping Icon/Cubic).
        I suggest you checking new integrated Thea for SketchUp!
        • G
          gafia
          I have problem in scatter part in Thea Render Material Lap
          i cant see it and it not working
          i am asking if i need some program for make it working right
          please answer me πŸ˜„
          • soloS
            You have a blank scene, try adding the material to a shape, a plane or something then check again.
            • G
              gafia
              i did that
              and not working it was working before i recover the laptop i guess its about the system files
              • N
                notareal
                I'd try to reinstall Thea if you have not done so. Are you using latest RV
                http://www.thearender.com/cms/index.php/downloads/thea-render.html remember also get latest presto GPU (if you have nvidia GPU) http://www.thearender.com/cms/index.php/downloads/presto-gpu.html
                • G
                  gafia
                  i have the latest version and i tried all versions
                  not working right " sorry about my english "
                  i have this problem in other CPU and this LapTop
                  but it work right in other LapTop
                  and i am afraid to uninstall it from it cause if i re install and get that am going to be disappoints
                  • G
                    gafia
                    Note : i have registration but i didnt put it
                    i tried ro recover laptop and have same problem
                    i tried to update windows and the same thing and graphics card too
                    i tried many things nothing work
                    i need solution
                    • G
                      gafia
                      Thanks for all and especially "notareal"
                      it work now i download the links and it working very good thanks again
                      • C
                        Cittizewn
                        cadmunkey... did you fix you problem with displacement map?
                        • C
                          cadmunkey
                          Hi, that was over 4 years ago! I didnt sort it at the time but I know displacement works well in Thea now, but to be honest I never use it anymore.
                          • JQLJ
                            JQL
                            Are you having trouble with displacement yourself Cittizewn?
                            www.casca.pt
                            Visit us on facebook!
                            • C
                              Cittizewn
                              Yes, my difuse map scale and displacemente map scale are not de same somehow. if i change the texture scale in sketchup somehow the displacemente scale of my displacemente map dont match afterwards.
                              How should i do do get same scales in dif and displa? change scales in sketchup first or in thea material studio?
                              • JQLJ
                                JQL
                                Verify if the following settings are the same with that material for both diffuse, displacement, and all other maps:
                                (click the gif)
                                www.casca.pt
                                • JasonWDJ
                                  JasonWD
                                  JQL That is super useful! Thanks
                                  SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
                                  • JQLJ
                                    JQL
                                    I'm glad it was helpful!
                                    www.casca.pt
                                      morin
                                      hi every one. I have no bump and no displacement.
                                      I follow all that was explained before but still have this problem.
                                      SEE the image.(no image. dont know how !) translation look good in preview but no bump no translation on rendering.
                                      I’m on the demo version. would like to buy but need to fix this problem first.
                                      please help! thea render look very great !
                                      I am on windows 10, sketchup 2017 make, Intel(R) Core(TM) i7-4770S CPU @ 3.10GHz (Cores: 😎 and GeForce GTX 750 Ti (Cores: 640)
