    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 655.8k Views 155 Watching
    • dereiD Offline
      derei
      Hy, I am a bit confused on how to PROPERLY use this plugin... Ok, I understood that I should keep the mouse button pressed while pulling the face, because click will only select/deselect (which is a bit annoying, honestly). But there is a funny behavior AFTER I do the push pull... sometimes (couldn't figure out in which conditions), when I press ENTER it actually CANCEL my pushpull.
      Until now, every successful pushpull i did was out of luck... I have no idea how I confirmed the operation, because apparently I do the same thing like when it's canceled.
      In my opinion it should do better use of ESC and ENTER keys (first to cancel, second to confirm). Also, selection of faces would be best to be key-assisted, as in regular SU behavior.
      Is very confusing when plugins ask for different commands to do similar SU actions... is like two different programs. Select should be performed the same in native Su and under plugins (same key+mouse combinations), other operations should be similar.
      Wish you best.
      DESIGNER AND ARTIST DEREI.UK
      • fredo6F Offline
        I know it is a change of habit, but JPP is not designed to replace the native SU Pushpull either.
        SU PushPull only acts on a single face. So when you click, the next action is PushPull.
        In multiface seelction, you cannot do the same, because when you click on the first face, then this face would move / pushpull with the mouse when you will try to select a second face.
        The only possibility remain is to select with NO click:
        • if the mouse if over a face and you click, this face is PushPulled
        • if you press CTRL why hovering over faces (.ie. no click), then these faces are added to the selection. If you then click, the Push Pull applies to all faces selected.
        This method is also different from Sketchup, which does not have a multi-element selection capability in implicit selection (i.e. just hovering the mouse).
        Note that I use this method in FredoScale, but I am pretty sure few users noticed or use it.
        I'll have anyway another look and reflection to see if I can improve the face selection process (the best, when applicable, is to select the faces and then just type the offset, if you don't need a placement by target).
        • dereiD Offline
          derei
          I completely understand that this tool is not meant to replace a native SU tool. I was merely talking about the way of use of the similar commands (eg. selecting faces).
          But this is not the biggest problem I got into. I could accommodate to it. The problem is that ENTER cancels the push-pull. I do it, i set custom value in VCB, then i press ENTER. And voila: no pushhpull. πŸ˜• And I get confused: did I pressed ESC?
          Unless there is any reason to assign a canceling to ENTER key.
          By the way... "before" JPP wasn't behaving like this. It's like this change was introduced recently...couldn't tell which release.
          Thank you very much, Fredo
          • fredo6F Offline
            I will have a look.
            The latest version of JPP is dated 9 Jan 15, so it's not recent, unless there is a side effect from LibFredo6.
            Did the problem happens when you are extruding a few faces or a lot of faces (with many faces, you have a preview mode)?
              I just did some quick testing and I'm not seeing any weird behavior with the Enter key. When I type a JPP distance and hit Enter, it makes the adjustment just like the native Push/Pull tool does. Maybe there's something else causing a conflict?
              FWIW, I updated LibFredo and the other extensions that got recent updates and according to the Plugin Store and LibFredo, everything is up to date.
              • dereiD Offline
                derei
                I tried to reproduce it now, Couldn't. Will keep an eye on it, as it happened many times while working.
                • dereiD Offline
                  derei
                  UNDO issue ...
                  sometimes when I cancel JPP it lets the geometry with missing faces. Then I undo to get it back to its previous state...the problem is that i have to hit A LOT of UNDOs.
                  Maybe the undo function should be reviewed and pack multiple phases in a single undo command.
                    Ciacnorris
                    Hi, I tried to install it on my PC, and I think it doesn't work on Windows 8.1.
                    Are you gonna make it work on Windows 8.1 too?
                    Really wanna try your plugin! πŸ˜„
                      peterromao
                      Hail to a very reliable extension which I have used countless times so far to give thickness to my sheets! Good Job!
                      Today is the first time that I found an error with it.
                      For some reason I cannot give this form a thickness.
                      The ruby error I get is the following:
                      Date: 07-Aug-15 19:49:31
                      An error occurred in Joint Push Pull
                      Error in generation of the geometry
                      reference to deleted Entity
                      JointPushPullGeometry.rb: 1027 -- entityID
                      JointPushPullGeometry.rb: 1027 -- block in geometry_coplanar_edges_overhang
                      JointPushPullGeometry.rb: 1025 -- each
                      JointPushPullGeometry.rb: 1025 -- geometry_coplanar_edges_overhang
                      JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges
                      JointPushPullGeometry.rb: 352 -- each
                      JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges
                      JointPushPullGeometry.rb: 214 -- robot_call_action
                      JointPushPullGeometry.rb: 177 -- geometry_robot_exec
                      JointPushPullGeometry.rb: 160 -- geometry_robot
                      JointPushPullGeometry.rb: 75 -- block in geometry_execute
                      Lib6Operation.rb: 325 -- call
                      Lib6Operation.rb: 325 -- step_geometry
                      Lib6Operation.rb: 367 -- start_execution
                      JointPushPullGeometry.rb: 75 -- geometry_execute
                      JointPushPullTool.rb: 891 -- go_preview_or_geom
                      JointPushPullTool.rb: 697 -- dragging_stop
                      JointPushPullTool.rb: 1319 -- onLButtonUp
                      I have attached the object.
                      Single sheet with openings.
                        If you JPP OUTWARDS it works OK.
                        Extruding INWARDS will fail.
                        This is because you have some tiny geometry in the surface - e.g. the segmented edges around the slotted holes semi-circular ends.
                        When extruding 'inwards', SketchUp's tolerance of 1/1000" can cause some tiny edges to be omitted - their start/end points are deemed coincident - then the faces relying on those also fail to be created.
                        But all is not lost...
                        You can JPP INWARDS if you do the following...
                        Make your group into a component.
                        Make a copy of it and Scale that x100.
                        Edit that instance and Preselect its surface.
                        Activate JPP - making x100 allowance in the offset value.
                        It will now extrude successfully.
                        Exit the edit and delete the scaled version.
                        The real size version will also show the JPP changes.
                        Tiny geometry can exist but it cannot be created directly in SketchUp.
                        The "Scale up a copy of a component" trick is a well known workaround for these kinds of issues...
                          peterromao
                          Hello TIG,
                          Awesome!!!!
                          That was an excellent reply. It worked. Thanks for the heads up. I recall doing something of the sort in the very distant past but if it weren't for your reminder I would have never gotten there!
                          Thanks again!
                          Peter
                          • JQLJ Offline
                            JQL
                            Fredo,
                            We are able to push pull by vector keeping original face orientation or by creating the ending faces as normal to the push pull vector. This is great!
                            Do you think it would be possible to pick any face in the project as the ending faces plane?
                            Thanks and best regards,
                            JoΓ£o
                            www.casca.pt
                            Visit us on facebook!
                            • fredo6F Offline
                              Joao,
                              This is technically feasible, but more a matter of UI, which is already complex for users, as you know.
                              I'll see what I can do when I refresh the plugin.
                              • JQLJ Offline
                                JQL
                                @fredo6 said:
                                Joao,
                                I understand perfectly.
                                It's also something that would be good to have but that can be achieved manually. I hope you find the time to include it someday.
                                Thanks again,
                                JoΓ£o
                                www.casca.pt
                                • dereiD Offline
                                  derei
                                  Two changes would be great for this plugin, as it works somehow against "intuition":
                                  -first would be Press RETURN to exit (that's the ENTER key, and usually is used to CONFIRM a action, not to cancel it) - best would be to use ESC Key
                                  -second would be the obligation of inserting push value with (-) AFTER the push action was initialized. It is great to let the option there, in case the user really needs to revert the direction, but it would be better that once a number was introduced, to take "by default" the pushing direction already initialized by the user.
                                  Another thing is that AFTER doing a JPP operation, I must be very careful what tool or key I press, or I risk to have my operation canceled... this is extremely frustrating, as there is no intuitive action. As I said before, I am tempted to press ENTER - but guess what? I cancel my work. If I press Space Bar (to go to select tool) it happens the same, if I click on screen I also cancel the operation... every time is "lucky guess". In my opinion should be clear: ESC= Abort, ENTER=Commit. Nothing around. To not exit from operation until ESC or ENTER was pressed. This way there is no chance of mistake.
                                  I hope this suggestions make sense.
                                  Thank you.
                                  • fredo6F Offline
                                    Do you have a model where this happens? It must be related to the Preview mode, when you have a lot of faces.
                                    • Enter / Return is used to perform the Push Pull, so that you don't even need to drag the faces. The cursor must be still on one face, since when the cursor is in the empty space, it is used to exit the tool.
                                    • Escape does Abort when in interactive mode
                                    • Spacebar functions as in any Sketchup tool. If you did not commit beforehands, it simply exits with doing nothing.
                                    • dereiD Offline
                                      derei
                                      yes, I had many faces in the model (organic modelling)...
                                      But why there are 2 different uses for ENTER (when cursor on face, or not on face?) Is possible that is why I miss it many times... because i move the cursor around. I am not used to pay attention to it when i don't actively use it to manipulate geometry. Do you think this behavior is actually useful?
                                      Thanks for all explanations πŸ˜‰
                                      • JQLJ Offline
                                        JQL
                                        Fredo,
                                        Would it be easy to have normal push pull Taper with an angle or a offset distance instead of exclusivelly by ratio? It would be a nice feature to have for chanfering faces outside their plane with a double click. (I love this double click through groups/components)
                                        www.casca.pt
                                          bapito
                                          Where do i download it!!!???!!!
                                            See the first post of this thread. It is clearly spelled out with bold type and links.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 30 / 31
