    Join Pipes Smoothly?
    27 Posts 10 Posters 3.0k Views 10 Watching
    • KrisidiousK
      Krisidious
      Center of the pipes by building a line that could then be used to rebuild the pipe.
      thanks for Perpendicular Face Tools though. gonna need that.
      By: Kristoff Rand
        If you're talking about whole car bodies, what about using Artisan?
        • KrisidiousK
          Krisidious
          The bodies I can bring straight over and or easily rebuilt their topography. The roll bars are in the right place, but need to be rebuilt.
          By: Kristoff Rand
          • BoxB
            Kris it's all geometry, edges and faces, I think you need to be more specific and tell us exactly what you need to do. To me sorting the car shell would be important and a roll cage something that I could fix in seconds. But is seems the other way for you.
            • KrisidiousK
              Krisidious
              I thought I had been pretty specific. I need to recreate roll bars with connect geometry. from the simplistic and disconnected ones I have or get.
              By: Kristoff Rand
                Tubes which are linear - like the horizontal parts - can be easily extruded as tubes - that is if those path edges are welded into one continuous curve - perhaps with a transitional arc joining the straight bits.
                Like my PipeAlongPath...
                If you have an L junction a welded path will also extrude as you hope.
                Add a transitional arc at the elbow if you don't want a right-angle mitered bend.
                When you have a 'T' of a tube meeting another tube at something like a right-angle, then make the two parts, then use Fredo's RoundCorner tool to make a proper 'filleted' joint - i.e. just like you'd get with a real-world 'weld'...
                If the scale of the modeling doesn't warrant such detail, then simply 'intersect' the two parts and delete the unwanted geometry...
                You'll need to do some exploding/combining of geometry if parts gets grouped as you make them...
                • andybotA
                  andybot
                  Just thinking - you could use vertex tools to merge close vertices. That may work to clean up the breaks at each bend in one shot.
                  Edit: looked at the model - that works only for the smaller bends. For the perpendicular intersections, not much help there.
                  rollbar2.skp
                  • KrisidiousK
                    Krisidious
                    That sounds like the labor I had envisioned Tig. I was really hoping for a clickable cure.
                    Andybot, that did work, but each vert had to be welding 1 at a time. again pretty time consuming.
                    And all of these work-arounds seem like more work that just rebuilding the roll bars.
                    I guess that will have to do.
                    Thanks for all the suggestions.
                    By: Kristoff Rand
                      There's no such thing as a free-lunch !
                      • KrisidiousK
                        Krisidious
                        Fredo Lines2Tubes
                        I guess it will do... I wish it were welded though.
                        Took longer here wrting and answering... But, I'd still rather have a pipe plugin that saw this geometry and knew I wanted 3" pipe in that general shape and welded.
                        Or am I back to the new Profile Builder?
                        By: Kristoff Rand
                        • sdmitchS
                          sdmitch
                          rollbar5.jpg is why I put a sphere at each vertex. That eliminates the outside gaps.
                          http://sdmitch.blogspot.com/
                            Why not use Plugins specialized in Pipes ?
                            Like 3SKeng or this free one by Architectboy?
                            • KrisidiousK
                              Krisidious
                              a roll bar is one solid piece and the less pieces the better on the system.
                              http://s3images.coroflot.com/user_files/individual_files/original_221352_5TgHTnNTM6oQ_yH1OYPItE4Ok.jpg
                              By: Kristoff Rand
                              • andybotA
                                andybot
                                I selected all the vertices and used "merge close vertices" with a distance of 0.3 Much quicker than if you do it individually. πŸ˜„
                                It deletes some faces in the back though, but generate faces fixed that pretty easily. Also need to remove inner faces (There's a plugin for that πŸ˜„ )
                                  With what plugins ?
                                  • andybotA
                                    andybot
                                    @pilou - Vertex Tools
                                    • 2 / 2
