    1.5k Posts 471 Posters 3.4m Views 470 Watching
    • massimoM Offline
      massimo Moderator
      Thank you very much for this update Fredo.
      You can now modify the parameters after the generation of the geometry without reselecting edges.
      This is a great new feature and a huge time saver. 👍
      • pbacotP Offline
        This may be the paragon of your plugins, Fredo, which are all superb at that. A hugely useful and essential tool that only gets better and more refined over time!
          jcyber
          Thank you so much fredo6
          • fredo6F Offline
            NEW RELEASE: RoundCorner v3.0b - 17 Jul 15
            RoundCorner 3.0b fixes a major bug preventing the plugin to launch for Sketchup 2013 and earlier versions.
            So it is IMPORTANT to upgrade to v3.0b if you run these versions of Sketchup.
            Sorry for inconvenience
            • Z Offline
              z200121
              Yep with little measures that splatting soon as Enter!
                No a very clear comment 😒
                If you mean that using very small dimensions causes a BugSplat, then this a well know limitation of SketchUp -both in SketchUp's native tools and many Plugins...
                Models with edges [and any faces they might support] < 1/1000" long can 'exist', BUT they cannot be 'created' - this is because at that size the tolerance built in to SketchUp means that it takes the edge's start/end points to be coincident.
                The work around is to scale the geometry up x100 or more, do the intricate creation and scale back down afterwards.
                As I said - the tiny geometry can exist, but it cannot be created...
                • dereiD Offline
                  derei
                  @tig said:
                  ...can exist, but it cannot be created...
                  Use this as your motto, is cool ! 😄 💚
                  DESIGNER AND ARTIST DEREI.UK
                    littleche
                    its great ! thanks fredo .
                    • DDKD Offline
                      DDK
                      One of the best plug-ins ever, thank you!!! makes my models look more realistic. the best part of this is it keeps the faces grouped as one. cheers keep making more 😄
                        kashiu
                        Hi fredo
                        I have the su2015 & Im interstate in the round corner pouring, can you help me?
                          littleche
                          HI
                          I Have problem with this model . round corner can't rounding this model and recive overlab error.
                          How can I fix this problem?
                          P & P.skp
                          thanks
                          • fredo6F Offline
                            @littleche said:
                            HI
                            thanks
                            Unfortunately, with the current algorithm, this is not possible.
                            At the sharp corner, you have edges which are smaller than the offset.
                              littleche
                              @fredo6 said:
                              @littleche said:
                              HI
                              thanks
                              Thank you fredo . You are always trying to develop this plugin.And I thank you very much.If you are not a thing of SketchUp shortage!
                              I hope you can fix algorithm in the next version .Always sincerely pray for your success...
                              • W Offline
                                Will C
                                I've been using this plugin for a while now and it's pretty awesome. Makes curving edges a lot faster with less frustration. Thanks for making this.
                                  Tony2015
                                  thx fredo
                                  • bac9-flclB Offline
                                    bac9-flcl
                                    @fredo6
                                    Is it possible to fix the chamfer process failing on such a corner?
                                    http://i.imgur.com/EuaXGhj.png
                                    It's pretty much impossible to avoid places like those in serious quad-based hardsurface modeling, and other chamfering implementations (in 3ds Max, Maya, etc.) never had issues with topology like that, so I'm not sure if anything really prevents proper chamfering here. Typically, corners like those are simply resolved like this:
                                    http://i.imgur.com/8UUbDRJ.png
                                    • fredo6F Offline
                                      Not possible with the current algorithm.
                                      Would require another technique, which I may implement one of these days.
                                        bac9-flcl
                                        Thanks for the info!
                                        While at it, can you take a look at this improvement? It would be an enormous help for users inserting edges into n-gons to control triangulation, and to users with quad-based geometry or otherwise unavoidable coplanar face sequences:
                                        http://i.imgur.com/wnsXjhF.png
                                          Guig2000
                                          this plugin helped me previously, so, thanks for that, fredo.
                                          But well it don't like curves at all even at 100 000 scale and despite that in this sample, the offset is much smaller than my requirement, I had overlaps everywhere.
                                          http://www.zimagez.com/miniature/sketchuproundcorneroncurved.png
                                          http://www.zimagez.com/miniature/sketchuproundcorneroncurved20.png
                                          Also a good enhancement could be to be able to have multi-offsets capability in a selection.
                                            pegaze
                                            hi everyone,
                                            i just run that plugin and after generating geometry, the model became a single part, i'm not able to select a face, if i try to select a face or anything else, the model is all selected ... is it always like that or may i miss something ?
                                            i also dont see any line on the edges.
                                            thanks for your answers.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 73
                                            • 74
                                            • 15 / 74
