    Substance and Sketchup Workflow
    107 Posts 9 Posters 28.1k Views 9 Watching
    • KrisidiousK
      Krisidious
      And did you not see that model I just showed you that was uv unwrapped and rendered in thea? what's the difference.
      By: Kristoff Rand
      • KrisidiousK
        Krisidious
        By: Kristoff Rand
        • JQLJ
          JQL
          There's no difference, I know I can render an unwrapped model in Sketchup, the question is how to easily unwrap it.
          I wouldn't know where to start, Rich adviced blender, but with the incredible amount of going back and forth my models have, I'm a bit scared that unwrapping will be a step to create ultimate confusion in my workflow.
          There's nothing like trying it and I will, of course, try it. Just holding my breath before I dive in to it...
          www.casca.pt
          Visit us on facebook!
          • JQLJ
            JQL
            But Kris did you model it? How did you unwrap it?
            www.casca.pt
            • KrisidiousK
              Krisidious
              AC3D easiest unwrapper around. almost completely automatic in some cases it is... in other you may want to edit a bit. But we use maps that other people are going to paint later, so it needs to look a certain way. but if it's just you? easypeasy.
              (www.inivis.com)
              By: Kristoff Rand
              • KrisidiousK
                Krisidious
                By: Kristoff Rand
                • KrisidiousK
                  Krisidious
                  just part of the uvunwrapped textures on that car. and it rendered very fast. that top texture mapuvwun.JPG is 1000x1000?
                  By: Kristoff Rand
                  • JQLJ
                    JQL
                    Oh no! Do I have to do all that hand work on separating faces?
                    I have no time for that!
                    Imagine I model a pipe like that with some windows around.
                    I unwrapp it by hand like that...
                    What happens if the pipe gets stretched?
                    www.casca.pt
                    • KrisidiousK
                      Krisidious
                      You don't map stuff until you're done with an object or you remap it after you modify it. a pipe is not really something that takes any time to unwrap. you just select the faces and hit the button then save the image map. same with a box or any standard shapes. it's cars and what not that get harder.
                      http://www.inivis.com/supercoldmilk/ac3dplug/img/um_gui.gif
                      You can map multiple things to one map or each to their own. but to me, procedural means it doesn't need a map, it maps on the fly as it covers a surface. so as to not repeat an to flow or seem more realistic. it would use an algorithm to show a natural surface.
                      By: Kristoff Rand
                      • JQLJ
                        JQL
                        I'm not fully grasping, I have to try it!
                        The only comment I can make is that, of course, I'm not very concerned with cilinders but with the actual stuff I need to create wich is a bit more complex (though not as complex as a car)
                        www.casca.pt
                        • KrisidiousK
                          Krisidious
                          there are two or three plugins for AC3D that make the job a bit easier than that...
                          By: Kristoff Rand
                          • jason_marantoJ
                            jason_maranto
                            To answer the resolution question, in some cases it is possible to go higher. You definately want to do the bulk of the work at lower resolutions, but a lot of the best features of Substances come through geometry-baked textures as the base... baking those textures can be resource intensive at larger resolutions.
                            Substances make alot more sense for character and prop models based on subD which have high poly sculpts (ZBrush or similar) to pull geometry-based information from. SketchUp models are usually so basic that the best features of Substances really will be marginalized. And that is before you even have to deal with UV unwrap and seam issues.
                            Substances are geard toward next gen (sculpt heavy) wokflows being developed by vidogame companies. SubD modeling and great UVs are the basis of how these projects need to be done to see maximum results.
                            • KrisidiousK
                              Krisidious
                              watch this tut starting at the time set.
                              By: Kristoff Rand
                              • JQLJ
                                JQL
                                I also understand this quite clearly.
                                Simple is good!
                                So imagine all I want for a given model is to use one of the edge procedurals to create a fake bevel in my arch models.
                                Would I need to unwrap it to achieve my objective, or would I be able to achieve this without unwrapping?
                                (I'm sorry for the insistence in unwrap without even trying, but that really is work that I wouldn't want to introduce in my workflow. I'd prefer to have no bevel than to waste half an hour unwrapping a model)
                                www.casca.pt
                                • jason_marantoJ
                                  jason_maranto
                                  Edge effects are all controlled by geometry baked textures, so resolution would be an issue for larger models and UVs will become an issue if not properly handled. That is also assuming the SketchUp created geometry is intelligable to SD/SP... which could be the fault of the model creator or SketchUp itself.
                                  • JQLJ
                                    JQL
                                    Well I really have to try. I know how to texture a model in SU as preciselly as possible and only that unwrapping slips my grasp. My main objective is to keep everything inside sketchup as long as I can and just jump out of it when I really need.
                                    Of course I'm open to a broader frame of mind if that does pay off.
                                    Thanks for all your help Jason.
                                    Let's see where this leads to...
                                    www.casca.pt
                                    • JQLJ
                                      JQL
                                      I don't get it. At a certain stage the guy is trying to make squares fit together quite precisely, then, suddenly he starts dragging and scaling things around in what seamed a random way to me.
                                      In the end the squares didn't fit together, obviously, so why did he do that in the first place?
                                      www.casca.pt
                                      • KrisidiousK
                                        Krisidious
                                        4096 is as high as the maps go.
                                        they do already have procedural choices like tile size and dirt and aging. you can apply it in the converter then apply the texture to the model.
                                        But it doesn't seem to map correctly on it's own.
                                        He's doing that because the car is to scale and the image is pixels. the larger the mode detail of course and the uvw unwrap doesn't actually have to touch all over.
                                        By: Kristoff Rand
                                        • KrisidiousK
                                          Krisidious
                                          By: Kristoff Rand
                                          • JQLJ
                                            JQL
                                            Yeah... Thea Substance Converter is pretty cool! I love hitting the randomize button! 😄
                                            www.casca.pt
                                            • 3 / 6
