    Substance and Sketchup Workflow
    107 Posts 9 Posters 16.3k Views 9 Watching
    • KrisidiousK Offline
      Krisidious
      we should run some tests and see what kind of live results we get and results overall.
      By: Kristoff Rand
      • JQLJ Offline
        JQL
        As you might know I also had a deep discussion with Manolis from Thea, wich, of course and unfortunatelly, confirmed what Rich and Jason state about unwrapping.
        I want to take full advantage of the 30days trial so I didn't download designer yet, I'm going through the tutorials and then I will find some time to work with it.
        I see tremendous material design and texturing potential in Substance designer, so I think I will have to conquer my fear of handling Blender...
        www.casca.pt
        Visit us on facebook!
          Krisidious
          And did you not see that model I just showed you that was uv unwrapped and rendered in thea? what's the difference.
          By: Kristoff Rand
            Krisidious
            By: Kristoff Rand
            • JQLJ Offline
              JQL
              There's no difference, I know I can render an unwrapped model in Sketchup, the question is how to easily unwrap it.
              I wouldn't know where to start, Rich adviced blender, but with the incredible amount of going back and forth my models have, I'm a bit scared that unwrapping will be a step to create ultimate confusion in my workflow.
              There's nothing like trying it and I will, of course, try it. Just holding my breath before I dive in to it...
              www.casca.pt
              • JQLJ Offline
                JQL
                But Kris did you model it? How did you unwrap it?
                www.casca.pt
                  Krisidious
                  AC3D easiest unwrapper around. almost completely automatic in some cases it is... in other you may want to edit a bit. But we use maps that other people are going to paint later, so it needs to look a certain way. but if it's just you? easypeasy.
                  AC3D - Easy to use 3D software
                  AC3D - 3D Software - View, Edit and Design great 3D graphics with ease. Free trial downloads for Windows, Mac and Linux. Widely used for Second Life and X-Plane.
                  (www.inivis.com)
                  By: Kristoff Rand
                    Krisidious
                    By: Kristoff Rand
                      Krisidious
                      just part of the uvunwrapped textures on that car. and it rendered very fast. that top texture mapuvwun.JPG is 1000x1000?
                      By: Kristoff Rand
                      • JQLJ Offline
                        JQL
                        Oh no! Do I have to do all that hand work on separating faces?
                        I have no time for that!
                        Imagine I model a pipe like that with some windows around.
                        I unwrapp it by hand like that...
                        What happens if the pipe gets stretched?
                        www.casca.pt
                          Krisidious
                          You don't map stuff until you're done with an object or you remap it after you modify it. a pipe is not really something that takes any time to unwrap. you just select the faces and hit the button then save the image map. same with a box or any standard shapes. it's cars and what not that get harder.
                          http://www.inivis.com/supercoldmilk/ac3dplug/img/um_gui.gif
                          You can map multiple things to one map or each to their own. but to me, procedural means it doesn't need a map, it maps on the fly as it covers a surface. so as to not repeat an to flow or seem more realistic. it would use an algorithm to show a natural surface.
                          By: Kristoff Rand
                          • JQLJ Offline
                            JQL
                            I'm not fully grasping, I have to try it!
                            The only comment I can make is that, of course, I'm not very concerned with cilinders but with the actual stuff I need to create wich is a bit more complex (though not as complex as a car)
                            www.casca.pt
                              Krisidious
                              there are two or three plugins for AC3D that make the job a bit easier than that...
                              By: Kristoff Rand
                              • jason_marantoJ Offline
                                jason_maranto
                                To answer the resolution question, in some cases it is possible to go higher. You definately want to do the bulk of the work at lower resolutions, but a lot of the best features of Substances come through geometry-baked textures as the base... baking those textures can be resource intensive at larger resolutions.
                                Substances make alot more sense for character and prop models based on subD which have high poly sculpts (ZBrush or similar) to pull geometry-based information from. SketchUp models are usually so basic that the best features of Substances really will be marginalized. And that is before you even have to deal with UV unwrap and seam issues.
                                Substances are geard toward next gen (sculpt heavy) wokflows being developed by vidogame companies. SubD modeling and great UVs are the basis of how these projects need to be done to see maximum results.
                                  Krisidious
                                  watch this tut starting at the time set.
                                  By: Kristoff Rand
                                  • JQLJ Offline
                                    JQL
                                    I also understand this quite clearly.
                                    Simple is good!
                                    So imagine all I want for a given model is to use one of the edge procedurals to create a fake bevel in my arch models.
                                    Would I need to unwrap it to achieve my objective, or would I be able to achieve this without unwrapping?
                                    (I'm sorry for the insistence in unwrap without even trying, but that really is work that I wouldn't want to introduce in my workflow. I'd prefer to have no bevel than to waste half an hour unwrapping a model)
                                    www.casca.pt
                                      jason_maranto
                                      Edge effects are all controlled by geometry baked textures, so resolution would be an issue for larger models and UVs will become an issue if not properly handled. That is also assuming the SketchUp created geometry is intelligable to SD/SP... which could be the fault of the model creator or SketchUp itself.
                                      • JQLJ Offline
                                        JQL
                                        Well I really have to try. I know how to texture a model in SU as preciselly as possible and only that unwrapping slips my grasp. My main objective is to keep everything inside sketchup as long as I can and just jump out of it when I really need.
                                        Of course I'm open to a broader frame of mind if that does pay off.
                                        Thanks for all your help Jason.
                                        Let's see where this leads to...
                                        www.casca.pt
                                        • JQLJ Offline
                                          JQL
                                          I don't get it. At a certain stage the guy is trying to make squares fit together quite precisely, then, suddenly he starts dragging and scaling things around in what seamed a random way to me.
                                          In the end the squares didn't fit together, obviously, so why did he do that in the first place?
                                          www.casca.pt
                                            Krisidious
                                            4096 is as high as the maps go.
                                            they do already have procedural choices like tile size and dirt and aging. you can apply it in the converter then apply the texture to the model.
                                            But it doesn't seem to map correctly on it's own.
                                            He's doing that because the car is to scale and the image is pixels. the larger the mode detail of course and the uvw unwrap doesn't actually have to touch all over.
                                            By: Kristoff Rand
                                            • 6 / 6
