    Mapping onto a cylindrical shape???
    15 Posts 7 Posters 1.2k Views 7 Watching
    • sdmitchS Offline
      sdmitch
      @utiler said:
      Hey guys, I've got a mental block. Why is it when I import an image, scale it to size and try to paint it onto a cylinder it won't?
      I've done it before but I've got nothing!!!!
      Import image as texture. Make sure texture is set Projected.
      Turn off hidden geometry. Sample texture with eye dropper.
      Paint cylinder.
      http://sdmitch.blogspot.com/
      • utilerU Offline
        utiler
        Gee I'm stupid..... Thanks Sam!
        ๐Ÿ˜ฎ ๐Ÿ˜ฎ
        Just Curious...
        • pbacotP Offline
          Another way. Make the texture on the flat face NOT Projected. Sample it. Select all the faces or just the whole surface (hidden geo off) to be painted. Click the paint bucket on it until it seems to stop shifting textures, and the label will be wrapped.
          • olisheaO Offline
            olishea
            Another way using UV tools.....just paint the cylinder using the normal bucket tool.
            Then right click the face, UV tools > Cylindrical Projection. Hey Presto...it maps the texture.
            oli
            • utilerU Offline
              utiler
              Hey thanks guys, I got it to work simply by the was Sam explained it, stupid me.
              I haven't played around with UV tools yet but want to give it a try; sounds like its pretty neat.
              Cheers to you all...!
              Just Curious...
              • utilerU Offline
                utiler
                quick question; what's the main difference between thomthom's UV toolkit and Whaat's SketchUV?
                Just Curious...
                  SketchUV has more mapping methods.
                  • cottyC Offline
                    cotty
                    ...and a great path select tool!
                    my SketchUp gallery
                    • olisheaO Offline
                      olishea
                      yeah the UV tools i was talking about is ancient. Just works for simple stuff; cylinders and spheres.
                      oli
                      • utilerU Offline
                        utiler
                        Cheers, y'all!!
                        Just Curious...
                        • david_hD Offline
                          david_h
                          Used the Old UV tools. Works pretty good . . .but I didn't get an Ace of Clubs for some reason.
                          • utilerU Offline
                            utiler
                            Nice work, Dave. ๐Ÿ‘
                            Just Curious...
                            • david_hD Offline
                              david_h
                              thanks. . .didn't mean to hi-jack the thread. I just hadn't used UV tools for a while. Queen of Hearts does look like she is retaining a bit of water though. ๐Ÿ’š
