    Substance and Sketchup Workflow
    107 Posts 9 Posters 20.3k Views 9 Watching
    • JQLJ Offline
      JQL
      But Kris did you model it? How did you unwrap it?
      www.casca.pt
      Visit us on facebook!
      • KrisidiousK Offline
        Krisidious
        AC3D easiest unwrapper around. almost completely automatic in some cases it is... in other you may want to edit a bit. But we use maps that other people are going to paint later, so it needs to look a certain way. but if it's just you? easypeasy.
        AC3D - Easy to use 3D software
        AC3D - 3D Software - View, Edit and Design great 3D graphics with ease. Free trial downloads for Windows, Mac and Linux. Widely used for Second Life and X-Plane.
        (www.inivis.com)
        By: Kristoff Rand
          Krisidious
          By: Kristoff Rand
            Krisidious
            just part of the uvunwrapped textures on that car. and it rendered very fast. that top texture mapuvwun.JPG is 1000x1000?
            By: Kristoff Rand
            • JQLJ Offline
              JQL
              Oh no! Do I have to do all that hand work on separating faces?
              I have no time for that!
              Imagine I model a pipe like that with some windows around.
              I unwrapp it by hand like that...
              What happens if the pipe gets stretched?
              www.casca.pt
                Krisidious
                You don't map stuff until you're done with an object or you remap it after you modify it. a pipe is not really something that takes any time to unwrap. you just select the faces and hit the button then save the image map. same with a box or any standard shapes. it's cars and what not that get harder.
                http://www.inivis.com/supercoldmilk/ac3dplug/img/um_gui.gif
                You can map multiple things to one map or each to their own. but to me, procedural means it doesn't need a map, it maps on the fly as it covers a surface. so as to not repeat an to flow or seem more realistic. it would use an algorithm to show a natural surface.
                By: Kristoff Rand
                • JQLJ Offline
                  JQL
                  I'm not fully grasping, I have to try it!
                  The only comment I can make is that, of course, I'm not very concerned with cilinders but with the actual stuff I need to create wich is a bit more complex (though not as complex as a car)
                  www.casca.pt
                    Krisidious
                    there are two or three plugins for AC3D that make the job a bit easier than that...
                    By: Kristoff Rand
                    • jason_marantoJ Offline
                      jason_maranto
                      To answer the resolution question, in some cases it is possible to go higher. You definately want to do the bulk of the work at lower resolutions, but a lot of the best features of Substances come through geometry-baked textures as the base... baking those textures can be resource intensive at larger resolutions.
                      Substances make alot more sense for character and prop models based on subD which have high poly sculpts (ZBrush or similar) to pull geometry-based information from. SketchUp models are usually so basic that the best features of Substances really will be marginalized. And that is before you even have to deal with UV unwrap and seam issues.
                      Substances are geard toward next gen (sculpt heavy) wokflows being developed by vidogame companies. SubD modeling and great UVs are the basis of how these projects need to be done to see maximum results.
                        Krisidious
                        watch this tut starting at the time set.
                        By: Kristoff Rand
                        • JQLJ Offline
                          JQL
                          I also understand this quite clearly.
                          Simple is good!
                          So imagine all I want for a given model is to use one of the edge procedurals to create a fake bevel in my arch models.
                          Would I need to unwrap it to achieve my objective, or would I be able to achieve this without unwrapping?
                          (I'm sorry for the insistence in unwrap without even trying, but that really is work that I wouldn't want to introduce in my workflow. I'd prefer to have no bevel than to waste half an hour unwrapping a model)
                          www.casca.pt
                            jason_maranto
                            Edge effects are all controlled by geometry baked textures, so resolution would be an issue for larger models and UVs will become an issue if not properly handled. That is also assuming the SketchUp created geometry is intelligable to SD/SP... which could be the fault of the model creator or SketchUp itself.
                            • JQLJ Offline
                              JQL
                              Well I really have to try. I know how to texture a model in SU as preciselly as possible and only that unwrapping slips my grasp. My main objective is to keep everything inside sketchup as long as I can and just jump out of it when I really need.
                              Of course I'm open to a broader frame of mind if that does pay off.
                              Thanks for all your help Jason.
                              Let's see where this leads to...
                              www.casca.pt
                              • JQLJ Offline
                                JQL
                                I don't get it. At a certain stage the guy is trying to make squares fit together quite precisely, then, suddenly he starts dragging and scaling things around in what seamed a random way to me.
                                In the end the squares didn't fit together, obviously, so why did he do that in the first place?
                                www.casca.pt
                                  Krisidious
                                  4096 is as high as the maps go.
                                  they do already have procedural choices like tile size and dirt and aging. you can apply it in the converter then apply the texture to the model.
                                  But it doesn't seem to map correctly on it's own.
                                  He's doing that because the car is to scale and the image is pixels. the larger the mode detail of course and the uvw unwrap doesn't actually have to touch all over.
                                  By: Kristoff Rand
                                    Krisidious
                                    By: Kristoff Rand
                                    • JQLJ Offline
                                      JQL
                                      Yeah... Thea Substance Converter is pretty cool! I love hitting the randomize button! 😄
                                      www.casca.pt
                                        Krisidious
                                        without the real substance studio I think you will have to use maps and you will not get any of the options to affect the map procedurally.
                                        By: Kristoff Rand
                                        • JQLJ Offline
                                          JQL
                                          That's true and that's almost what I have right now. I'm used to create my own maps with an image editor and I like the control I have, but it takes me so much time fine tunning everything.
                                          I recently found awesome bump and it serves it's purpose very well and is also able to generate all the pbr maps one needs and name them with any convention.
                                          Basically that emulates the B2M workflow and it can also be used with Thea converter to automatically create a PBR material.
                                          So it really is the ability to tinker with procedurals inside Thea Substance Converter that is ticking me to dive into Designer.
                                          However, if you think of it that way, you're not getting much as the final result is a static material.
                                          So substance designer only really starts paying off if you use it for procedurally and non desctructivelly texture a specific model.
                                          Let's assume we can get a sketchup model to export nicely to Substance Designer, using 3ds or collada or obj. (as Jason pointed out it's not clear that even this is easily achievable...) But let's assume we can, then it all comes down to what Rich pointed out initially. UV mapping or ultimatelly UV unwrapping.
                                          If I can deal with that in my workflow, I can justify using Designer as it's the UV unwrapping that will allows me to place the effects I want, in the right place of the model inside Substance and then turn that substance into a material I can replace with a thea material inside sketchup.
                                          I'm willing to take the long shot and I hope I'll have an as streamlined as possible workflow in the near future (with just the enough details we need in architecture) to share with you guys.
                                          www.casca.pt
                                            Krisidious
                                            Ok I just got the trial of these programs because they are so cool that not only do they offer the Thea thing for free and not only is it a great program but it's priced to fit small business budget. Kudos allegorithmic.com
                                            So Now I'm trying the procedurals.
                                            By: Kristoff Rand
                                            • 3 / 6
