    Join Pipes Smoothly?
    27 Posts 10 Posters 2.9k Views 10 Watching
    • KrisidiousK Offline
      Krisidious
      I thought I had been pretty specific. I need to recreate roll bars with connect geometry. from the simplistic and disconnected ones I have or get.
      By: Kristoff Rand
        Tubes which are linear - like the horizontal parts - can be easily extruded as tubes - that is if those path edges are welded into one continuous curve - perhaps with a transitional arc joining the straight bits.
        Like my PipeAlongPath...
        If you have an L junction a welded path will also extrude as you hope.
        Add a transitional arc at the elbow if you don't want a right-angle mitered bend.
        When you have a 'T' of a tube meeting another tube at something like a right-angle, then make the two parts, then use Fredo's RoundCorner tool to make a proper 'filleted' joint - i.e. just like you'd get with a real-world 'weld'...
        If the scale of the modeling doesn't warrant such detail, then simply 'intersect' the two parts and delete the unwanted geometry...
        You'll need to do some exploding/combining of geometry if parts gets grouped as you make them...
        • andybotA Offline
          andybot
          Just thinking - you could use vertex tools to merge close vertices. That may work to clean up the breaks at each bend in one shot.
          Edit: looked at the model - that works only for the smaller bends. For the perpendicular intersections, not much help there.
          rollbar2.skp
            Krisidious
            That sounds like the labor I had envisioned Tig. I was really hoping for a clickable cure.
            Andybot, that did work, but each vert had to be welding 1 at a time. again pretty time consuming.
            And all of these work-arounds seem like more work that just rebuilding the roll bars.
            I guess that will have to do.
            Thanks for all the suggestions.
            By: Kristoff Rand
              There's no such thing as a free-lunch !
                Krisidious
                Fredo Lines2Tubes
                I guess it will do... I wish it were welded though.
                Took longer here wrting and answering... But, I'd still rather have a pipe plugin that saw this geometry and knew I wanted 3" pipe in that general shape and welded.
                Or am I back to the new Profile Builder?
                By: Kristoff Rand
                • sdmitchS Offline
                  sdmitch
                  rollbar5.jpg is why I put a sphere at each vertex. That eliminates the outside gaps.
                  http://sdmitch.blogspot.com/
                    Why not use Plugins specialized in Pipes ?
                    Like 3SKeng or this free one by Architectboy?
                      Krisidious
                      a roll bar is one solid piece and the less pieces the better on the system.
                      http://s3images.coroflot.com/user_files/individual_files/original_221352_5TgHTnNTM6oQ_yH1OYPItE4Ok.jpg
                      By: Kristoff Rand
                      • andybotA Offline
                        andybot
                        I selected all the vertices and used "merge close vertices" with a distance of 0.3 Much quicker than if you do it individually. πŸ˜„
                        It deletes some faces in the back though, but generate faces fixed that pretty easily. Also need to remove inner faces (There's a plugin for that πŸ˜„ )
                          With what plugins ?
                          • andybotA Offline
                            andybot
                            @pilou - Vertex Tools
                            • 2 / 2
