    How to make a seamless line
    6 Posts 3 Posters 624 Views 3 Watching
      JoeAnderson
      Hi, guys!
      Is it possible to make a single curve/line of an arc and a line connected? Or of two connected arcs?
      Arc and a curve.skp
      • B
        Bruce Watt
        Will 'Weld' do it for you.
        Go to SketchUcation plugin store and type 'weld' into the search box for the plugin extension.
        SKUP PRO 2021 latest version / update
        Windows 10 Pro
        Dell Alienware Aurora R10 AMD
        AMD Ryzen™ 9 3900X
        NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
          Yes, you need to "Weld" it - use a Plugin like this http://sketchucation.com/pluginstore?pln=TIG-weld
          I have mine shortcutted to J [==Join]
          Select the edges/curves with connected ends and no branches and a new Curve gets made...
            JoeAnderson
            Thanks a lot for your advice and the link! However, is it possible to realise with the standard tools?
              It this were possible with the native tools then why would someone bother to write a Plugin ?
              Curves a bound edges in a 'welded' form.
              Arcs, Circles and Polygons are all Curves, but get additional properties, so list separately in Entity Info.
              If you deform on of those it remains welded, but becomes a Curve in Entity Info.
              In Ruby code you can do somethings unavailable with the native tools - here we combine suitable edges into a Curve, in a 'Weld' tool...
              • B
                Bruce Watt
                Hi Joe,
                I was once resistant to using plugin and exclaimed "why can I not do this simple thing straight out of the box". Once I spent a few minutes working out how to install plugins i did not look back. With the Plugin Store and extension warehouse this could not be easier. I would recommend to give it a go and before you know it you will have more tools than you can shake a stick at.
                Windows 10 Pro
                AMD Ryzen™ 9 3900X
