    Mapping onto a cylindrical shape???
    15 Posts 7 Posters 1.4k Views 7 Watching
    • utilerU
      utiler
      Hey guys, I've got a mental block. Why is it when I import an image, scale it to size and try to paint it onto a cylinder it won't?
      I've done it before but I've got nothing!!!!
      RiD-CounterTop.skp
      Just Curious...
      • pbacotP
        I had to use ThruPaint myself. First make the texture not "Projected".
        I scaled it up. Perhaps inappropriately. Seems if you don't want it to go so tall, you have to define a smaller surface for it.
        RiD-CounterTop 2.skp
        • sdmitchS
          sdmitch
          Import image as texture. Make sure texture is set Projected.
          Turn off hidden geometry. Sample texture with eye dropper.
          Paint cylinder.
          http://sdmitch.blogspot.com/
          • utilerU
            utiler
            Gee I'm stupid..... Thanks Sam!
            ๐Ÿ˜ฎ ๐Ÿ˜ฎ
            Just Curious...
            • pbacotP
              Another way. Make the texture on the flat face NOT Projected. Sample it. Select all the faces or just the whole surface (hidden geo off) to be painted. Click the paint bucket on it until it seems to stop shifting textures, and the label will be wrapped.
              • olisheaO
                olishea
                Another way using UV tools.....just paint the cylinder using the normal bucket tool.
                Then right click the face, UV tools > Cylindrical Projection. Hey Presto...it maps the texture.
                oli
                • utilerU
                  utiler
                  Hey thanks guys, I got it to work simply by the was Sam explained it, stupid me.
                  I haven't played around with UV tools yet but want to give it a try; sounds like its pretty neat.
                  Cheers to you all...!
                  Just Curious...
                  • utilerU
                    utiler
                    quick question; what's the main difference between thomthom's UV toolkit and Whaat's SketchUV?
                    Just Curious...
                      SketchUV has more mapping methods.
                      • cottyC
                        cotty
                        ...and a great path select tool!
                        my SketchUp gallery
                        • olisheaO
                          olishea
                          yeah the UV tools i was talking about is ancient. Just works for simple stuff; cylinders and spheres.
                          oli
                          • utilerU
                            utiler
                            Cheers, y'all!!
                            Just Curious...
                            • david_hD
                              david_h
                              Used the Old UV tools. Works pretty good . . .but I didn't get an Ace of Clubs for some reason.
                              • utilerU
                                utiler
                                Nice work, Dave. ๐Ÿ‘
                                Just Curious...
                                • david_hD
                                  david_h
                                  thanks. . .didn't mean to hi-jack the thread. I just hadn't used UV tools for a while. Queen of Hearts does look like she is retaining a bit of water though. ๐Ÿ’š
